  1. Oct 29, 2020 at 5:01 AM
    Yeah you've had some bad luck but your truck also has over a quarter million miles man. Even Toyota can only build them so well. And who knows what kind of life it had before you bought it.
    TomGreen and theblurry1[QUOTED] like this.
  2. Oct 29, 2020 at 6:09 AM
    Professional Hand Model
    Fred
    Hand Protectors
    A small island for small minds.
  3. Oct 29, 2020 at 6:49 AM
    speedtre
    speedtre New Member
    Inland Northwest
  4. Oct 29, 2020 at 7:03 AM
    Fred
    Hand Protectors
    My favorite character!
    speedtre[QUOTED] likes this.
  5. Oct 29, 2020 at 7:46 AM
    The squeeking noise a bearing? like a failed water pump? Or a screeching noise from coolant on the accessory belt causing it to slip? Not sure your rig is toast yet. Check thermostat and waterpump before you make 'er walk the plank. Could be a relatively easy fix. I'm doubtful it's the head gaskets. Different set of symptoms all together, but checking for contamination in the oil and coolant is an easier path than pulling heads. They usually leak in more than they leak out so to speak.
    NUDRAT and theblurry1[QUOTED] like this.
  6. Oct 29, 2020 at 8:01 AM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    Any suggestions where to get oem springs for the front for a 2003. Dont want to raise the truck. Maybe lower a little if anything.
    2003 V8 4x4 reg cab. Oem front springs no longer available from toyota.
    Thanks
  7. Oct 29, 2020 at 8:16 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
  8. Oct 29, 2020 at 8:38 AM
    Fred
    Hand Protectors
  9. Oct 29, 2020 at 8:40 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Where are you located? I'd check junkyards because what Toyota wants for them is stupid. Are you replacing your shocks at the same time? You can get the old man emu 2883 coils and that should keep you at stock height.
    I have two in my storage unit you can have if you're near Colorado.
    TomGreen, theblurry1 and oscardog86 like this.
  10. Oct 29, 2020 at 9:11 AM
    TomGreen
    TomGreen New Member
    Man that looks great
    Tundra2 and imDementeD[QUOTED] like this.
  11. Oct 29, 2020 at 9:12 AM
    TomGreen
    TomGreen New Member
    Cutting the flares straight was the hardest part. I need to go back and fix mine too
    oscardog86 and FrenchToasty like this.
  12. Oct 29, 2020 at 9:19 AM
    TomGreen
    TomGreen New Member
    So the archive leafs give you 1 inch or more over stock? I'm looking for 1.5 to 2 inches when I replace my leaf springs.
  13. Oct 29, 2020 at 9:23 AM
    TomGreen
    TomGreen New Member
    Check craigslist and the market place here if you meet the requirements. Same with FB market. People are always selling take offs. Sometimes they are old and sometimes they are new
  14. Oct 29, 2020 at 9:27 AM
    TomGreen
    TomGreen New Member
    Florida keys?
  15. Oct 29, 2020 at 9:27 AM
    oscardog86
    oscardog86 New Member
    Southern California
    Actually if you check out the archive garage website, it says: -Lift height (vs stock unloaded 4WD models) is estimated at about: 2.5" unloaded, 2.0" with 500 lbs, 1.5" with 750 lbs, and 1.0" with 1,000 lbs added to rear axle weight. Lift amount similar for Access Cab and Double Cab
    TomGreen[QUOTED] likes this.
  16. Oct 29, 2020 at 9:28 AM
    TomGreen
    TomGreen New Member
    Do y'all got snow on Xmas? We get snow like once every 10 or so years
  17. Oct 29, 2020 at 9:30 AM
    TomGreen
    TomGreen New Member
    That should be perfect then. I don't know how much weight i.have back there but I have a tool box full of crap and the same bumper as @imDementeD
  18. Oct 29, 2020 at 9:30 AM
    Haha not usually, it’s snowed in town on easter 5 or 6 years back. The Lil mountain near town will get snow, but not usually in town ever
  19. Oct 29, 2020 at 9:36 AM
    Fred
    Hand Protectors
    Possibly. Like any great Model, I can throw different looks.
    Darkness likes this.
  20. Oct 29, 2020 at 10:42 AM
    RR60
    RR60 New Member
    I may need to check if they can actually get them. I had already checked with Conicelli Toyota and Loyalty who said main warehouse was out.
    Also checked out the Old Man Emu Coil Springs but they dont list them as being for 1 st gen Tundra. And worried about the ride height of stiffness will not be the same as oem.
    Long story. But I got stuck with new TRQ struts (not TRD)on my Tundra. Does not ride as good. But main thing is it raised the front 3/4". If anything 1 myself would rather have the front lower not higher. Especially since I had already lowered the back some.
