Tacoma wheels on tundra
Discussion in '1st Gen Tundras (2000-2006)' started by watatoo, Oct 31, 2020.
  1. Oct 31, 2020 at 12:47 PM
    watatoo
    watatoo [OP] New Member
    Derek
    Toyo peeps,
    I am a total newb to wheels so here we go. Just ordered a pair of OEM steel wheels for my 03 tundra. They are 16x7 wheels. They used tire shop down the street put them on but had to add some "studs" to get the lugs to tighten down. This mean I need to get some offset spacers to flush the lugs out? Or these wheels just won't work? Photos attached.
    Any advice would be much appreciated.
    Derek
  2. Oct 31, 2020 at 3:23 PM
    llessur2
    llessur2 New Member
    2005 Double Cab TRD off road
    I may be wrong, but I think a different style( not mushroom) lug nut will fix that
    speedtre likes this.
  3. Oct 31, 2020 at 3:29 PM
    watatoo
    Derek
    That's the rabbit hole I've been going down the last hour. It doesn't look like I have and rubbing issues with the control arm but trying to figure out the OEM lug shape and size for the steelies.
  4. Oct 31, 2020 at 3:37 PM
    andnyleswillriot
    andnyleswillriot Not Remote Working
    Breckenridge, CO
    2016 DC w/ Black Topo Topper
    Toytec 3" w/2.5 Coilovers. SPC UCA's. Method Roost Bronze Wheels. 35" BFG KO2's. SPC Upper Control Arms. 2019+ TRD Pro Grill. LED headlight bulbs. 2020 OEM LED Fog lights. Tech12volts Remote Start. MobArmor Magnetic Phone Mount. Topo Topper.
    Just get some black splined lugs and be done with it.
  5. Nov 1, 2020 at 3:44 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Are the studs from the axle bottoming out on the cap of the nut?:confused:
  6. Nov 1, 2020 at 5:21 AM
    lamboboy732
    lamboboy732 New Member
    Those are your oe lug nuts nothing there seems to be added. With the steel wheels there is no pocket for them to sink into like on the alloys so you see the whole lugnut. As long as the seats match the rim which they should it's fine just looks a bit odd. Same thing happens when you use the factory spare tire.
  7. Nov 1, 2020 at 6:52 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    technically you should be using acorn style lugs with steel wheels.. but the shank style ones are designed to be used with steel too for the spare tire... sooo yea?
    arbucklejon1 likes this.
  8. Nov 1, 2020 at 6:54 PM
    lamboboy732
    Yea, the oe lugs still have the acorn seat on them. They just look funny because of the extended base for the alloys.
  9. Nov 2, 2020 at 10:56 AM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    These are the lug nuts that held my stock steel wheels on. When I picked up a set of starfish wheels locally, the guy included the lugs nuts you have which are meant for the aluminum Toyota wheels.
  10. Nov 2, 2020 at 11:57 AM
    Professional Hand Model
    Fred
    Hand Protectors
    I sense a deal getting ready to happen.
    Lil Steve[QUOTED] likes this.
  11. Nov 8, 2020 at 12:12 PM
    Mxvet90
    Mxvet90 New Member
    Yea, alloy and steel wheel lug nuts should be different
