Frozen Lock
Discussion in 'General Tundra Discussion' started by Tundyfundy, Nov 10, 2020.
  1. Nov 10, 2020 at 8:47 PM
    Tundyfundy
    Tundyfundy [OP] Petunia The Tundra, and her sidekick Colbie
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Hey all,
    I was camping with the family in freezing temps (staying cozy in our travel trailer!). I went out to get something out of the bed of my truck and I’m pretty sure the tailgate lock was frozen. It wouldn’t budge using the key. I was able to open it once things warmed up but is there anyway to prevent that? I have a bed cover so I was pretty much locked out of my truck bed. Any insight would help...
  2. Nov 10, 2020 at 8:52 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    spray some diluted alcohol??? I use to do this in Reno, and would drop some on my windshield and it would melt ice with the quickness....
    Tundyfundy[OP] likes this.
  3. Nov 10, 2020 at 9:09 PM
    Tundyfundy
    Bay Area, CA
    I was hoping for a permanent fix, like some coating I can put in there to prevent freezing but that sounds like a good method once it’s frozen.
  4. Nov 10, 2020 at 10:55 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Tundyfundy[OP] and Saltyhero13 like this.
  5. Nov 11, 2020 at 6:56 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    I'd imagine WD40 or anything similar would work fine.
    szabo101 and TTund16 like this.
  6. Nov 11, 2020 at 9:14 AM
    TTund16
    TTund16 New Member
    WD-40 works great. it will also make the inside parts smooth again.
    Squirt some in there with its straw. I wouldn't overdo it.
  7. Nov 15, 2020 at 7:20 PM
    Tundyfundy
    Bay Area, CA
    Apparently WD 40 can degrade the tumblers over time.
  8. Nov 15, 2020 at 7:54 PM
    Tundra-in-Cement
    Tundra-in-Cement Truck Chump
    2021 Tundra CM-OR
    Scanguage-II, Decked Systems, Leitner Rack, CaliLED lights, Firestone Air Bags, Trans-cooler kit, 2017 Pro grille and bulge, S-Tech 6 way switch, Corse Evo Darks w/ Stock Tires, 17-inch Alpha Equip Delta w/ Wildpeaks, Falcon Suspension, Coachbuilder +1 Shackle, Valhalla Cat Protectors.
    You might research graphite. B'laster graphite spray at Walmart might be worth a try. About $9.
  9. Nov 16, 2020 at 9:23 PM
    TTund16
    TTund16 New Member
    I have sprayed wd-40 in all my cars and never had a failure and they all worked great in very cold winters without freezing. My Tacoma is over 20 yrs old. Maybe I should stop doing it. :D
    Let us know what's the best thing to use.
  10. Nov 16, 2020 at 10:10 PM
    Tundyfundy
    Bay Area, CA
    WD 40 is a light lubricant but acts as a solvent. It will remove previous lubrication placed into the lock. The biggest problem is it attracts and sticks to dirt and dust, as well as it dries out in a short period of time, which is what will do the damage. The tumblers are the little pins and springs that move up and down when you insert your key. Once coated in WD40 and dust the movement of those pins will create an abrasive environment. Apparently for locks a dry lubricant is recommended. Petroleum based lubricants are generally not recommended due to the dust and dirt being attracted to them. As far as lubrication for locks there's tons of info out there but not so much for keeping them from freezing.
  11. Nov 16, 2020 at 10:23 PM
    Tundyfundy
    Bay Area, CA
  12. Nov 16, 2020 at 10:50 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I spray a wee shot of Fluid Film in with the straw, once a year. No freezing, no seizing, no corrosion, no explosion.
