  1. Nov 11, 2020 at 8:14 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    I have been pondering these as well...
    Yes, heat is an option.
    http://www.toro1.tw/product_1019570.html
  2. Nov 11, 2020 at 8:18 AM
    MaxYota
    MaxYota GrilledCheese
    Murf
    MS Gulfcoast
    2019 TRD PRO VooDoo Blue
    Mighty Mouse suction cupped to the review 8 ball shifter. Driver side "Oh poop" handle. Smoked side window deflectors. ReadyLift TRD PRO +2 for front. 1.5" ProFormFab Shackles + 1" ToyTec block for rear. SDHQ Hidden winch mount with Badlands 9000 winch. 305/70r18 Cooper Discoverer STT PRO
    Yes they are still power adjusted but the whole mirror moves. The convexed part is manual so if you adjust your mirrors you will have to get out and adjust the convex. Not sure how to post a link but here’s my try....
    https://spottermirror.com/p/toyota/2007-2020-tundra-spotter-mirror/
    The wires from the stock mirror plugs into the new mirror. I have not used the defrost yet.
  3. Nov 11, 2020 at 8:18 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Can't find where to order them from that site tho...
    Sweet - I just found that site about the time you posted. Order placed...
  4. Nov 11, 2020 at 8:36 AM
    Will1606
    Will1606 New Member
    Will
    NJ
    2019 TRD DCLB
    I have a set that I picked up used off this forum that has (had) the same problem. Hit them with the pressure washer to clean them up and most of the powder coat came off real easy. Was thinking of options and maybe doing the same thing, can I ask how much they charged you to line-x them?
  5. Nov 11, 2020 at 8:37 AM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    It’s been almost 3 months since getting creative with relocating the TSS, for anyone considering an aftermarket grille or any grille for that matter that doesn’t have a spot for TSS, works like a charm!
    TSS Update/Transmission Cooler Coming To The 2020 Tundra
    https://youtu.be/M1NF8bcRz_c
  6. Nov 11, 2020 at 8:51 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Did N-Fab give you any sort of remedy under their 5-year warranty on the powder coat?
  7. Nov 11, 2020 at 11:53 AM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    Added a bracket from Powertank for my 5lb propane tank. Seems like it'll work pretty well, but wasnt cheap :eek:
  8. Nov 11, 2020 at 12:04 PM
    FirstTruck
    FirstTruck New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
    Whats the offset on those wheels?
  9. Nov 11, 2020 at 12:06 PM
    Dceclipse
    Dceclipse New Member
    NORCAL
    4AC71AA8-654E-4157-A5D9-4EA97C6C3643.jpg Finally removed my liner before it start raining, found some rust build up on the bed too.. now time to get some rhino lining for it.23D60D4D-FFA5-4D10-8C72-65D9340082BC.jpg
  10. Nov 11, 2020 at 12:08 PM
    YotaBro
    YotaBro This forum will make me broke
    Calvin
    FL
    2017 Cement Grey Tundra TRD PRO
    Lots of shenanigans.
    Lmk how it goes
    Dceclipse[QUOTED] likes this.
  11. Nov 11, 2020 at 12:09 PM
    Dceclipse
    NORCAL
    Will do Calvin
  12. Nov 11, 2020 at 12:26 PM
    Wallygator
    Very nice!
    junior[QUOTED] likes this.
  13. Nov 11, 2020 at 12:34 PM
    Wallygator
    Built the battery cables for the battery box finally. Then had to stop the rest of the wiring cuz I left my wiring supplies at a friend's house. We were gonna wire up some LEDs on his Vstrom and got side tracked. Oh well. The build continues.
    So moved onto organizing the interior a little. Took out the dbl cab factory storage container cuz it doesn't really work for my set up. Bought these Plano boxes at the depot for $15 each and basically triples the storage and organized it ten fold. Happy with this for sure and can easily remove if I decide to pick up some hitch hikers an need the seat. May have to bungie these down but not a problem.
    Then in between rain sessions installed the K9 mounts on the tent and started laying out where the solar panel is going to go along with sorting out the mounting of it. Pretty sure it's going here:thumbsup:.
    Solar panel frame is bare aluminum so may paint it black to conceal things a little more. Too humid for any painting today.
  14. Nov 11, 2020 at 1:12 PM
    They wanted me to order another set through the site that I ordered them from and then pay to ship the other ones back. I told them no because shipping would have been expensive and the next set would just do the same thing. Alot of mass produced items have crappy powdercoat jobs on them.
  15. Nov 11, 2020 at 3:47 PM
    Derf77
    Derf77 New Member
    Fred
    South Chesterfield VA
    2020 Crewmax SB SR5 TRD Off Road
    TRD rear sway bar, Ready lift 3/1, 4 window auto up/ down.
