  1. Oct 30, 2020 at 7:08 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Got her washed finally
  2. Oct 30, 2020 at 7:14 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Thank you, didn't know that. :)
  3. Oct 30, 2020 at 7:15 PM
    biebs96
    PA
    Yes I’ve done that.. just wish some guru on here would find a way to extend it to a minute or more.
    Wallygator, Jcmf52 and TILLY like this.
  4. Oct 30, 2020 at 7:17 PM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    I'm not an electrician or wiring expert but I'm assuming it can be done. Reason I think it can be done is bc I have 2 BD squadrons wired into my rear bumper that come on automatically when I shift into reverse. I also have them wired onto a switch on dash that I can turn them on or off at anytime. I'm assuming you can do the same here. Your lights will come on auto when the door is open and off eventually when close, you can then have the switch to power on and off whenever you want besides the auto function tied into the doors.
  5. Oct 30, 2020 at 7:24 PM
    TILLY
    Massachusetts
    Nice and comfy inside with an adult beverage and don't feel like going out to the truck :cheers:, What happens with the lights when you have it switched to off?
  6. Oct 30, 2020 at 7:28 PM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Not sure...:monocle:
    TILLY[QUOTED] and Rica25 like this.
  7. Oct 30, 2020 at 7:39 PM
    TILLY
    Massachusetts
    I'll have to go out and check after a few more, my guess would be that all the lights go out as soon as you close the door?
  8. Oct 30, 2020 at 8:09 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    Ok. A lot more miles than me. I'm only at 37k. You're lights have seen a lot more road grime and pitting than mine. But it's good to know that's they'll still look like new after detailing.
    GarTX526[QUOTED] and Rica25 like this.
  9. Oct 30, 2020 at 8:11 PM
    TILLY
    Massachusetts
    Thanks, this is definitely the route i want to take. Was trying to avoid adding an additional switch, but i don't think there's any other way.
    Wallygator likes this.
  10. Oct 30, 2020 at 9:06 PM
    Zilla18
    Zilla18 New Member
    Scott
    Richmond, TX
    18 SR5 CM TSS Offroad
    I would like a bit more delay too, but generally sufficient for my purpose. Really like how it makes the truck look. Played around with placement in the rear and spills nicely onto the bar, almost a low key puddle light.
  11. Oct 30, 2020 at 9:08 PM
    Zilla18
    Zilla18 New Member
    Scott
    Richmond, TX
    Comes wired to plug into existing footwell bulb socket. Delay qould be nice tho...
    Rica25 likes this.
  12. Oct 30, 2020 at 9:22 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Yep, I have the footwell kit as well. I'll have to pay attention to the ignition ring and the footwell lights and see if they turn off at the same time. They might not be related at all, but was just curious.
    TILLY and Rica25 like this.
  13. Oct 31, 2020 at 5:54 AM
    Toptalktoyota
    Toptalktoyota New Member
    2020 DC SX
    No, west central
    Rica25 likes this.
  14. Oct 31, 2020 at 6:08 AM
    needsmoresalt
    needsmoresalt New Member
    Patrick
    2020 Tundra TRD Pro
    A few
  15. Oct 31, 2020 at 8:15 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Actually, I gave this some more thought...
    Rather than connecting the VLED’s to the tiny footwell light, you could connect it a little bit higher into the illumination circuit. This would allow you to turn them on on with the parking lights/dash. The cool thing about this is that you would be able to dim them. However, the bummer is that they would not come on with the door unlock/lock without special additional wiring.
    I wired in my door handle lights this way and really like this set up.
  16. Oct 31, 2020 at 8:32 AM
    TundraPHX
    TundraPHX Ryan started the fire.
    Jared
    The answer to this is techstream. I just had this key programmed and while he was in there he turned off the seatbelt chime since I Offroad a lot and I’m in and out of the truck all the time and it gets annoying. I also have 4 kids so rarely am I unlocking just one door. I had it changed to just one click unlocks all 4 doors. I remember seeing some light setting timers in there too. I’d entertain that. It’s a program that hooks up to comp and you usb comp to your obd2 plug. (Whatever it’s called nowadays) and you’re in.
    Cosmoblu, TILLY, Wallygator and 3 others like this.
