Towing a clam shell snowmobile trailer
Discussion in 'Towing & Hauling' started by Bammer, Nov 4, 2020.
  1. Nov 4, 2020 at 3:39 AM
    Bammer
    Bammer [OP] I'm disinclined to acquiesce your request.
    Monroe, CT
    First winter towing my sled trailer (if it snows). So my question is, I'll be towing 2500 pounds or so, do I need tow/haul? Would it be better to leave in S4? The weight isn't there but the wind drag is ……………….. well like my wife says, towing a parachute. Any insight from those who have one? TY
  2. Nov 4, 2020 at 4:01 AM
    pro2amendment
    pro2amendment Member
    Indiana
    2018 Tundra: 5.7L Flex, MGM Gray DC, Offroad pkg
    Bullet liner
    I find tow haul to be noticeable even at that weight or in my case even around 2000. I use it on long trips. I left it in D. Maybe I should have used S4 but was less familiar. Since then I use S4 also but those have been much heavier and shorter trips.
    Bammer[OP] likes this.
  3. Nov 4, 2020 at 5:14 AM
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    Why dont you wait and see how it feels for yourself?
    It is not a subtle difference really between T/H and I will bet you will figure it out quickly.
    I doubt that you will "Need" to use much special consideration for the Drag but sometimes you might and others you ,ight not depending on the actual conditions on the ground at the time.
    The Weight should not be a problem but the Wind can be amazing too!
    If you find that it is hunting gears too much try T/H and see the difference.
  4. Nov 4, 2020 at 5:57 AM
    41bigdawg
    41bigdawg Let the BIG DAWG Eat
    Robert
    Tennessee
    2013 Tundra DC 5.7
    Magnum front, Iron Cross rear bumpers, SB Cold air intake and Gibson Metal Mulisha exhaust, Fender flares, Tow mirrors, 18" Outlaw wheels, 12k Smitty X2O winch, Tech 12v auto start, Firestone Air Bags, Pedal Commander, Devil Horns, etc...
    Tow/Haul and put it in S4 or 5 with that weight. In my experience it makes all the difference in the world. I just did a 1400 mile trip towing my bikes (about the same weight), I played around with T/H and S or D a lot and found that T/H and S4 and 5 works the best. Just give it a try and see what works the best for you.
    Bammer[OP] and Cpl_Punishment like this.
