  1. Oct 31, 2020 at 8:56 AM
    #8881
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    I’m really happy with my Neico set, and my dad has Tekton and they’re pretty much identical.
    this is the set i have. You have no idea how nice it is to have 2 of every size for those bolt/nuts that you need both ends.
    https://www.amazon.com/Neiko-Shallo...ocket+set&qid=1604159716&sprefix=neiko&sr=8-7
    Festerw likes this.
  2. Oct 31, 2020 at 9:15 AM
    #8882
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    FirstGenVol likes this.
  3. Oct 31, 2020 at 9:30 AM
    #8883
    MS22
    MS22 New Member
    02 Tundra 4x4
    Gave me the chills too but because I hate heights.
    jImmegart[QUOTED] likes this.
  4. Oct 31, 2020 at 10:01 AM
    #8884
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads
    bmf4069 and speedtre like this.
  5. Oct 31, 2020 at 1:01 PM
    #8885
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Does anyone know if I can apply a grease coating or fluid flim coating over my por 15 coating on my rear axle cover? I want to keep as much moisture out as possible but I don't know if that would do more damage
  6. Oct 31, 2020 at 2:33 PM
    #8886
    Professional Hand Model
    Fred
    Hand Protectors
  7. Oct 31, 2020 at 2:34 PM
    #8887
    Fred
    Hand Protectors
    bmf4069 likes this.
  8. Oct 31, 2020 at 3:59 PM
    #8888
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
  9. Oct 31, 2020 at 4:45 PM
    #8889
    ktundra
    ktundra rust be damned
    Lex
    NJ
    06 Tundra DC Limited 4WD
    Bilstein 5100
    It has been raining all week. Not much work done on truck.
    Finally got around to replacing my 14 year old water heater. Seems that corrosion is a common theme around here... lol.
    Upgraded from 40 gal to 50 gal. Sweated a few couplings (my first time). The rest are sharkbite. Also added a pressure expansion tank, never had one before. This is typically recommended to relieve any unnecessary pressure on the pipes when the hot water in the tank expands. Apparently, required by code these days.
    Prob saved about $600 in installation costs and definitely sidestepped the usual goofy/shoddy work that most contractors do.
    chrisb, bmf4069, shifty` and 7 others like this.
  10. Oct 31, 2020 at 6:21 PM
    #8890
    speedtre
    speedtre New Member
    Inland Northwest
    Happy Halloween...
    bmf4069, NUDRAT[OP], Darkness and 3 others like this.
  11. Oct 31, 2020 at 6:43 PM
    #8891
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    If I didn’t work through Halloween I was going to spin the Mercedes around, put a skeleton in it and have the headlights glow a dim red... but oh well. Work still has to be done
    bmf4069, shifty`, ktundra and 2 others like this.
  12. Oct 31, 2020 at 7:28 PM
    #8892
    lsaami
    lsaami Let ‘er buck
    Minnesota
    that kit just keeps going down in price. I'm so tempted...
    TomGreen and jImmegart[QUOTED] like this.
  13. Oct 31, 2020 at 10:54 PM
    #8893
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Congrats on making the decision to join the club.
    My three pieces of advice from my experience is this.
    1. Find a store that has display models that you can feel, and touch. Figure out what feels right in your hand.
    2. Buy an impact wrench, not an impact driver. For truck work. Impact drivers are the ¼" hex units. Not the socket units, but you can get an adapter, but I've found those break when you use them like I do. Which is why I bought the wrench.
    3. Buy a "kit" that includes batteries, and a charger.
    Here is a link to the impact wrench I used on your bumper.
    Link.
    Heres a link to the "kit."
    Link
    Heres a link to a charger only.
    Link.
    Heres a link to ONE battery.
    Link.
    I could do the math for you, but I don't have enough fingers, or toes for that. #KentuckyEdumacation
  14. Nov 1, 2020 at 1:08 AM
    #8894
    jImmegart
    Jonah
    California
    bmf4069 and TomGreen like this.
  15. Nov 1, 2020 at 1:39 AM
    #8895
    empty_lord
    05 rollover special
    id run everything but the turbo itself. no way id run a turbo from china..
  16. Nov 1, 2020 at 1:58 AM
    #8896
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Any tips for plasti-dip in a can?