  17. Oct 31, 2020 at 9:28 AM
    Airn890
    Airn890 New Member
    airn
    2021 tundra
    what was your process for removing the pinstripe
  18. Oct 31, 2020 at 9:29 AM
    TR15UCK
    TR15UCK New Member
    2020 Cement Limited
    Bought from another user on here and just installed my OEM bed step. Took the "bracket cut" shortcut, and installation was way simple.
    aark12, Cosmoblu, redryder and 16 others like this.
  19. Oct 31, 2020 at 9:34 AM
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
    Ordered my 10" DD last night. That group buy is open through today. 30% off SS.
  20. Oct 31, 2020 at 9:37 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
  21. Oct 31, 2020 at 9:39 AM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    Rica25 likes this.
  22. Oct 31, 2020 at 10:38 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Great idea!
    :cheers:
    Rica25 likes this.
  23. Oct 31, 2020 at 10:40 AM
    AlrightAlrightAlright
    AlrightAlrightAlright New Member
    Northwest Arkansas
    2020 SSM DC 4x4 with SR5 Upgrade Package
    RetraxONE MX retractable bed cover TRD Rear sway bar Debadged FabFours Matrix front bumper Smittybilt 9,500# XRC winch Aries 30" light bar (internal bumper mount) Diode Dynamics SS3 3" SAE Fog and Driving lights ConsoleVault RhinoRack crossbars
    Fall is the season to install! Retractable cover (RetraxOne XR) and Rhino Rack vortex crossbars (VA180S with RLT600 mounts). Cheaper than Yakima or Thule and equally spec’d... we’ll see how it proves out for my uses. Very pleased with manufacturing, top-rate instructions and straightforward install. Also bolted on TRD rear sway bar, equally simple.
    Only one clumsy skinned knuckle in the whole install! Keep adventuring, Tundra members!
    Cosmoblu, Ostrich, GAknight and 7 others like this.
  24. Oct 31, 2020 at 10:52 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Put it n the cargo light circuit. It has a switch.
    Yzed608[QUOTED] and Rica25 like this.
  25. Oct 31, 2020 at 10:58 AM
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    Put some Kings on. It took about an hour, a little less but a bracket was bent in shipping and I had to make it round again.
    4BEC6F76-8150-42D3-B157-1A5ADA1E1D21.jpg 5F80C11A-EEB5-4C2C-9776-E2A56259935D.jpg E2DF821E-9838-44C8-A940-0C21E9593767.jpg C822334C-565B-4698-8914-CBAFF1800E1E.jpg
    Cosmoblu, RBB, Baja Mike and 14 others like this.
  26. Oct 31, 2020 at 12:04 PM
    Wallygator
    I was thinking the timer as in how the dealer can access the system and change certain options.
    EDIT: Yeah someone mentioned it...Techstream
    TundraLuv, TILLY[QUOTED] and Rica25 like this.
  27. Oct 31, 2020 at 12:36 PM
    andnyleswillriot
    andnyleswillriot Not Remote Working
    Breckenridge, CO
    2016 DC w/ Black Topo Topper
    Toytec 3" w/2.5 Coilovers. SPC UCA's. Method Roost Bronze Wheels. 35" BFG KO2's. SPC Upper Control Arms. 2019+ TRD Pro Grill. LED headlight bulbs. 2020 OEM LED Fog lights. Tech12volts Remote Start. MobArmor Magnetic Phone Mount. Topo Topper.
    Nothing huge but I’m stoked. Put the TRD PRO grill on my 2016. Used the Ares plate cover for the TSS sensor area, looks great and well made!!
    Tierhog, RBB, Ostrich and 11 others like this.
  28. Oct 31, 2020 at 12:53 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Curious what other covers you looked at before settling on the Retrax? I had a TruckCovers USA one on my 08 that took a lot of abuse (and had its issues over time), but I've now got a 21 and need something for it. The rails for a rack are a necessity, which narrows it down to only a couple contenders. I've seen a few people have issues with the Retrax over time - the plastic wearing out or something. Would love to hear more.
    Thanks.
  29. Oct 31, 2020 at 1:12 PM
    InsaneAuto86
    InsaneAuto86 New Member
    SE PA
    2020 Tundra SR5 TRD
    Hauled some tires back from my sisters farm
    Hightide, Cosmoblu, Ostrich and 10 others like this.
  30. Oct 31, 2020 at 1:20 PM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Have these same bars over my PowertraxOne XR, love them for hauling extra “stuff”!
    I’ve had the Retrax Power covers on my last 3 trucks, no issues whatsoever!...I would highly recommend them, I love being able to just hit a button and open/close the cover, and also locking it anywhere along the track!
