  1. Nov 8, 2020 at 12:09 PM
    #4471
    ACDC2ZZTop
    ACDC2ZZTop Rock n Roll!
    Travis
    Oregon
    2012 MGM Tundra double cab 5.7L V8
    All cosmetic so far see my posts in 2nd gen Black out chrome in progress….
    Painted hallway
    Trip to building center tomorrow to get all new door frame moldings To paint and put up this week
    TaquitoBandito and Fotnot like this.
  2. Nov 8, 2020 at 12:18 PM
    #4472
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    Set up my new compressor. Yes I know HF stinks of contractors needs, but will be fine for my needs. I had a HF torpedo style for 8 years before of died. I replaced it with the pancake style and looked out for a good deal on larger sizes. Between a price of $164 and decent reviews I went back to HF.
  3. Nov 8, 2020 at 12:47 PM
    #4473
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    5 years with my HF 8 gal hot dog. Works great.
    kparrow and TomC843[QUOTED] like this.
  4. Nov 8, 2020 at 1:17 PM
    #4474
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Seeing that hose reel gives me nightmares. I installed the same one on the ceiling in the middle of my garage. Holy hell that was a pain in the ass.
  5. Nov 8, 2020 at 2:01 PM
    #4475
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Want to move the ceiling light in the kitchen to be over the table. Pretty sure the joists are running parallel to the direction I want to move it. Think this is an easy enough job?
    Leave the connector box, run new wire with wire nuts, and add drywall over the top? I know they have the new connector box for adding to drywall without nailing it to a joist.
    535A137B-996A-4754-B0BF-19E4002AC3D0.jpg 6AB976B4-7059-4CAC-8424-6EB329AEC9EF.jpg
    TaquitoBandito, Fotnot and jewsNbrews like this.
  6. Nov 8, 2020 at 2:25 PM
    #4476
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Just swapped the can light bulbs in the kitchen and downstairs restroom for LED bulbs. Also did the light fixtures in the dining area. Now I just have the chandelier at the front door and the 2 bulbs in my garage door opener left and I'll be fully converted.
    Of course, my wifes friend stopped by last week and told her how studies show LED ligt is bad for our health and fluorescent is healthier. :rolleyes: I told her that same guy thinks holding infrared lights against your body will heal injuries, we should be fine.
  7. Nov 8, 2020 at 2:45 PM
    #4477
    BlueRibbon4x4
    Geno
    Is there a room above this ceiling? If so, you don’t want to drywall over an existing box with breaks in the romex. It should remain serviceable. Of the switch is coming from the direction you want to move the light, there’s a good chance you can cut your new hole for the light, and pull the wire through. My guess is the switch is perpendicular to where the new light goes, to which you’ll have to run the wire from the switch. This also depends on where your feed is going. Most of my experience is that it goes to the switch. Then again, it’s your house and you’ll know where the box is buried if there’s ever an issue. But it’s not recommended.
    saybng and T-Rex266 like this.
  8. Nov 8, 2020 at 2:48 PM
    #4478
    :hattip:
    NewImprovedRon likes this.
  9. Nov 8, 2020 at 2:51 PM
    #4479
  10. Nov 8, 2020 at 2:51 PM
    #4480
    csuviper
    Broomfield, CO
    Yes room above so I end up with a white circle plain cover. Not the end of the world but manageable.
  11. Nov 8, 2020 at 2:58 PM
    #4481
    Si
  12. Nov 8, 2020 at 3:07 PM
    #4482
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Maybe change the existing light to a recessed can light and make a run from that for a light over the table area? You could use a can light for the new light or a fixture, if a fixture i would consider even adding a 3rd light down the line a little to make it look even.
  13. Nov 8, 2020 at 3:08 PM
    #4483
    BlueRibbon4x4
    Geno
    Oh I see. Then yep. You should be good to go.
  14. Nov 8, 2020 at 3:32 PM
    #4484
    TomC843
    Tom
    Charleston, SC
    That's from Northern Tool. I mounted it to a board then mounted the board.
  15. Nov 8, 2020 at 3:38 PM
    #4485
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I like your helper there. :D
    Assuming there’s another story up there, it depends on if the joist space is insulated, and how heavy the new light will be. You can’t simply splice the wires and patch over the old hole...gotta have access to any splices by code, and there’s a good chance the wiring is well secured and not coming from the middle of the room, so you’ll have to splice and fish to the new box. Easiest would be to leave the old light and add a new one over the table, but still some work.
    csuviper[QUOTED] likes this.
