  1. Nov 6, 2020 at 8:17 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    When I first put GY Duratracs on my 2008, I would get a rub only at full lock making a right-hand turn. The thin aluminum TRD “skid plate” was the culprit and all I did was smack it with a hammer to bend it a little farther up and it was all fixed. I looked at the opposite side, and it was already bent on that side (maybe the guys at the tire shop had done it and didn’t get the drivers side enough?).
    That worked until I went to 305’s (I think they were 305/65R18s), at which time the shop that put those on had to actually trim that skid plate.
  2. Nov 6, 2020 at 8:54 PM
    Heath423
    Heath423 New Member
    Heath
    Chattanooga, TN
    2020 Magnetic Gray CM SR5 4WD
    Console tray/dividers, Interior LED's
    Purchased from Amazon the brand was MostPlus. Identical to 1Aauto and Boost Auto but at 1/3 of the price. Only time will tell how they hold up. So far I am pleased.
  3. Nov 6, 2020 at 9:23 PM
    Heath423
    Heath423 New Member
    Heath
    Chattanooga, TN
    I purchased from Amazon. The brand was MostPlus. See if the link below works. I have a 2020 and they fit and worked no problem despite stating 2017 was the end year for compatibility. They have been on for little over a week and I am still pleased with them. They are manual fold which does not bother me. I park outside at the house anyway. The top mirror is large. The glass has a minor shake/vibration at 70mph but nothing bad my opinion, still very usable. The bottom mirror (blindspot) is adjustable horizontally. I could probably live happily with just the bottom mirror for day to day driving. I gained many features I did not have with the stock mirror on my SR5 package and all was plug n play. The only exception is the reverse/spot light. I have to pull those into the cab. Very easy to do and there are many videos to watch beforehand. I have not hooked up the wiring for the reverse/spot light yet, but hope to this week. I had to locate and order some T-taps.
    The only thing that I did not like at 1st notice was that the 2 mirrors are not at the same angle. However, after a quick google search about the matter, it appears that this is a normal thing with tow mirrors. Designed at different angles to allow the user to see out of them, since the driver is not in the middle of truck it makes the angle different. It does not bother me now that it is suppose to be "normal". I will look at some other vehicles in parking lots soon to see if theirs are similar. Anyways I hope this helps out some.
    https://www.amazon.com/MOSTPLUS-200..._6?dchild=1&keywords=tundra+tow+mirror&sr=8-6
  4. Nov 6, 2020 at 10:24 PM
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    Before and after measurements on my RC 3.5” lift kit: upgraded front coil over, upgraded rear V2 shocks, RC drop carrier bearing, Camburg 1.5” rear shackle lift, TRD front and rear sway bars. Detail pics tomorrow just got her cleaned up and too dark for pics
    Before: front 22” & rear 24”
    After: front 25.5” & rear 27.5”
    Increase of both 3.5”
    Last pic is the shop that did my instal posted on Instagram
  5. Nov 6, 2020 at 11:31 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Will post truck view tomorrow
  6. Nov 7, 2020 at 3:39 AM
    TheyCallMeBruce84
    TheyCallMeBruce84 New Member
    Bruce
    NC
    2020 Tundra Limited Barcelona Red
    I did something, but not expecting much from it...
    Cosmoblu, KC.Tundra, Ostrich and 7 others like this.
  7. Nov 7, 2020 at 4:30 AM
    Ltaco17
    Ltaco17 New Member
    NC
    2023 TRD Pro
    285/75/18 Falken Wildpeak R/T color matched handles and mirrors.
    It is not a normal 12v socket. It is threaded to keep from vibrating loose.
    biebs96[QUOTED] likes this.
  8. Nov 7, 2020 at 7:15 AM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    New rubbers and wheels
  9. Nov 7, 2020 at 8:26 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Cleaned the underside. One benefit of not living in the salt belt. Believe it or not, this truck is almost 3 years old, 72,000 miles and gets driven on construction sites daily; through mud, ditches, dirt & dust etc.
    PXL_20201107_160906527.jpg PXL_20201107_160853753.jpg PXL_20201107_160741903.jpg PXL_20201107_160637275.jpg PXL_20201107_161520124.jpg
  10. Nov 7, 2020 at 8:31 AM
    :eek::eek2: That looks amazing! I doubt mine will look that good in another couple years. Wyoming doesn't use much salt, but Utah does. Mag water on the dirt roads is rough too.
    ElNopal and Boerseun[QUOTED] like this.
  11. Nov 7, 2020 at 8:34 AM
    Wallygator
    That reminds me I need to get the Woolwax on the frame soon!
    Boerseun likes this.
  12. Nov 7, 2020 at 8:43 AM
    Stanky10
    Stanky10 New Member
    Stanky
    W Columbia SC
    2019 MGM Tundra TRD Sport
    3/1 leveling kit with 295/60/20 Nitto Ridge Grapplers, Go Rhino Dominator D6 step rails, Husky X-Act floor liners (front and back).
