Glove Box Light
Discussion in '1st Gen Tundras (2000-2006)' started by 2006Tundra, Nov 11, 2020.
  1. Nov 11, 2020 at 6:33 AM
    2006Tundra
    2006Tundra [OP] Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    Hey, Guys.
    So I just discovered my glove box light and the filament of the lamp was burnt out. So I bought and installed a LED lamp. Nothing came on, So I grabbed a new halogen lamp to see if that would come on, nothing. I tested for power, nothing. I tested all the fuses in my truck and all came out good.
    Is there a switch that I'm not seeing? I've searched the forum, google, even my owners manual doesn't say anything.
  2. Nov 11, 2020 at 6:40 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Perhaps a fuse? Is everything else "working" fine?
  3. Nov 11, 2020 at 6:45 AM
    2006Tundra
    Lou
    Long Beach, CA
    All the fuses are good and everything else is working fine.
  4. Nov 11, 2020 at 7:17 AM
    Casper421
    In the woods
    06 DC
    Is the truck on when you’re testing the light? I remember mine works when the truck is running or the headlights are on, I believe.
    HulkSmurf14 and NewImprovedRon like this.
  5. Nov 11, 2020 at 7:43 AM
    2006Tundra
    Lou
    Long Beach, CA
    yeah, Truck on and headlights on and still no power.
    yup, I check every fuse, hood and under dash and they all gave good continuity. When you say pin switch, where is that located? I don't see a switch in or around my glove box.
  6. Nov 11, 2020 at 8:16 AM
    trueblue1981
    trueblue1981 New Member
    2006 white tundra sr5 dc
    TUINDRA 2006...can you post some pics of glove box light?? also what led are you using?
    HulkSmurf14 likes this.
  7. Nov 11, 2020 at 8:36 AM
    2006Tundra
    Lou
    Long Beach, CA
  8. Nov 11, 2020 at 9:31 AM
    trueblue1981
    looks like a t5 led goes into there.
  9. Nov 11, 2020 at 10:04 AM
    Casper421
    In the woods
    06 DC
    You said you checked for power and got nothing, did you use a multimeter? Any chance the polarity is reversed? Flip the bulb around? I know it’s a stupid question but have to eliminate possibilities.
    HulkSmurf14 and trueblue1981 like this.
  10. Nov 11, 2020 at 11:47 AM
    2006Tundra
    Lou
    Long Beach, CA
    I used my Fluke multimeter and I wasn't getting power to the socket. I did check the polarity to the bulb and flipped it, still nada. I appreciate the questions and I would be asking too.
    Yeah, my glove box light doesn't look like that. If you look at the picture I posted earlier, it's just a lamp holder, almost the size of a quarter.
  11. Nov 11, 2020 at 11:51 AM
    Casper421
    In the woods
    06 DC
    I’ll check mine out when I get home.
  12. Nov 11, 2020 at 11:53 AM
    trueblue1981
    same truck..same problem 2006 Tundra i think previous owner of my truck when they replace stock radio to after market they might have a wire leading to light to glove box who knows.
  13. Nov 11, 2020 at 11:53 AM
    2006Tundra
    Lou
    Long Beach, CA
    I'll do some more troubleshooting when I get home too. The old halogen lamp filament burnt out so at some point, it was working just fine.
  14. Nov 11, 2020 at 11:56 AM
    2006Tundra
    Lou
    Long Beach, CA
    I had my radio replaced several months ago but I never noticed my glove box light until recently. Why do you think the previous owner used glove box wire?
  15. Nov 11, 2020 at 11:58 AM
    trueblue1981
    Mine was cut..i didnt know until i replaced some leds on the a.c and found a royal blue wire leading to box.
    2006Tundra[OP] likes this.
  16. Nov 11, 2020 at 12:00 PM
    2006Tundra
    Lou
    Long Beach, CA
    When I get home, I'll check that out. Thanks
  17. Nov 11, 2020 at 4:58 PM
    2006Tundra
    Lou
    Long Beach, CA
    It works, not sure what I did but it works. I pulled the lamp from its housing, I unplugged the connector and for the 4th time, I checked for voltage but this time, I turn my truck on again and the head lights, again and then I tested for voltage and got 13v. I plugged the lamp back in and it works. Fucking automotive electrical, I curse you.
  18. Nov 11, 2020 at 5:48 PM
    trueblue1981
    Awesome!!! I was going to say, I was heading over to your place and help you since you live so close to me.
  19. Nov 11, 2020 at 6:01 PM
    I had the same concerns as you when I swapped to LEDs and found my glove box light was out. I thought I installed the LED backwards but it wouldn't work either way. Put the key in the ignition and kicked it to ACC, and in my case the glove box light only works if my truck has the key in ACC or ON position. Not sure if that might be what was biting you in the ass here but I'm tossing it out there anyway. Also an 06 here. Also went with a T5 LED bulb.
    trueblue1981 likes this.
  20. Nov 12, 2020 at 5:18 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    No switch on the 1st gen. They come on with the rest of the dash lights when the parking lights are turned on.
    Tundra2 likes this.