  16. Nov 8, 2020 at 3:42 PM
    #4486
    He has another story on it
  17. Nov 8, 2020 at 4:04 PM
    #4487
    csuviper
    Broomfield, CO
    Ok I like the change existing to recessed because I have a bunch of recessed throughout the house
    RainMan_PNW and Pudge[QUOTED] like this.
  18. Nov 8, 2020 at 4:12 PM
    #4488
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Just finished the desk. I can officially give up coffee because when the sun hits this I won't feel sleepy.
    2 mistakes:
    1) I didn't have a flat surface to screw this thing together on, and one leg the wood was a bit twisted. So even though the frame measures square, its off just a bit at the top.
    2) I got in a hurry staining the top. The most important part to do and I rushed it. Its a bit more saturated than the sides, not as dramatic as in this picture though.
  19. Nov 8, 2020 at 4:22 PM
    #4489
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Looks great, but am I the only one surprised at all the color or lack of black in your house?!?
    Darkness[QUOTED] likes this.
  20. Nov 8, 2020 at 5:03 PM
    #4490
    BlueRibbon4x4
    Geno
    Thanks!!
  21. Nov 8, 2020 at 7:52 PM
    #4491
    Sapper406
    Sapper406 New Member
    2024 Tundra Limited, 3in lft, trd package
    TRD Air Intake, TRD Center Cap, 18x8 matte black TRD Pro Forged Alloy Wheels, Tailgate insert black badge, Lomax hard matte black tri-fold tonneau cover, TRD dual exhaust w/black exhaust tips and muffler and TRD matte black badge. 2.5 lift
    the lack of black or color could be consider a modern look.
    Darkness likes this.
  22. Nov 9, 2020 at 7:25 AM
    #4492
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    :rofl:I was waiting for that! Wife controls the color scheme indoors unfortunately. Although I picked the colors for this desk, it had to get approved by her.
    First day using it, my keyboard is so loud now. Its a satisfying real wood sound, best way I can describe it. Next I would like to find a way to wall mount my 32" and maybe make a matching stand for the office supplied little monitor.
    saybng, jewsNbrews, Trooper2 and 2 others like this.
  23. Nov 9, 2020 at 9:06 AM
    #4493
    helloo
    helloo New Member
    Aurora, CO
    2018 Black TRD CM Limited
    I did the same thing a few years ago when the chandelier was not lined up with the table.
  24. Nov 9, 2020 at 12:21 PM
    #4494
    BlueRibbon4x4
    Geno
    Nice patch job. :thumbsup:
  25. Nov 10, 2020 at 6:42 AM
    #4495
    AZTundra
    Paul
    Phoenix, AZ
    Remodel day 6. Not too much happened yesterday. Prepped the drywall in the kitchen and bathroom for running additional outlets. Chipped away the concrete to replace the pipes for the new tub.
  26. Nov 10, 2020 at 1:05 PM
    #4496
    AZTundra
    Paul
    Phoenix, AZ
    Remodel day 7. Added outlets in kitchen and another light switch (3 way), added 2 outlets in bathroom. Electrical in the kitchen was cleaned up and extended as needed where there wasnt enough slack since the ceiling will be raised. Tomorrow planning to get the tub started and remove the water softener and install a utility sink in the garage.
  27. Nov 10, 2020 at 5:38 PM
    #4497
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    Deep cleaned the carpets with an industrial Bissell cleaner. What a chore, but the carpets look like new now.
    My wife did 'em, I mean.
    So proud of her.
    Took the dog outside to stay out of her way.
  28. Nov 10, 2020 at 5:53 PM
    #4498
    Vizsla
    Vizsla 2 = 2.5
    Pool shotcrete today
  29. Nov 10, 2020 at 6:12 PM
    #4499
    csuviper
    Broomfield, CO
    Short move and I’m guessing you didn’t leave wire nuts in the previous spot. Mine needs to move about 6’ and in the opposite direction of the switch. Good job with the hole patch!!!
    AZTundra likes this.
  30. Nov 10, 2020 at 8:34 PM
    #4500
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Took apart my sliding patio door to try and replace the interlocking weatherstripping. The replacements were too small and it appears I just need to find some foam tapered weatherstripping. BUT NO ONE SELLS IT ANYMORE. The old stuff is from Q-Lon but appears too thin and doesn’t seal well. May be stuck using some creativity :/
