High RPM at start up
Discussion in '1st Gen Tundras (2000-2006)' started by Stumplifter, Nov 4, 2020.
  1. Nov 4, 2020 at 1:26 PM
    Stumplifter
    Stumplifter [OP] New Member
    Milwaukee, WI
    2006 Tundra Limited Double Cab
    None.
    Still relatively new with this truck and trying to sort things out.
    She starts at a high RPM which will drop after about a minute of idle, which I understand to be considered normal. Question... when the RPM drops what is the typical range? Just under 1000 is what I see.
    Maybe related... I am averaging 14 mpg even on long freeway runs... normal? Anything I could do to improve it?
  2. Nov 4, 2020 at 1:51 PM
    How high on startup? Clean the throttle body plate.
  3. Nov 4, 2020 at 2:03 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    There may be a decal on the underside of the hood or in the engine compartment somewhere that may state the warm idle RPM. Probably 750 ± 50. I'm guessing that when it first fires up it will get to somewhere around 1500 or fewer RPMs then drop to 1200 RPMs, then decrease as it warms? If so, that's pretty par.
  4. Nov 4, 2020 at 2:06 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    600-1000 is the typical idle range, once warmed up. It will fluctuate depending on if A/C is on or not.
  5. Nov 4, 2020 at 2:39 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Engine at full operational temp:
    1) 590-600 rpm in D with foot on brake in stopped position.
    2) 725-750 rpm in P at idle.
  6. Nov 4, 2020 at 9:28 PM
    bassman417
    bassman417 "Tundra Time". My favorite time of day...
    Paul
    Las Vegas
    2004 DC 2wd Imperial Jade
    14 mpg is about right. The best way to improve Mpg is to modify your driving habits.
    After reading this post on tundrasolutions I was able to push MPG about 1-2 mpg.I also use fuelly to track mpg.
  7. Nov 5, 2020 at 4:20 AM
    Fred
    Hand Protectors
    I’m getting about 17-18mpg on long highway trips.
    13-14 in the city.
  8. Nov 5, 2020 at 4:57 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Clean the MAF and throttle body.
  9. Nov 5, 2020 at 5:42 AM
    Piney
    Piney New Member
    South Jersey Pine Barrens
    2020 MGM TRD Pro
    Sounds normal. My truck does the same. On cold mornings, it will idle around 1500 for a minute before dropping to just below 1000.
  10. Nov 5, 2020 at 5:47 AM
    lewi3069
    lewi3069 New Member
    2017 Crew Max 4x4 Sunset Bronze
    X2
  11. Nov 5, 2020 at 7:49 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Double cabs are always around 3 mpg shy of what access cabs can get in real life. 14mpg is spot on from what others have reported for a double cab.
  12. Nov 5, 2020 at 7:58 AM
    Casper421
    In the woods
    06 DC
    I agree. 15mpg stock and 14mpg after lift/tires. But I drive like I’m 80.
  13. Nov 5, 2020 at 9:21 AM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    2007 Tundra CrewMax 4x4 5.7L V8
    Dead on.. this is what I observe on my LC and Tundra.. both having same engine.
  14. Nov 5, 2020 at 12:08 PM
    chester
    chester best member
    2005 Double Cab SR5
    That's surprising. I just Googled the differences and found two things:
    The DC is 510 lbs heavier than the AC
    The DC is 3.3 inches taller than the AC
    That would explain it. I'm surprised at both these numbers though. Are they correct?
  15. Nov 5, 2020 at 12:22 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    @chester
    Yeah that sounds right. DC is taller at the hood, the cab, and the bed sides are taller. They stretched the truck tall-ways so it would look more proportional from the length change.
  16. Nov 5, 2020 at 1:23 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    I recall the DC also being wider than the AC.
  17. Nov 5, 2020 at 1:28 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yup, its a bit bigger every way you look at it on the outside.
  18. Nov 5, 2020 at 1:47 PM
    Fred
    Hand Protectors
    I wonder how many of those extra 40 horses get cancelled out due to the 510 extra pounds?
  19. Nov 5, 2020 at 2:53 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    Depends if you have TRD stickers or not.
  20. Nov 5, 2020 at 3:25 PM
    bassman417
    Paul
    Las Vegas
    Bigger is always better. At least thats what she told me......
    Darkness[QUOTED] likes this.
  21. Nov 5, 2020 at 3:27 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    01 AC to 06 DC I can definitely tell the 06 has more power, but part of that could be the 5 speed transmission. Maybe it would be different going from an 06 AC to DC.