    And it just still fits in my garage!
  16. Nov 11, 2020 at 4:24 PM
    TrenThom86
    TrenThom86 New Member
    Trent
    NW Louisiana
    2021 TRD Pro Lunar Rock
    Today I installed Firestone ride rite bags on my TRD pro along with Daystar cradles.
  17. Nov 11, 2020 at 4:42 PM
    easleycrawler
    Travis
    Easley, South Carolina
    19 TRD SPORT CM MGM 4WD
    Makes towing sooo much better.
    Bigboitundra, 2020Platinum and Derf77 like this.
  18. Nov 11, 2020 at 4:52 PM
    16MagSR5
    16MagSR5 New Member
    Buffalo
    2016 Magnetic SR5, leveled and capped
    Boost tow Mirrors, TRD rear sway, Rough Country Duals, Bilstein 5100's, diff breather mod, more that I'm forgetting...
    The vinyl looks great. I'm going to pull the trigger on it soon I think. A few questions...How hard was it? I have a vinyl cutter, so I understand the product a little. How large of a piece do I need? Were you able to do it on the truck, or had to remove the ends? What brand vinyl did you use? Any tips/tricks? Thank you for any preliminary help you can provide.
    manhster likes this.
  19. Nov 11, 2020 at 5:11 PM
    tightywhitey
    tightywhitey New Member
    New Orleans, LA
    2015 Toyota Tundra CREWMAX - Louisiana Edition
    Installed hertz 6.5 in the doors and a JL powered sub
    KnoxHog22 and GarTX526 like this.
  20. Nov 11, 2020 at 5:30 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Need to post that truck over in the Lunar Rock club! Nice setup
  21. Nov 11, 2020 at 5:48 PM
    biebs96
    PA
    I wish they made them for the tow mirror glass. I’d love the extra angle view.
  22. Nov 11, 2020 at 5:48 PM
    JSKOOL
    JSKOOL IG: @trd_jay_z06
    Jay
    Bay Area, CA
    2017 Black Tundra Limited
    My nephew has his own detail business and he’s the one who wrapped them. He did them with the caps on, but I think it would be better for you to remove them. There are a few imperfections on my mine. I wrapped them for the mean time until I decide on a new front bumper. I believe he used 3M brand vinyl, but not sure how much product he used. There are some difficult angles on the caps, but with a little time and finesse, you’ll be fine.
  23. Nov 11, 2020 at 5:52 PM
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    If your tires rub the front plastic molding and want to fix the issues....coach builder 1/2” bumper shims fixed my rubbing. 3.5” lift rims 20/9/+12 tires 33.1x10.8x20. Prior would rub at full lock now have 3/4” gap. I also loosened the factory end caps and pushed it another 1/4” out. Hence the 3/4” gap at full lock
  24. Nov 11, 2020 at 5:54 PM
    JSKOOL
    Jay
    Bay Area, CA
    Will these create enough for 35’s? (Currently on a 3” suspension lift).
  25. Nov 11, 2020 at 5:57 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Running 33” with 3/4” gap maybe 34” but 35” not to sure
  26. Nov 11, 2020 at 6:37 PM
    Toptalktoyota
    Toptalktoyota New Member
    2020 DC SX
    I got these for my truck. Very nice, easy to install, awesome blind spot mirror. Power adjustable and heated.
    Cosmoblu and RainMan_PNW like this.
  27. Nov 11, 2020 at 6:45 PM
    DMV_Tundra
    DMV_Tundra New Member
    2021 Tundra Limited, Nightshade Magnetic Gray Tu
    Window Tint, TRD Dual Exhaust
    mind sharing how much?
  28. Nov 11, 2020 at 7:05 PM
    TrenThom86
    Trent
    NW Louisiana
    Bags were $391 from e-trailer. Daystar Cradles were $70 from Amazon.
    Amazon had the air bags a little cheaper from a third party seller but I went with e-trailer because I’ve had good luck with them a lot.
  29. Nov 11, 2020 at 8:17 PM
    TundraChungus
    TundraChungus New Member
    Phoenix, AZ
    So, if any of you decides to get a Move rear classic bumper, its a good idea (if you aren't welding it yourself) to ask your fabricator to make new mounts for it, as the ones they provide give very little room and the tailgate might hit it.
    A call to customer support, the refunded me a couple hundred bucks, and said they'd talk about changing the mounts in the future.
    Awesome bumper besides that little hiccup and looks pretty awesome, too, in my opinion.
    Cosmoblu, Paulskie, Sean492 and 16 others like this.
  30. Nov 12, 2020 at 5:40 AM
    the ER kid
    the ER kid New Member
    2020 Platinum Crewmax
    I did the AJT black out and love the look. Used 2020Platinum's video
