daytime running lights
Discussion in '2.5 Gen Tundras (2014-2021)' started by stevolene, Oct 30, 2020.
  1. Oct 30, 2020 at 4:25 PM
    stevolene
    stevolene [OP] New Member
    GA/TN line
    this may be a simple fix , but the right side daytime running lamp / turn signal stopped working , was clearly burnt out so bought another and changed it out , worked fine .. drove it for several hours now out again, figured it was loose , pulled it out and reseated , worked once again, drove about a minute , right turn signal and DRL out again on the same right front side , right rear turn signal works but flashes fast usually meaning there is a light out , however both front parking lights are working when the parking lights and or headlights are turned on , are they not the same bulb? I would think the fuse would control both front daytime running lamps , anyone have any suggestions?
  2. Oct 30, 2020 at 4:27 PM
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    Maybe check the socket? It may be corroded or something causing the failure?
  3. Oct 30, 2020 at 9:18 PM
    johnvan
    johnvan OG
    john
    Rensselaer,New York
    2016 inferno SR5 DC
    Like Doxiedad said, check the socket, I have seen them almost melt from the heat from the bulb.
    Doxiedad likes this.
  4. Oct 30, 2020 at 10:31 PM
  5. Nov 5, 2020 at 6:58 PM
    stevolene
    GA/TN line
    thanks for the replies , turns out I got a bad lamp from Toyota , luckily I bought 2 worrying that the tint may differ
