Lifter noise
Discussion in '1st Gen Tundras (2000-2006)' started by Girllovestrucks, Oct 30, 2020.
Had cylinder rethreaded, threads came out when removing spark plug now getting lifter noise.
  1. Don't know
    0 vote(s)
    0.0%
  2. I'm guessing
    2 vote(s)
    100.0%
Multiple votes are allowed.
  1. Oct 30, 2020 at 7:11 PM
    Girllovestrucks
    Girllovestrucks [OP] New Member
    Nancy
    1st gen tundra
    None yetY
    Had to have cylinder rethreaded, threads came out when changing spark plug now getting valve train noise. What is possible cause?
  2. Oct 30, 2020 at 7:16 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    possible the combustion pressure is getting past the threads. hard to tell without video at least. but even then its hard.
    these engines (all the first gen engines) are sping and bucket design, there are no lifters
  3. Oct 30, 2020 at 7:19 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I'm guessing draws first blood!
    Girllovestrucks[OP] likes this.
  4. Oct 30, 2020 at 8:15 PM
    Girllovestrucks
    Nancy
    1st gen tundra
    None yetY
    Did not know I didn't have lifters so does that mean I can drive and no damage will occur to engine? Looking for all the knowledge I can want to make informed decision on what to do to fix.
    Thanks!
  5. Oct 30, 2020 at 8:25 PM
    empty_lord
    05 rollover special
    it should be looked into. it is possible you have a noise related to the plug issue. you do not want a plug to fly out while driving.
  6. Oct 30, 2020 at 8:36 PM
    Girllovestrucks
    Nancy
    1st gen tundra
    None yetY
    Ok just want as much knowledge to bring to mechanic. I was also thinking something to do with pressure because they took the top of engine apart but don't know if there is s factory setting??
  7. Oct 30, 2020 at 8:40 PM
    Girllovestrucks
    Nancy
    1st gen tundra
    None yetY
    How do I check if fuel injection issue?
  8. Oct 30, 2020 at 9:04 PM
    empty_lord
    05 rollover special
    Doubt it’s a fuel issue. A video would do a lot to possibly shed light on it.
  9. Oct 30, 2020 at 9:33 PM
    Girllovestrucks
    Nancy
    1st gen tundra
    None yetY
    Video of valve train?
  10. Oct 30, 2020 at 9:38 PM
    bassman417
    bassman417 "Tundra Time". My favorite time of day...
    Paul
    Las Vegas
    2004 DC 2wd Imperial Jade
    Probably just a short video of the truck idling with the hood up and a few good revs to see what noise you are referring to. Good luck and tell us more about your truck. got pics?
  11. Oct 30, 2020 at 9:41 PM
    Girllovestrucks
    Nancy
    1st gen tundra
    None yetY
    Will post pics and vids tomorrow. Thanks for the info Dan and hope to converse after I post.
    Good night all!
    N84434 likes this.