    What did you use to clean the under carriage
  13. Nov 7, 2020 at 8:53 AM
    Boerseun
    Ferdie
    Sarasota Florida
    Just a bucket with water, dollar store car wash soap and a few old rags. I have a bottle with cheap ceramic spray that I sprayed on afterwards, just to see how it works.
    GAknight, equin and GODZILLA like this.
  14. Nov 7, 2020 at 9:18 AM
    Dingpud
    Dingpud New Member
    2020 Tundra SR5 TRD
    Can you provide a link to where you got the mirrors? My old Titan had that style, and I think they are the only thing I miss on the new Tundra.
  15. Nov 7, 2020 at 9:23 AM
    Dingpud
    Dingpud New Member
    2020 Tundra SR5 TRD
    Bought the Diamondback HD.... Should arrive next week. Can't wait to put it on....will post pics.
    Looking for suggestions on running boards....looking for something tubular and sporty in black. Any recommendations?
    equin, BlueRibbon4x4 and Fotnot like this.
  16. Nov 7, 2020 at 9:39 AM
    RobertD
    Robert
    DFW, Texas
    Heath423 likes this.
  17. Nov 7, 2020 at 9:41 AM
    TH1776
    TH1776 New Member
    FL
    040 PRO
    What is the wait time on the Diamondback right now? Been having some thoughts about buying one myself.
  18. Nov 7, 2020 at 9:46 AM
    maxdriver
    maxdriver New Member
    ‘23 GRolla, sans ‘19 Tundra
    Nothing crazy but....took the TRD Sport stickers off the back of the truck, added a 13 inch shorty antennae, TRD cup holder inserts and added a leather steering wheel cover.
    GODZILLA likes this.
  19. Nov 7, 2020 at 9:46 AM
    Willard
    Willard New Member
    2024 F250
    Ordered mine September 11 and delivered mid October.
  20. Nov 7, 2020 at 10:29 AM
    Dingpud
    Dingpud New Member
    2020 Tundra SR5 TRD
    About 2 months. 2 guys at work have them, and they've spoken so highly of them I figured it was a good investment. Also, Diamondback has a good American company story, Penn State guys who saw a problem and designed a solution. I am anxiously awaiting it's arrival.
  21. Nov 7, 2020 at 10:29 AM
    Dingpud
    Dingpud New Member
    2020 Tundra SR5 TRD
    Heath423 and RobertD[QUOTED] like this.
  22. Nov 7, 2020 at 11:12 AM
    Installed my exhaust.
  23. Nov 7, 2020 at 11:27 AM
    Sweet! How do you like it so far? Did you install the resonator?
    Rica25 likes this.
  24. Nov 7, 2020 at 11:53 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    I think its supposed to go on the truck. Idk, I've never installed one yet :D
    TomC843 and WFD473 like this.
  25. Nov 7, 2020 at 12:01 PM
    Rely01
    Rely01 Window Shopping
    Eli
    SW Arkansas
    2016 Silver Sky SR5 CM
    Winner winner. Got a little muddy this morning, so when I got home I crawled under the truck and was able to see a small rub spot (less than a dime size) on the skid plate. Grabbed the handy ole channel locks and persuaded the skid plate inward. No more obnoxious and embarrassing rub noise.
    Thanks gents :hattip:
  26. Nov 7, 2020 at 12:49 PM
    Elfine
    Elfine Doing my best to break this beast
    Pensacola, FL
    2017 Quicksand Tundra TRD
    Datin Metal Fab 18" Bed Rack, ARB Diff Breather, SDHQ ABS Guards, RCI Engine/Transmission/Fuel Skid, ICON Stage 5, Rago Bed Stiffener/Ditch light brackets, ARB twin air compressor, 295/70R18 Cooper Evolution M/T, Spydertrax 1.25" spacers
    Finished up last night. I will have better pics after the trail ride my local Toyota group is doing tomorrow! 20201106_173801.jpg 20201106_173813.jpg
  27. Nov 7, 2020 at 12:58 PM
    RobertD
    Robert
    DFW, Texas
    Nothing crazy. But pics of installed front and rear sway bars and a nice clean truck!
    Only driven about 20 miles with them installed, but really happy with the result.
  28. Nov 7, 2020 at 1:37 PM
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    20201107_162335.jpg nothing exciting just gave her a bath
    Cosmoblu, RBB, KnoxHog22 and 20 others like this.
  29. Nov 7, 2020 at 1:49 PM
    I like it. Made a Dodge guy at the light look when I made the turn and got on it. :D I did not use the resonator.
  30. Nov 7, 2020 at 1:52 PM
    :thumbsup:
    :hattip:
    Rica25 likes this.
