Want a front camera on 2018 SR5
Discussion in 'Audio & Video' started by sludgepickle, Oct 7, 2020.
  1. Oct 7, 2020 at 1:06 PM
    sludgepickle
    sludgepickle [OP] New Member
    San Diego
    2018 Silver SR5 DC 4x4
    Has anyone installed a grille or bumper-mounted camera and tied it into their stock stereo head unit? Or maybe installed one and put a separate display somewhere?
    I'd love a camera right below the T badge on my 2018. I have bad depth perception and have to park in tight parallel parking often. I'd love recommendations.
  2. Oct 7, 2020 at 1:23 PM
  3. Nov 11, 2020 at 6:26 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I used the Beat-Sonic setup https://www.beatsonicusa.com/cs6ep.html I started with 1 camera on the bumper, then added 9 more cameras (underneath the truck and bumper corners) so that I can spot myself when I'm out wheelin and to eliminate my blind spots.
    Ely010606 likes this.
  4. Nov 11, 2020 at 6:38 PM
    TundraPHX
    TundraPHX Ryan started the fire.
    Jared
    You, my friend, are my spirit animal. I’m putting this together in my head. I’ll dig through your post history. Have you done a build thread on it?
  5. Nov 11, 2020 at 7:13 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    I have not written one up yet. Some of the guys on the forum were asking me to. If you already have a FRAC setup then all you need are:
    3pXt rotary dial (3pole and the X = number of cameras you want - I have a 3p10t dial for my 10 cameras, but I'm adding one more so I just picked up a 3p11t)
    Like this (you'll need to get the knob as well) https://www.amazon.com/gp/product/B00JJ46UX4/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
    https://www.amazon.com/Uxcell-a1406...keywords=6mm+knob+dial&qid=1605196696&sr=8-10
    One male to male RCA extension:
    https://www.amazon.com/2-RCA-Fosmon...words=male+to+male+rca&qid=1605150553&sr=8-21
    Multiple RCA to bare wire:
    https://www.amazon.com/gp/product/B00G352P2C/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
    The rotary dial has 3 common terminals:
    Terminal 1: RCA cable 1 of 2
    Terminal 2: RCA cable 2 of 2
    Terminal 3: ACC power
    Image should be self explanatory.
    joonbug likes this.
  6. Nov 11, 2020 at 10:19 PM
    TundraPHX
    Jared
    glad to know I’m not a crazy person thinking cameras underneath the truck would be money. I already own the FRAC harness from running4tacos.
    do you have any photos of the cams you used and mounting locations?
    is dust and mud an issue? I have the ARB and have this vision of finding a way to have air and water nearby and a momentary button to wash all 6 of mine at once and then another momentary for my on board air to dry them. (Will get tank If have to)
    I have searched and searched and can’t believe I hadn’t run into you yet. This is great news for me. Proof of concept has worked!!
  7. Nov 12, 2020 at 7:05 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Here are the cameras I used:
    These give you good straight ahead views without the fisheye distortion.
    2 x https://www.amazon.com/Backup-Waterproof-Starlight-1280×720-Definition/dp/B078ZZSKQ2/ref=sr_1_7?dchild=1&keywords=Natika&qid=1605190959&sr=8-7
    These give you a flush or bracket mount option AND it allows you to rotate the camera so that the view is level.
    9 x https://www.amazon.com/gp/product/B083SF5VVN/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    This is where my cameras are mounted:
    1. FDB (front driver bumper) Flush mount (1 of 9 cameras)
    2. FDL (front driver LCA) Bracket mount (2 of 9 cameras)
    3. FCD (front center diff) Bracket mount (1 of 2 cameras)
    4. FCB (front center bumper) Bracket mount (2 of 2 cameras)
    5. FPL (front passenger LCA) Bracket mount (3 of 9 cameras)
    6. FPB (front passenger bumper) Flush mount (4 of 9 cameras)
    7. RPB (rear passenger bumper) Flush mount (5 of 9 cameras)
    8. RPD (rear passenger diff) Bracket mount (6 of 9 cameras)
    9. RCD (rear center diff) Bracket mount (7 of 9 cameras)
    10. RDD (rear driver diff) Bracket mount (8 of 9 cameras)
    11. RDB (rear driver bumper) Flush mount (9 of 9 cameras)
    Gorilla Glue double sided tape works really well for securing the bracket mounted cameras.
    Cameras getting dirty are only an issue for the rear diff cameras when you actually go through mud or go through some water and then get dry dust onto the camera, which isn't that big of a deal. The only time I use the rear diff cameras is when I have to go over an obstacle, which I have to get out of the truck to determine my line, at which time I just quickly clean the camera lenses before getting back in the truck. I went wheelin this past weekend - there was snow, mud, water, you name it and I only had to wipe down the rear diff cameras once.
    For daily driving I find cameras 6 & 7 to be really useful. I use 7 to see my rear blind spot. I use 6 when there are a lot of pedestrians (parking lots, downtown, etc.) cuz I sometimes can't see people walking in front.
    Camera 4 is what I use the most when on the trail as it allows me to see what's on the other side of a hill as I begin to crest it.
    I'm adding camera 3 to better judge the height of an obstacle as I approach it.
    Also, wanted to note that camera 3 & 4 will be near the 12o'clock position on the rotary switch so that I instantly know which cameras I'm pointing at without taking my eyes off the road/trail.
    I'll do a full write up soon since I'm adding another camera.
    Boerseun and TundraPHX like this.