    I know some of you all have used that before, but can't remember who.
    Got a little house project to work on, and depending on how that goes possibly a truck project.
  17. Nov 1, 2020 at 4:07 AM
    #8897
    ktundra
    Lex
    NJ
    Bilstein 5100
    Apply by using several coats. Use thin coats.
    I’ve used it mostly for blacking out chrome trim and badges.
    how big a surface are you painting?
  18. Nov 1, 2020 at 4:34 AM
    #8898
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Thanks!
    Just a small little thing. About 8 inches by 8 inches. I could use paint, but wanted practice with plasti-dip.
    Thinking of doing my grille
  19. Nov 1, 2020 at 5:26 AM
    #8899
    TomGreen
    TomGreen New Member
    Do it
    bmf4069 and jImmegart[QUOTED] like this.
  20. Nov 1, 2020 at 5:27 AM
    #8900
    TomGreen
    TomGreen New Member
    Do it. For science.
    bmf4069, FrenchToasty and jImmegart like this.
  21. Nov 1, 2020 at 10:06 AM
    #8901
    Fred
    Hand Protectors
    @empty_lord
    Which 86 Model Radio do you recco? I have XM and need that capability. Will run microphone for phone shtuff.
    Plug and play?
  22. Nov 1, 2020 at 10:08 AM
    #8902
    empty_lord
    05 rollover special
    You need to find a newer radio bezel from an 03-04. The radio doesn’t do XM because it’s meant for cellphones to use the XM. But I can see if they make the extension module
  23. Nov 1, 2020 at 10:46 AM
    #8903
    Fred
    Hand Protectors
    That new bezel requirement is a deal breaker. Thank you for the reminder.
    empty_lord[QUOTED] likes this.
  24. Nov 1, 2020 at 12:19 PM
    #8904
    ktundra
    Lex
    NJ
    Bilstein 5100
    Most cheap tools at Harbor Freight are one-time use disposable tools.
    That said, there are some gems in their collection. The high end floor jacks are one.
    I think these are fantastic at $24. I have a 1/2 drive impact gun. Definitely the recommended size as others have said. The etched size markings on the sockets are immensely helpful. I never had a set with them until I got these.
  25. Nov 1, 2020 at 12:29 PM
    #8905
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I have actually been using harbor freight impact sockets for a while now. I would like to replace them with something nicer, but until they fail they will stay in the chest.
    chrisb, MS22 and FrenchToasty like this.
  26. Nov 1, 2020 at 2:03 PM
    #8906
    Thanks guys. Is there a benefit to buying the bare tool and then piecing it together? Seems the lowest the bare tool got down to last black friday was only $25 less than it is now, give or take.
  27. Nov 1, 2020 at 2:16 PM
    #8907
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Only if you already have the right battery and charger. If you don't yet, then get the combo kit.
    I have 3 M18 batteries and 2 chargers so the next few M18 tools I buy will be tool only.
    bmf4069 and Tundra2 like this.
  28. Nov 1, 2020 at 2:20 PM
    #8908
    That makes sense. I just read the Milwaukee Impact is made in China and that is extremely disappointing. I'm not worried about the quality but I'm trying really hard to limit what I purchase from those assholes. I wish we could slowly pull back what we make there. The DeWalt Impact is made in the USA but it doesn't have as much power. I'll probably have to break my own rule since the Milwaukee have such outstanding reviews.
    Darkness[QUOTED] likes this.
  29. Nov 1, 2020 at 2:29 PM
    #8909
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I have heard plenty of people prefer miliwaukee over Dewalt, but I have put a few Dewalt tools through absolute hell and they still work. It isn't a bad option.
    My Dewalt corded reciprocating saw has seriously been submerged in water twice, rained on a few times, and used to cut everything you can imagine. 14 years old and still works fine.
    Or go miliwaukee and pretend you bought it pre-covid.
  30. Nov 1, 2020 at 2:49 PM
    #8910
    Festerw
    Festerw New Member
    04 Tundra DC
    Depends which rating/model you look at they're Milwaukee 750/Dewalt 700 max M1100/D1200 breakaway.
    I don't think you can go wrong with either.
    speedtre and FirstGenVol[QUOTED] like this.
