'19 TRD Pro Keyless remote problem help
Discussion in '2.5 Gen Tundras (2014-2021)' started by Kevfran99, Oct 27, 2020.
  1. Oct 27, 2020 at 6:44 AM
    Kevfran99
    Kevfran99 [OP] New Member
    Kevin
    Lilburn, GA
    '19 TRD PRO
    TRD Rear Sway Bar - Front tint - Caliraised LED Fogs & Light Bar-Bed LEDs-Bed Cover-Wireless Charger
    So my factory keys don't work very well. I had my locksmith check out the remotes themselves and they are putting out a strong signal so I know my keys aren't the issue. Sometimes when I get out of my truck and hit the lock button on the remote I'll have to hit it 4-6 times or more for it to lock. I hardly ever can get it to unlock all the doors with the unlock because it never reads the second unlock hit. Anyone experienced this? I'm just out of warranty and don't want to take it into the stealer. TIA
  2. Oct 27, 2020 at 11:37 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Is this only a problem in one location or all locations? I'm trying to eliminate radio interference.
  3. Oct 27, 2020 at 11:49 AM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    Multiple locations.
    Saltyhero13[QUOTED] likes this.
  4. Oct 27, 2020 at 11:52 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Have you changed any of the interior or exterior lights to led?
    Saltyhero13 likes this.
  5. Oct 27, 2020 at 11:52 AM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    I have but I was having this problem problem before also.
  6. Oct 27, 2020 at 12:07 PM
    Saltyhero13
    Can you run the app to lock/unlock? If so does the problem go away?
  7. Oct 27, 2020 at 12:21 PM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    I did not know about an app. Please do tell me more.
  8. Oct 27, 2020 at 12:24 PM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    Found the app. Will try tonight and report back
  9. Oct 27, 2020 at 12:27 PM
    Saltyhero13
    Its part of Toyota's Connected Services. It allows you to unlock/lock and remote start your truck. Its subscription based but you can activate the trial if you haven't done so already.
    I am trying to eliminate the locks from the equation. Its unlikely its the problem but it may help narrow in on the issue.
  10. Oct 27, 2020 at 12:30 PM
    Superwhite19
    Superwhite19 New Member
    2019 Superwhite CM
    if you put a LED in the cargo light it will cause what you are describing. although i see you said you were having issues before hand. i have to leave the cargo light switch in the off position to get proper function with the key fob
  11. Oct 27, 2020 at 12:32 PM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    Definitely not an actuator problem. They work from the button 20 times in a row.
  12. Oct 27, 2020 at 12:32 PM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    I will try turning this off just to make sure it's not my problem.
  13. Oct 27, 2020 at 1:22 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Unless yours is a push button start, app won't work.
    Almost every time someone here has had this problem it's been an LED in the cargo light.
  14. Oct 27, 2020 at 1:25 PM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    hmm. wonder why LEDs in those lights cause this problem. There has to be a way around it.
  15. Oct 27, 2020 at 1:27 PM
    19TurdPro
    2019 Tundra TRD Pro
    The antenna for your wireless is in there. Certain LED lights create EMI. There are LED lights that fit in there that do not.
  16. Oct 27, 2020 at 1:29 PM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    Which ones do not. The LEDs made a huge difference in the light output. I'd like to keep LEDs there.
  17. Oct 27, 2020 at 1:33 PM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    Just had the wife check my truck. Must have been the LEDs in the cargo lamps (although I swore I had this problem before I put the LEDs in there). She said the keyless works fine now.
    The Californian and Saltyhero13 like this.
  18. Oct 27, 2020 at 1:35 PM
    19TurdPro
    2019 Tundra TRD Pro
    I believe this one does not:
    https://www.vleds.com/921-36-w-5500k-t.html
    In fact, I checked with VLEDs and it is, indeed this one. Originally I had a different link in this post, which I revised. If you clicked on that link, it was the wrong one.
  19. Oct 27, 2020 at 1:43 PM
    19TurdPro
    2019 Tundra TRD Pro
    On a side not, I'm going to order these. How many are in there? Just one?
  20. Oct 27, 2020 at 1:44 PM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    Just got off the phone with them. Ordered a couple as he said they should have them next week and will ship right out. Thanks!
  21. Oct 27, 2020 at 1:45 PM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    There's one per side so you will need to order 2 bulbs
  22. Oct 27, 2020 at 1:58 PM
    Saltyhero13
    Glad you identified the issue before involving the dealer.
    Nice catch @19TurdPro !
    Kevfran99[OP] likes this.
  23. Oct 27, 2020 at 2:45 PM
    Danman34
    Danman34 New Member
    Danny
    They’ve been saying “next week” on these since September....lol. I’ve been waiting for these for months
  24. Oct 27, 2020 at 2:47 PM
    19TurdPro
    2019 Tundra TRD Pro
    Good to know. I think I shall wait.
  25. Oct 27, 2020 at 3:58 PM
    jr1016
    jr1016 New Member
    Ric
    Sacramento, CA
    2020 CM TRD Sport
    I put cheap Amazon LED on my cargo lights and although remote still works but the distance significantly shorten.
  26. Oct 27, 2020 at 5:36 PM
    MrBoJangles78
    MrBoJangles78 New Member
    '21 SR5 TRD Offroad Army Green w/ Blackout Package
    I have this exact problem with my Tacoma, also have LED's internal. Was bugging the crap out of me why it was not working well. Also the door touch areas would randomly not work and I'd sit there rubbing the door handle praying the damn thing would lock.... I'll try to turn off the cargo light as well and see what happens. Also nice to know before I go buying my LED's for the Tundra
    Thanks
