Rough idling after replacing battery
Discussion in '2.5 Gen Tundras (2014-2021)' started by Machado, Oct 19, 2020.
  1. Oct 19, 2020 at 4:16 AM
    Machado
    Machado [OP] New Member
    Cezaro
    Hi
    I had to replace the battery. Now, I'm in trouble.
    Does anyone know how to fix rough idling ?I
    2015 Toyota tundra 6.4l V8
    Thanks!
    YardBird likes this.
  2. Oct 19, 2020 at 4:24 AM
    A battery shouldn't cause that.. Is it surging? I bet the throttle body is dirty.
  3. Oct 19, 2020 at 4:29 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    How long did u let it run after replacing battery? The ecu needs some time to learn.
    grichg, YardBird and Machado[OP] like this.
  4. Oct 19, 2020 at 5:13 AM
    Machado
    Cezaro
    Maybe 3 minutes.
  5. Oct 19, 2020 at 5:42 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    The ECM will take awhile to adjust after disconnecting the battery. Drive the vehicle and give us an update on your results.
    Machado[OP] likes this.
  6. Oct 19, 2020 at 6:03 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Hopefully some running time will allow the ECU to get everything running smoothly again. If not, the folks here are pretty knowledgeable and will help you figure it out.
  7. Oct 19, 2020 at 7:00 PM
    Welcome
  8. Oct 28, 2020 at 8:12 AM
    Machado
    Cezaro
    thank you guys!
    After driving for 2 minutes, everything returned to normal.
  9. Oct 28, 2020 at 8:24 AM
    YardBird
    Jonesy
    2005 RCLB
  10. Oct 28, 2020 at 1:29 PM
    kevine0001
    kevine0001 New Member
    Kevin
    I just replaced my battery an hour ago. First start felt like it stuttered and it shut off. I turned it again, no problems. Drove it around, no problems.
  11. Oct 28, 2020 at 1:36 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Every tundra does that after reconnecting the battery.
    kevine0001[QUOTED] likes this.
  12. Oct 28, 2020 at 1:38 PM
    grichg
    grichg New Member
    rich
    and tacomas etc...
    Danman34[QUOTED] and Machado[OP] like this.
  13. Oct 29, 2020 at 6:47 PM
    socaltundra951
    socaltundra951 Gentlemen Prefer Black Tundras
    Southern California
    Black CrewMax 5.7
    Probably that 6.4L V8 you have in there, truck was never designed to run with something that big wedged in the engine bay! :D:thumbsup:
    Glad you got it figured out and welcome from socal.
  14. Oct 29, 2020 at 6:54 PM
    Suprafantx
    Suprafantx New Member
    2020 4X4 White Tundra TSS
    As I remember, I think you need to drive about 40 miles for ECU to learn.
    kevine0001 likes this.
