  1. Oct 27, 2020 at 4:02 PM
    marky671
    marky671 New Member
    Marky671
    2018 Tundra
    Thanks brotha!! They’re the Vision Nemesis 18x9 +18offset in gunmetal wrapped in falken wild peaks 295/70/18
    TundraTool13[QUOTED] likes this.
  2. Oct 27, 2020 at 4:49 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    Dang they have a new design my 2019 weathertech don’t look like that those look like a way better fit darn it.
  3. Oct 27, 2020 at 4:51 PM
    TundraTool13
    TundraTool13 New Member
    2020 Tundra Platinum
    I really wanted to see how gunmetal wheels looked on a white tundra!! Really like they the combo of white and gunmetal!!
  4. Oct 27, 2020 at 5:16 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I always thought the best rule of thumb is whatever your e fine weighs, put an equal amount of weight in bed and you will have the best traction...I have x10 60# tube sand bags in mine and I rarely need 4wd in the snow...comforts the ride a bit too...
  5. Oct 27, 2020 at 5:32 PM
    Do58
    Do58 New Member
    I saw that some people have had issues with the passenger sliding around and having to do Velcro or something like that. Honestly, these do not have the nipples on the bottom like a set of husky x-act contours for a double cab Tacoma I had but these do NOT slide at all. These fit fantastic and snug as all get out.
  6. Oct 27, 2020 at 5:58 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    I only added two options; the roof rack for my canoe and the sliding windoors on the sides.
  7. Oct 27, 2020 at 6:03 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    I had seen someone did add some d rings that utilized the factory bed bolts. Added 4. I like it and want to do that to add some stronger clips down low. Especially since I lost one tie down for my swing case
  8. Oct 27, 2020 at 6:15 PM
    Fotnot[QUOTED] likes this.
  9. Oct 27, 2020 at 7:00 PM
    jr1016
    jr1016 New Member
    Ric
    Sacramento, CA
    2020 CM TRD Sport
    Can't remember who it was but someone here installed a new Tonneau cover and instead of lowering the OEM Rails he just replaced the big circle plastic nut on the cleats with a wing nut and it cleared the Cover. I'm about to purchase a Bakflip MX4 and I don't want to lower the rails if I don't have to. Please chime in if you did this. Thanks.
  10. Oct 27, 2020 at 7:18 PM
    Rely01
    Rely01 Window Shopping
    Eli
    SW Arkansas
    2016 Silver Sky SR5 CM
    @NoCoToyo I did this same thingy n that thread that @Tundra234 shared. Mine turned out great. I did find that I had to take a razor blade and cut away the spray in bed liner to help the bed bolts free up. I just sprayed over mine with rattle can bed liner for touch up.
  11. Oct 27, 2020 at 7:34 PM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Finally got around to fixing the recall on the turn signals, I upgraded to LEDs so it didn’t really matter to me but I wanted to “close” the recall on the truck...Toyota said they’ll just look to see that I swapped the wires next time I bring it in for my 15k service and they’ll close it out...easy fix for anyone who hasn’t done it yet
    https://youtu.be/-Mv7YaLUx44
    3xYOTA, GAknight, jrquist and 5 others like this.
  12. Oct 27, 2020 at 7:42 PM
    the ER kid
    the ER kid New Member
    2020 Platinum Crewmax
    Put in Rock Lights
  13. Oct 27, 2020 at 7:47 PM
    the ER kid
    Where did you get the first aid kit? Do you have a link?
  14. Oct 27, 2020 at 7:47 PM
    18" TRD Off Road Wheels
    For a super quick and easy way to contain them you can just drop a board into the bed slots circled in the first pic below. You would basically have a little wall outlined in the second pic.
    If you want it more secure than that you could cut and put a piece of plywood or OSB over the bags and screw it into the top of the board. This would basically box the bags in between the board and the tailgate.
    3rd easy option if you decide to add more bags would be to stack them in on top of your current bags. Put a couple eyebolts into the top of the board at the blue "X" marks in the second pic and run straps across the tops of the sandbags from your factory tie downs to the eyebolts on the opposite side of the bed. The crossed straps should be able to pin the bags in place so long as you have them stacked high enough for the straps to make contact.
    I hope I explained what I am thinking well enough.
    Cosmoblu, GAknight, WFD473 and 8 others like this.
  15. Oct 27, 2020 at 7:54 PM
    RobertD
    Robert
    DFW, Texas
    I enjoy reading what you guys with snow have to do. Such a foreign concept to me but I enjoy being educated incase I end up in that environment.
  16. Oct 27, 2020 at 7:58 PM
    Honestly, I don't add weight to my truck. I make sure my tires have good tread, and I use a light touch on all control inputs. Slamming the brakes, jamming the throttle, or cranking the wheel are all bad news in snowy/icy conditions. Finesse will save you more often than an extra 500 pounds in the bed will.
  17. Oct 27, 2020 at 8:18 PM
    marky671
    marky671 New Member
    Marky671
    2018 Tundra
    Same, I was gonna go for bronze but I barely see gunmetal on white.
  18. Oct 27, 2020 at 9:20 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    You got her done! Very nice!
    marky671 likes this.
  19. Oct 27, 2020 at 9:22 PM
    BlueRibbon4x4
    Geno
    Damn that’s beefy! Takin’ out buffalo with that thing?
    Beesta, BashFab, mgm16trdpro and 2 others like this.
  20. Oct 27, 2020 at 9:45 PM
    This post makes me doubt that you've seen a buffalo in person.:monocle: It did make me laugh though! :fistbump:
    dpast88, SMTundra, ElNopal and 3 others like this.
  21. Oct 27, 2020 at 10:13 PM
    RobertD
    Robert
    DFW, Texas
  22. Oct 27, 2020 at 10:16 PM
    Not at all. I completely understood that he was being facetious, but because I have buffalo in my front yard on a regular basis I couldn't help myself. :p
  23. Oct 28, 2020 at 12:26 AM
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    Seeing as buffalo aren’t on the North American continent (or South American), I doubt you’ve seen one either. :duel:
    I bet you do have bison in your yard, though!
    I’ve been to your neck of the woods and those things are beasts.
  24. Oct 28, 2020 at 12:28 AM
  25. Oct 28, 2020 at 12:33 AM
    The Patriot 1776
    '16 TSS CM 4x4
    It’s a misnomer. You could call them monkeys but that wouldn’t technically be correct either. Only 2 types of buffalos have ever existed:
    Water buffalo (South Asia)
    Cape buffalo (Africa)
    It’s a very common misconception and I was just ribbin’ ya.
    :thumbsup:
    ElNopal, HulkSmurf14 and GODZILLA like this.
  26. Oct 28, 2020 at 12:36 AM
    I got the joke, and was not disturbed. I was just pointing out the evolution of language and that Buffalo (specifically used in North America) is commonly used to refer to Bison. It is not biologically correct, but it is grammatically correct. It's similar to using the term Indian to refer to Native American. It's not incorrect even if it's not specifically accurate.
    Marcstryd and ElNopal like this.
  27. Oct 28, 2020 at 3:33 AM
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    I think the 21s come with it. My Trail edition has it as well.
  28. Oct 28, 2020 at 3:33 AM
    CorsoTundra
    North GA
    Zoom in and you'll see the part number
  29. Oct 28, 2020 at 4:08 AM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
  30. Oct 28, 2020 at 4:24 AM
    TheyCallMeBruce84
    TheyCallMeBruce84 New Member
    Bruce
    NC
    2020 Tundra Limited Barcelona Red
    Looks great! I'm coming up on 8 weeks waiting on my Leer 700...
