6 speed to 8 speed conversion
Discussion in 'General Tundra Discussion' started by Michaelpotts787, Nov 6, 2020.
  1. Nov 6, 2020 at 6:12 AM
    Michaelpotts787
    Michaelpotts787 [OP] New Member
    Michael
    2014 Toyota Tundra
    LED Headlights
    Has anyone completed or contemplated swapping an 8 speed transmission from 2016 Land Cruiser into a 3rd Gen Tundra with a 6 Speed? What all would be involved? I'm sure it would bolt up and may need to lengthen the drives shaft but wasn't sure about any additional mods.
  2. Nov 6, 2020 at 7:49 AM
    rebmo
    rebmo 2020 Crewmax Limited 4wd Silver/Black
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    Mechanical fit might be the least of the concerns. Transmission electronic control compatibility might be the biggest hurdle.
  3. Nov 6, 2020 at 1:56 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I think the trans ECU is in the transmission... might not be an issue.. Same engine with same connector shouldn't be an issue...
    Example my celica has 2 engine variations with 2 different automatic transmissions which are shared with the Corolla, Matrix and Pontiac Vibe with 1 that cant be crossed over but the manuals can be cross platformed..
    Michaelpotts787[OP] and Rica25 like this.
  4. Nov 6, 2020 at 2:20 PM
    rebmo
    Rural SE Wisconsin
    As long as the TCM firmware is compatible with the vehicle weight, differential ratios, tow haul, etc..
  5. Nov 6, 2020 at 7:14 PM
    blackdemon_tt
    Yes, I agree odds are they may be very similar in weight and gearing as its is easier to do 1 math equation than 5.... mass production advantage, atleast that's what I would think with cost savings and parts bin availability.. 3.90:1 gearing on the 8spd attached some more info for compare and contrast..
    http://www.new-cars.com/2016/toyota/specs/land-cruiser.html
    Michaelpotts787[OP] likes this.
  6. Nov 6, 2020 at 10:59 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I’m sure it can be done, I mean you’ve got guys throwing new 3.5l Toyota motors in 2nd gen mr2s with some wiring.
    you will likely need a land cruiser ecu (I’m pretty sure the trans control on the tundra is in the ecu, not sure on the land cruiser but likely the same) and body side of the ECU will need to be re pinned likely. Not a super hard task, but very time consuming, you will also likely need a land cruiser engine/trans harness.
    pickeledpigsfeet likes this.
  7. Nov 6, 2020 at 11:05 PM
    Michaelpotts787
    Michael
    2014 Toyota Tundra
    LED Headlights
    Thanks for everyone's help
