Crunched skidplate
Discussion in '2.5 Gen Tundras (2014-2021)' started by DCLarston13, Nov 5, 2020.
  1. Nov 5, 2020 at 1:58 PM
    DCLarston13
    DCLarston13 [OP] New Member
    2020 Tundra Magnetic Gray TSS
    I saw something hanging down from my truck, it turned out to be a rock sticking through a hole in the front skid plate. Upon closer examination I noticed the skid plate is bent in a few places. Funny thing is that I have only some light wheeling with it in Colorado and I don't remember hitting anything hard enough to do that. There was one drop of about 2 feet that I heard some scraping. Anyway I guess it's time for a replacement. Suggestions, RCI? TRD pro? any others?
  2. Nov 5, 2020 at 2:00 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
  3. Nov 5, 2020 at 2:37 PM
    DCLarston13
    Thanks for the link, Budbilt seems a pretty good option, as does the RCI. TRD seems overpriced.
  4. Nov 5, 2020 at 3:16 PM
  5. Nov 5, 2020 at 3:41 PM
    Piney
    Piney New Member
    South Jersey Pine Barrens
    2020 MGM TRD Pro
    I guess the skid plate did its job and took one for the team.
  6. Nov 5, 2020 at 5:18 PM
    Vizsla
    Vizsla 2 = 2.5
    I had RCI engine and KW transmission skid glued together, but the engine skid gave up. Skids made at local fab shop for a little cheaper than buying the available ones. Very happy with them, but no oil filter door, have to remove skid for oil change.
    chickunfut, Elfine, Skew12 and 2 others like this.
  7. Nov 6, 2020 at 3:06 PM
    DCLarston13
    That is pretty slick Dave. I cant imagine that being cheaper than RCI
  8. Nov 6, 2020 at 3:22 PM
    Jhawk87373
    Jhawk87373 New Member
    Louisiana
    2010 tundra Blue, crewmax, 4x4
    is that the aluminum ones that caved in or the 10gauge steel ones?
  9. Nov 7, 2020 at 6:13 PM
    Calebrichardson85
    Calebrichardson85 New Member
    Stock skids barely count as skids IMO, the metal is just to thin for any little bit of use and abuse off-road. Even tho the TRD Pro skid looks great under the truck, from what I’ve read on the forums, you get a better skid from RCI, Budbuilt, or Victory 4x4.
  10. Nov 7, 2020 at 9:04 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    How much were these and who did the work? They look amazing!
