What's needed to tow this 4700lb Rambler 21ft?
Discussion in 'Towing & Hauling' started by Q's-TTS, Nov 6, 2020.
  1. Nov 6, 2020 at 7:02 AM
    Q's-TTS
    Q's-TTS [OP] New Member
    Greatings from Texas, I just bought a 17 Tundra TTS with a 4.6, I know, I know, It fit our budget but now Im second guessing the towing. I believe the TTS is rated for 7k tow cap. We just bought a 1965 Holiday Rambler 21ft with a dry weight of 4700. Do I need a torsion or sway bar? What about Airshocks? I never even considered those and know Im screwed on MPG! Please Help!13745.jpg IMG_20201024_181838083_HDR.jpg
    ATHiker likes this.
  2. Nov 6, 2020 at 7:09 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Welcome!
    Check the drivers side door jam for the actual tow rating for your truck.
    Weight distribution hitch with a sway bar is a must.
  3. Nov 6, 2020 at 7:29 AM
    Q's-TTS
    thanks, should I get Air shocks? how do i keep the MPG down while towing?
  4. Nov 6, 2020 at 7:37 AM
    18" TRD Off Road Wheels
    I haven't heard of "air shocks" before. Do you mean Air Bags? If that is what you mean then you should know air bags do nothing except help with sag. They do not increase your tow or payload ratings.
    EDIT: Air shocks do the same thing as air bags, and so the above still applies.
    I assume you also meant that you want to keep the MPG up, and again, there is little you can do for that. When you tow, you will pay for it at the pump. There isn't much you can do to alter this besides driving slower.
    I would recommend you check out this thread. Lots of vids on safe towing and how to make sure you aren't going beyond your truck's ratings. https://www.tundras.com/threads/tow-ratings-guide-how-to-be-safe.39211/
    and Welcome from Wyoming.
  5. Nov 6, 2020 at 9:05 AM
    Grumpy Uncle
    Pat
    CO
    They exist
    https://www.shockwarehouse.com/site/mon_air.cfm
    GODZILLA[QUOTED] likes this.
  6. Nov 6, 2020 at 9:08 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Cpl_Punishment and GODZILLA like this.
  7. Nov 6, 2020 at 9:09 AM
    That's wild. Learn something new everyday. Thanks for sharing the info.
    Looks like it is essentially an airbag built into a shock? If they are, I would guess that my statement for airbags would still apply, but I cannot be sure because I didn't even know these existed 20 minutes ago.
  8. Nov 6, 2020 at 9:13 AM
    Grumpy Uncle
    Pat
    CO
    Been around since my Dad was a kid in some form or another.
  9. Nov 6, 2020 at 10:15 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Check page 167 in your owner manual. Trailer Weight Rating (TWR) for CrewMax with 4.6L 2WD is 6700 pounds, 4WD is 6400 pounds. There is a whole list of ratings to confirm that you meet such as tongue weight, cargo load vs vehicle weight rating, etc.
    What's your plan for transmission fluid cooling...that's our second favorite subject here right after what brand of motor oil and filters to use. :D
    Cpl_Punishment likes this.
  10. Nov 6, 2020 at 10:22 AM
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Gabriel Hi-Jackers. Everybody that was somebody ran those back in the mid/late 70's.
    EDIT:
    OH! That trailer looks sweet OP! Would love to see some pics of the inside.
  11. Nov 6, 2020 at 11:01 AM
    Grumpy Uncle
    Pat
    CO
    Yep, the old school hot rodders like my dad and brother used them.
    Taco-Blender[QUOTED] likes this.
  12. Nov 6, 2020 at 11:14 AM
    Q's-TTS
    well JohnLakeman thanks for your input...your right and it is 6700 lbs and because i just bought the truck so im not sure what kind of oil they put in it. When it comes to a trans cooler im open for suggestions.
  13. Nov 6, 2020 at 11:46 AM
    Q's-TTS
    i put them on my Ford Maveric, man i miss that car!
  14. Nov 6, 2020 at 11:50 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I thought he only wanted to move it 21 feet :rofl:was gonna say just push it.
    GODZILLA likes this.
  15. Nov 6, 2020 at 11:52 AM
    Darkness[QUOTED] likes this.
  16. Nov 6, 2020 at 12:01 PM
    Q's-TTS
    at this point i think ill be better off
  17. Nov 6, 2020 at 12:07 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    I had one too. I beat the crap out of it and it held up. I did bust one of the rear shock mounts from the body. :p
  18. Nov 6, 2020 at 12:08 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
  19. Nov 6, 2020 at 12:30 PM
    Wallygator
    Nice camper!
  20. Nov 6, 2020 at 12:55 PM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Bilstein 5100 2.3/1.5, TRD sway bars ft/rr, Cooper Tires Discoverer AT3 XLT 295.70.18, Vision Manx 2 18x9 +12, APS side armor steps, TRD-Pro Grill and Bulge, de-chromed, blackout emblems, OEM mirror caps and flares, TRD shift knob, Leather wrapped steering wheel, All weather mats
    Air shocks is still widely used in different applications. Rancho, Monroe and others are still makes them mainly for domestic vehicles.
  21. Nov 6, 2020 at 1:01 PM
    I see that now. It appears they function is the same as the airbags, so they will help with sag and maybe plush the ride a bit.
    The only real concern I see for your truck would be the payload rating. It's not hard to chew through it on a Tundra.
  22. Nov 6, 2020 at 1:04 PM
    pilsnerpopper
    pilsnerpopper New Member
    2010 Tundra 5.7 4x4 Double Cab
    Beautiful trailer, would love to see more pics.
    As far as towing, never assume you know the dry/wet weight without getting it on a scale. Weigh her empty and then load up everything you are going to bring and weigh it again. Adjust gear as needed. Make sure your brakes are good on both vehicles. I like to keep my trailer under 80% of vehicle weight if I am towing further than a few dozen miles, but to each their own. Going light on the right pedal will help keep you safe and help with the mpg.
    Cpl_Punishment, Wallygator and ezdog like this.
  23. Nov 6, 2020 at 1:38 PM
    oldscout1001
    oldscout1001 New Member
    2008 Radiant Red Toyota Double Cab SR5 TRD Off Road
    Back in the 80's I used air shocks to "jack up" the back of my Cutlass to fit the 60s under it. Real bad ass look. :)
  24. Nov 6, 2020 at 4:34 PM
    JohnLakeman
    Keep in mind that vehicle load capacity minus passengers and cargo will determine your allowable tongue weight. The vehicle load capacity must be adjusted for the weight of any added options and modifications. The placard on the driver-side door jamb provides an "adjusted" vehicle load capacity for any factory or port-added options or modifications. If you add anything else you should keep track as part of your "cargo".
    I'm sure the oil they put in your truck is fine. That was an inside joke on us.
    Stay tuned for 4.6L specific transmission cooler thoughts.
    And, oh yeah, Welcome from the Texas Hill Country.
  25. Nov 6, 2020 at 5:15 PM
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    Those Holidays are all aluminum framed too and I bet your weight estimate is off but like was said above you will not really know until you weigh it yourself and thats where you need to start.
    Cool Trailer!
    Wallygator likes this.
  26. Nov 6, 2020 at 6:01 PM
    TundraBike&SkiGuy
    TundraBike&SkiGuy So I got that goin' for me
    Jeff
    Minneapolis, MN
    2020 Quicksand Tundra
    x2, let's see some inside pics
