Hub Rings
Discussion in 'Wheels & Tires' started by nh98, Oct 24, 2020.
  1. Oct 24, 2020 at 3:17 PM
    nh98
    nh98 [OP] New Member
    2018 Tundra Platinum
    Ive been having an issue lately with my Method Wheels where at speeds over 40 mph I’ll get some steering wheel wobble. I brought the truck to a shop to have balance beads put in and that didn’t do the trick. I took it to another shop and they found that my truck didn’t have hub rings. I’m not sure if they got lost when the lift was being installed, when the balance beads were put in, or if I never had them. The shop told me to reach out to Method and see if they could give me an answer and I got nothing. I’m wondering if anyone has had this issue or if anyone knows what type/size I should purchase. This is far outside my expertise so links would be extremely helpful. I have a 2018 Tundra Platinum with 17x8.5 Method Grids and 35” Maxxis Razr MTs. Thanks in advance for any help
  2. Oct 30, 2020 at 4:16 AM
    Beerghost
    Beerghost New Member
    2014 MGM Tundra TRD CrewMax
    Go to where you bought the wheels, it should list what hub centric rings (size) it needs and you should be able to purchase them there. Super cheap items. I've dealt with this same issue in the past when my tires were rotated and the shop lost my hub rings.
