Anyone know what these things are called?
Discussion in 'General Tundra Discussion' started by skphillips78, Nov 5, 2020.
  1. Nov 5, 2020 at 7:02 PM
    skphillips78
    skphillips78 [OP] New Member
    Shawn
    Oklahoma
    2016 Toyota Tundra SR5 Crewmax TSS 4X2 - 4.6L V8
    Does anyone know what these are called and if they are hard to replace? ~Pic attached~
    The one on the driver side makes a loud popping noise every time I open the door. I think it’s cracked or something.
    Thank you in advance!
    Shawn P.
    2016 Tundra SR5 4.6L V8 CrewMax TSS
  2. Nov 5, 2020 at 7:38 PM
    Wallygator
    I think that is called a door check. Make sure but this is what I think it is...OOPS I looked it up for a 5.7 than saw you have the other engine. Shouldn't make a difference but call @Roman at Sparks and make sure.
    https://www.sparksparts.com/oem-par...1bmRyYSZ5PTIwMTYmdD1zcjUmZT01LTdsLXY4LWdhcw==
    Another link...
    https://www.sparksparts.com/v-2016-toyota-tundra--sr5--5-7l-v8-gas/body--front-door
  3. Nov 5, 2020 at 9:43 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    @Roman doesn't work for Sparks, he works for Toyota of Cool Springs.
    Unfortunately their online store isn't taking orders right now.
    https://parts.toyotaofcoolsprings.com/
    Although I do think you have the right part.
    It is cheaper here..
    https://toyotaparts.bochtoyotasouth.com/oem-parts/toyota-door-check-686100c023
    @skphillips78 you could try messaging @Roman and see if that is the correct part.
    Not sure if he is responding to messages or not..
  4. Nov 6, 2020 at 11:58 AM
    Wallygator
    OOPS!:D Sorry about that.
  5. Nov 6, 2020 at 2:00 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Wait, it's not normal for it to pop??? My driver side rear door has popped since "new"...
  6. Nov 6, 2020 at 2:12 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Spray a little lithium grease on it.
    skphillips78[OP] and Black Wolf like this.
  7. Nov 6, 2020 at 5:42 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Try tightening up the studs on door and body. Think 10mm socket. Sometimes they loosen and create that popping noise.
  8. Nov 8, 2020 at 5:56 PM
    Mxvet90
    Mxvet90 New Member
    I had that happen on my Camry. I loosened the bold and slightly moved the latch and re tightened and the popping went away
    Sunnier and skphillips78[OP] like this.
  9. Nov 8, 2020 at 9:44 PM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    That's called a "doorcheck".
    1lowlife likes this.
  10. Nov 8, 2020 at 10:20 PM
    NoRcptn
    NorCal
    2017 Platinum
    Yes they break. Ive replaced both on both of my Tundra's. The right side of the door check where the pin goes through should not have a crack in it. The popping can also be from the inside. Basically it pulls on a plastic tab against a metal plate. That tab can easily wear out. There some video's online of removing the door panel. I was able to reach in without removing anything else. It takes a little work but less time consuming. Total project was about 15 minutes.
    https://www.youtube.com/watch?v=2KHUaUM_q28
    Wallygator likes this.
  11. Nov 8, 2020 at 10:42 PM
    Sunnier
    Sunny
    San Diego, CA
    Also called a “detant” or “detent”.