    So wanted to get rid of the TRQ junk and go back with what I wanted to begin with. Bilstein 4600 shocks and a oem height spring.
    Years back had lowered back just an inch. Which still left me with the back 1" higher than the front. Just what I wanted.
    With these new struts in front it now sits with the front 1/4 to 1/2" higher than the back. SOS makes a 1" front lowering kit. But need to have the 4600 Bilsteins which I have on order. But they are not sure if I can still use the TRQ springs. So to save any problems figured safe bet is a OEM spring.
    TRQ structs sell for 180.00 a pair so figured maybe a bad quality.
    3 different shops this year with suspension problems and want to get it right this time.
    Thanks for any suggestions
  21. Oct 29, 2020 at 2:15 PM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    I wish I would have measured before/after but i also added the bumper and sliders at the same time.
    What I can say is the front is between 3.5-4" lift and it seems level at this point with probably 4-600lbs added in the rear. So i'd guess around 2"?
    I did not do any relocation of the stock shock locations.
    oscardog86[QUOTED] likes this.
  22. Oct 29, 2020 at 2:17 PM
    imDementeD
    They are supposed to give:
    2.5" - Unloaded
    2" - 500lbs
    1.5" - 1000lbs
    @oscardog86 - didn't see you had already answered this.
    oscardog86 and TomGreen[QUOTED] like this.
  23. Oct 29, 2020 at 4:29 PM
    Fred
    Hand Protectors
    8 ‘Silencer Pads’ arrived today for the rear leafs. Might get them on tomorrow after a few cups of French Roast and late morning breakfast. :bananadance:
    abcinv and FrenchToasty like this.
  24. Oct 29, 2020 at 5:27 PM
    carpenter356
    carpenter356 New Member
    Madison
    2006 DC Limited
    Toytec blown on my 06 DC... And CV boot replace or new CV? I bought this truck used last year, but gremlins are showing...IMG_20201029_110337.jpg IMG_20201029_110501.jpg
  25. Oct 29, 2020 at 5:56 PM
    theblurry1
    theblurry1 ~
    Castle Rock, CO
    2001 Thunder Grey Tundra AC Limited 4x4 V8
    (Camper conversion underway.) Rebuilt engine w/265K miles, A.R.E. camper shell (w/cab pass-through, rooftop fan, and side windows delete), bedlinered steel ladder rack (w/wooden rooftop deck and hammock mount), all LED lights (red dash, 4" side floods, 32" rear bar), Android head unit, 1.5" lift from Bilstein 5100 struts, 32" DuraTrac tires on factory rims, 1.5" wheel spacers, Moog suspension parts, SuperSprings leaf kit, diff drop, Reese trailer brake control, GoRhino Hitch Step, debadged, F-150 rear bumper, Sequoia center console unit upgrade, partial rear bench seat delete, dashcam, aftermarket speakers, 50% sound deadening coverage, custom tools unit.
    Confirmed blown head gasket.
    The options are to a) pull the engine and do open heart surgery by essentially rebuilding it, or b) sell it and get a Tacoma.
    Has anyone done this job? Please someone let me feel like I'm not pioneering this.
    What all should I replace besides all engine gaskets?
    Might start looking at beaters to get me by until it's rebuilt.
  26. Oct 29, 2020 at 7:13 PM
    Kongap
    Kongap New Member
    2004 SR5 DC
    Rip
    theblurry1 likes this.
  27. Oct 29, 2020 at 7:17 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Toyota sells gasket Kits for engine overhauls.. can’t say I’ve ever seen a gasket let go like that...
    It can be done in the truck.. it’s not a super complex engine, but it is gone consuming
    That’s a project someone would buy (I know I would for the right price) but you’d be better off fixing it if you have the know how
    Used engine is also another choice here
    ktundra, chrisb, speedtre and 3 others like this.
  28. Oct 29, 2020 at 9:24 PM
    ktundra
    ktundra rust be damned
    Lex
    NJ
    06 Tundra DC Limited 4WD
    Bilstein 5100
    Look for a pull-a-part junkyard in your area?
  29. Oct 30, 2020 at 12:33 AM
    ktundra
    Lex
    NJ
    Bilstein 5100
    15% Harbor Freight coupon off single item. Rare no exclusions coupon good thru Nov 1
    chrisb, Lil Steve, w666 and 2 others like this.
  30. Oct 30, 2020 at 7:29 AM
    theblurry1
    theblurry1 ~
    Castle Rock, CO
    I wouldn't feel comfortable putting in an engine of unknown history. If I'm going to rebuild it, I'm going to do it right, and use OEM parts when I can. I think I'm literally going to have to get another job to afford a second vehicle and the parts for this build.
