Rim Question
Discussion in 'Wheels & Tires' started by intr3nsic, Nov 4, 2020.
  1. Nov 4, 2020 at 12:18 PM
    intr3nsic
    intr3nsic [OP] New Member
    2010 Tundra, will they fit my 2016 Tundra? I am assuming they are 5x150mm and from what I have read anything from 07 and up should work? I am just looking for someone with more experience with them to verify for me. Thank you all.
    Rex Kramer likes this.
  2. Nov 4, 2020 at 12:21 PM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Confirmed!
  3. Nov 4, 2020 at 12:22 PM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    yes they will fit
  4. Nov 7, 2020 at 4:48 PM
    intr3nsic
    Will the lug nuts from the 2016 alloy rims be fine on the 2010 rims ?
  5. Nov 7, 2020 at 5:59 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    They should. I went the other way on my prior ‘08 - I put ‘15 TRD alloy rims on it and reused the lug nuts.
  6. Nov 8, 2020 at 7:11 PM
    Mxvet90
    Mxvet90 New Member
    Should fit
