Modifying seat height
Discussion in '1st Gen Tundras (2000-2006)' started by RangerDanger, Oct 22, 2020.
  1. Oct 22, 2020 at 9:43 AM
    RangerDanger
    RangerDanger [OP] New Member
    2006 Tundra Access Cab
    New to site. Just bought a 2006 Tundra Access Cab with 97K miles (Unicorn). The only thing I am not thrilled about is the seat to floor height. Unlike American 1/2 tons, this riding position has your feet further out in front of you; more like a car or Tacoma/Ranger. Am I the only one who doesn't like this? Has anyone modified Seats to lift them a couple inches? Maybe spacers between rails and seats?
  2. Oct 22, 2020 at 9:54 AM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    If you moved them a couple inches I could see a problem with headroom.
    NewImprovedRon likes this.
  3. Oct 22, 2020 at 10:22 AM
    RangerDanger
    Maybe for a taller "new" owner but at 5'8" I have some room to spare. Even 1" higher may be enough.
  4. Oct 22, 2020 at 11:21 AM
    Kongap
    Kongap New Member
    2004 SR5 DC
    IMO, seems sketchy placing a spacer there. I mean sure it’d probably take a lot of force to sheer a quality bolt if it were in an accident, but not something I’d personally risk. Then again, others have suggested throwing washers under the front of the rails to help with comfort.
    Why not just put in a booster seat?:D
    Rex Kramer, bmf4069 and Black Wolf like this.
  5. Oct 22, 2020 at 11:25 AM
    RangerDanger
    Maybe a phone book?
    Baja Mike, flyfisher, bmf4069 and 4 others like this.
  6. Oct 22, 2020 at 11:32 AM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Welcome to the forum! as for your question, get over it! Lol
  7. Oct 22, 2020 at 11:33 AM
    RangerDanger
    Over it. Move'n on.
    Stumplifter, Black Wolf and Pucks18 like this.
  8. Oct 22, 2020 at 12:15 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I'm 6'3 and haven't noticed that the seat is low, but then again before toyota trucks, I drove a 2wd S-10. The padding may be worn out.
  9. Oct 22, 2020 at 12:50 PM
    RangerDanger
    I think a back to back comparison between sitting in a Silverado and Tundra will demonstrate the difference in sitting position. It kinda reminds me of my 2000 Ranger. People complain about the Tacoma for the same reason.
    Not a deal breaker by any stretch and a cushion sold on A....N should do the trick without major mods.
  10. Oct 22, 2020 at 1:54 PM
    Professional Hand Model
    Fred
    Hand Protectors
    I did put a washer under the front bolts to give the pan of the seat more of an angle. The two thick washers effectively raised the front about a 1/4”. Doesn’t seem like much, but thats what she said. :help:
    Actually, it makes for a better comfort level. A nestlé feeling.
    Stumplifter and bmf4069 like this.
  11. Oct 22, 2020 at 5:11 PM
    RangerDanger
  12. Oct 22, 2020 at 5:17 PM
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    I could not live with mine either for the same reason and so I got some hard rubber spring spacers,drilled a hole in the center and got some grade 8 bolts to make up the extra length and bolted those bitches in between the seat and tracks in the back.
    To make the front work I took small lengths of Strut and Jam Nuts for Strut and raised the front too.
    I have over 100K like this on my '01 and will only remove it all i9f I actually sell the truck which does not look likely these days though it was what I have planned too.
    I dont have and can not get pics right now but it is a simple fix and when raising the seat a small difference feels huge every time I do this!
    I think I have duplicated this 5 or 6 times in different vehicles an nit always freaks me out how much even small differences make in comfort.
  13. Oct 22, 2020 at 6:03 PM
    RangerDanger
    Thanks for the input. I knew I couldn't be the only one who had issues with this. I will probably try a pad under a seat cover first and if that doesn't do the trick will bite the bullet and mod it.
