Another 5.7 Cam Tower leak
Discussion in '2nd Gen Tundras (2007-2013)' started by letsgetbeaned, Nov 8, 2020.
  1. Nov 8, 2020 at 5:06 PM
    letsgetbeaned
    letsgetbeaned [OP] New Member
    Rhode Island
    What’s up guys,
    I’m new to to his forum and think I have the dreaded cam tower leak. I’ve got a 2008 5.7 with about 135k miles and am leaking lots of oil right from the crappy RTV layer. As you all know this isn’t a cheap fix and would like to postpone the repair for now. Does anyone have any suggestions to delay the repair? Or whats the best option for me to get it rebuilt ?
  2. Nov 8, 2020 at 6:14 PM
    Welcome to the site.
    Only way to delay the repair is keep adding oil. This leak can get worse over time, so keep a watch on oil level.
  3. Nov 8, 2020 at 6:35 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    wait, cam tower leak??? isn't it also known as the valve cover?? I'm pretty sure this is an easy fix... Unless you blew a head gasket then we could be talking about a complete rebuild....
  4. Nov 8, 2020 at 7:02 PM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    It's not a backyard job from what I seen. It's more like 30 hours or more from start to finish.
  5. Nov 8, 2020 at 8:21 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    @blackdemon_tt the cam tower is not the same part as valve cover.
  6. Nov 8, 2020 at 8:23 PM
    AZTundra
    Paul
    Phoenix, AZ
    Had mine done (drivers side only) at about 30k miles. Think it took Toyota 1.5 days to complete if I recall correctly.
  7. Nov 8, 2020 at 8:25 PM
    blackdemon_tt
    Is it the timing chain cover?? or the heads?? slightly confused... May have to look at this...
  8. Nov 8, 2020 at 8:34 PM
    AZTundra
    Paul
    Phoenix, AZ
    Here's a picture of mine after the repair. Poor picture, but you can see the black gasket maker used.
    blackdemon_tt[QUOTED] likes this.
  9. Nov 8, 2020 at 8:36 PM
    blackdemon_tt
    OOOH SHIT.... got it.. lol my bad.. I see it now...
  10. Nov 8, 2020 at 8:38 PM
    Dalandshark
    Northwest
    Eibach Level LIft
  11. Nov 8, 2020 at 8:41 PM
    zeekevin
    zeekevin New Member
    I had the cam tower, timing cover and the coolant valley resealed recently. It was no fun at all.
    Filthyphil, TTund16 and Dalandshark like this.
  12. Nov 8, 2020 at 8:48 PM
    blackdemon_tt
    damn.... that thing splits... learned something new today.... I guess its easier to replace if it goes sideways... easier to pull the engine as I've seen.... Well, I may check mine, since I've been pulling engines as of late too....
  13. Nov 8, 2020 at 9:00 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    The consensus here from a few Toyota techs that do this regularly is that its about a 8-10 Hr. job for both sides. There's a vid of it somewhere here on the forum.
  14. Nov 8, 2020 at 9:38 PM
    Blueline
    Blueline New Member
    Jeb
    Temecula, CA
    2016 Tundra TRD PRO crewmax
    Bakflip MX4
  15. Nov 9, 2020 at 1:00 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    A lot of folks don't bother getting the repair done unless they smell oil burning on the exhaust (or see it dripping on the driveway, which I understand is rarer).
    Filthyphil likes this.
  16. Nov 9, 2020 at 3:59 AM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    Yeah it took the master mechanic at the dealership a few days to do mine. He actually took the cab off because it was easier for him. I’m hoping my 2020 starts leaking soon so they can fix it. Just get it out of the way
  17. Nov 9, 2020 at 4:40 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    More pictures...
    GFG5QyDZnXqVG_T9ufnIsGWXgAfg3iKNvDUaKaHl_98206314ac9e39a1df299c278968f432951714b0.jpg
    50uvHOghvLi1HVKa76-BQrGi_lhSldQREkRnRZIY_4fa765a6e3975ce9ddbe9be93d853443ea8d5878.jpg
    ruX1PMYcknFT-1rS2o5Mt85aSacIoSOdxkoTYyAX_18bfe6f933cbe85d96f8a29f10ca45e41e0715a0.jpg
    Filthyphil and GODZILLA like this.
  18. Nov 9, 2020 at 4:40 AM
    zeekevin
    zeekevin New Member
    mine was leaking oil pretty good when I started parking downhill and the smoke got pretty bad we’re it looked like it was going to catch fire for me.
  19. Nov 9, 2020 at 4:49 AM
    letsgetbeaned
    Rhode Island
    @zeekevin
    God damn bro that looks no fun. I can twist a wrench but that might be beyond my mechanic abilities. Where did you have it done? Dealership, yourself ?
  20. Nov 9, 2020 at 4:50 AM
    letsgetbeaned
    Rhode Island
    Mines leaking all over exhaust and all over driveway. Already almost lost a whole quart of oil... Very noticeable when driving it’s all i can smell.
  21. Nov 9, 2020 at 4:54 AM
    You pretty much have no choice at this point but to get it repaired.
  22. Nov 9, 2020 at 4:56 AM
    letsgetbeaned
    Rhode Island
    I know, now just finding someone i trust to perform open heart surgery on my girl...
  23. Nov 9, 2020 at 5:08 AM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    That’s a lot of oil? Are you sure it’s not something else? Oil filter ,drain plug ,valve cover gasket? Get under engine and check everything. Do you change your own oil and when or did Jiffy Lub do it?
    Good luck. Keep us posted. Peace. D
  24. Nov 9, 2020 at 5:14 AM
    letsgetbeaned
    Rhode Island
    Yes i change my own oil and do almost all maintenance my self. I spent all day cleaning and following the leak yesterday and it’s apparent its coming from the cam seal.
    I don’t think i’ve noticed it for about 500-1000 miles so it’s over the span of that time.
  25. Nov 9, 2020 at 5:41 AM
    zeekevin
    zeekevin New Member
    Loosing a quart of oil sounds about right. I had my friends shop do the repair and it took them a few days as they wanted the sealant to cure fully before adding all the fluids back in.
    The price I paid was very fair compared to how much it should of cost. I just had them replace everything else while they were in there. Like all the gaskets and seals were replaced with new Oem ones and cleaned everything from all the leaks before
    Black Wolf likes this.
  26. Nov 9, 2020 at 6:54 AM
    letsgetbeaned
    Rhode Island
    What was the final price you paid? Did they use a more durable RTV layer?
  27. Nov 9, 2020 at 7:03 AM
    zeekevin
    zeekevin New Member
    I paid less than 3k but also had everything else in the cooling system replaced also and the fan clutch and upgrade alternator since everything was out. They used the updated black Toyota sealant.
  28. Nov 9, 2020 at 7:09 AM
    letsgetbeaned
    Rhode Island
    Yea that is a fair price. The good news is that after that rebuild i’m sure the 5.7 is now bulletproof. After i have this done i’m expecting no less than 750k on my engine Haha.
