Intermittent Wipers
Discussion in '2nd Gen Tundras (2007-2013)' started by Notarobot, Oct 29, 2020.
  1. Oct 29, 2020 at 12:55 PM
    Notarobot
    Notarobot [OP] Jagged lines!
    2013 CM
    I have a 13 sr5 crewmax.
    I've only had the tundie since June and I noticed the intermittent wiper settings are opposite of my last vehicle (02 celica).
    After a short search I discovered the tundra doesn't have oem intermittent wiper settings??!
    But mine has it which means someone else put them on aftermarket.
    My question is can I reverse the time settings on the switch? In my celica -and every car I've ever used wipers in- the settings are as follows:
    Below first (shortest) dash=3s
    Between first and second=6s
    Between second and third =9s
    Above third (longest dash)=12seconds
    My tundie is the exact opposite.
    Can the plugs be reversed to change the polarity?