  14. Oct 22, 2020 at 9:51 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    Very easy to add a few flat washers under the rear bracket for a little lift. I couldn't find a phone book! Take a look at the 5th and 6th pics in this post for an example... https://www.tundras.com/threads/wha...t-gen-tundra-today.2558/page-658#post-1795929
  15. Oct 23, 2020 at 6:17 AM
    RangerDanger
    Steve,
    Thanks. That is exactly what I had in mind except at all 4 corners.
    Lil Steve likes this.
  16. Oct 23, 2020 at 1:13 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    Lookout Mtn Georgia
    Guess I'm spoiled; I just push a button...
  17. Oct 23, 2020 at 1:31 PM
    ezdog
    ezdog New Member
    Gateway To The West
    The problem or challenge there is that the fronts are in a different plane than the rears and require different solutions.
    So something simple works in the rear but not in the front of the seat.
  18. Oct 23, 2020 at 6:21 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I used aluminum 1 inch blocks on the two rear mounting bolts of my Ford f150 seats. With my short leg syndrome, it changed the angle of the seat and made it more comfortable.
  19. Oct 24, 2020 at 5:41 AM
    Fred
    Hand Protectors
    Stumplifter likes this.
  20. Nov 2, 2020 at 8:00 PM
    Suprafantx
    Suprafantx New Member
    2020 4X4 White Tundra TSS
    I raised the back side of the seat about 1.5 inches. I uses like 20 washers on each side. For the bolts, I used 2 M10 1.25 60 mm bolts. I will take pictures when I have time.
  21. Nov 3, 2020 at 11:47 AM
    Rdway60
    Rdway60 New Member
    2005 Bluesteel Metalic Tundra
    I've got an 05 AC with the 60/40 cloth seating and am having the same problem with seat height. The PO was an older heavy set fella and I'm pretty sure it is a breakdown of the seat foam. I compared the 60 to the 40 visually and by actually sitting in each and i'm seeing a 1 to 2 inch difference. I can also tell in my lumbar area if I raise my bod up about 1 or 2 inches I hit my sweet spot. I contacted a Toyo dealer for shits/giggles to price new driver side upper/lower foam. 1 was 200.00 and the other was 300ish. Their system showed 1 upper foam piece and 2 of the lower foam pieces available.......in the countryo_O. Needless to say I'm searching my area for a good upholstery shop. I love my truck...but I loath that damn foam broke cloth seat. Feels like my ass is trapped in memory foam lol. Anybody with upholstery solutions?
  22. Nov 3, 2020 at 12:18 PM
    ezdog
    ezdog New Member
    Gateway To The West
    Ok I have been out if town.
    You cant believe how much different it feels with just this little height!
    assassin10000 likes this.
  23. Nov 3, 2020 at 12:35 PM
    Rdway60
    Rdway60 New Member
    Great pics! I'll study them closer when i have time. Night shift bed callszzzz. What was condition of your foam? Seat covering?
  24. Nov 3, 2020 at 5:00 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Just an FYI, I would upgrade the rear bolts to at least grade 10.9 like your fronts. The rears appear to be 8.8, which is equivalent to standard grade 5 bolts.
  25. Nov 3, 2020 at 5:31 PM
    ezdog
    ezdog New Member
    Gateway To The West
    I have run these for 10 years as they were the best I could find at the time but your point is well taken.
  26. Nov 4, 2020 at 6:53 AM
    While the seating position may be more to your liking, I would be concerned about crash worthiness. The modifications made look they wouldn't survive a major crash.
    AggiePhil likes this.
  27. Nov 4, 2020 at 7:05 AM
    Danny502
    Danny502 New Member
    Danny
  28. Nov 4, 2020 at 7:07 AM
    Those are for 2007 and up. 2nd and Turd Gen
  29. Nov 4, 2020 at 8:38 AM
    Fred
    Hand Protectors
    This country is splitting up into short versus tall seating. We need to eat more veggies to save us!
  30. Nov 4, 2020 at 6:58 PM
    artsr2002
    'Yonder
    I have short leg syndrome. Had to do the same with the seat on my Ford. I used aluminum block 1 inch thick to make some spacers for the rear seat bolts.
