Schaeffers 0w-20 Oil Change
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rebel Tundra Man, Oct 26, 2020.
  1. Oct 26, 2020 at 6:16 AM
    Rebel Tundra Man
    Rebel Tundra Man [OP] New Member
    Tyler
    Western Kentucky
    2016 Black Limited CM
    4" RCX Lift, 20x10 Fuel Coupler's, 35x12.50x20 Nitto Ridge Grappler's, Color Match Front End, LED Bulbs, RCX Tube Steps, Green LED Underglow
    I have a buddy that was telling me about this brand of oil, they service their tri-axle dump truck with it (has 700k miles on it) since the start using Schaeffer's 15w-40, but he was telling me about the sales rep coming to give a demo of how this oil brand compares to Rotella and other brands of oil. He stated that he had some kind of bearing fixture on an electric motor to demonstrate. Apparently this Shaeffers oil will not allow a bearing to lock up (again this was some kind of demonstration fixture the rep had) under much pressure unlike all the other oils they demonstrated. My friend said the Rep pulled oil off their shelf, not stuff he had brought with him as well. They mixed water in with the oil and it still continued to do its job and did not turn thick and milky. Im gonna call it the "burn point" probably not the right term for it but it was like 400 degrees compared to most other brands at around 200 degrees. Anyone have any experience with something like this? I am thinking of switching to this brand for all of the specs my friend told me about that this oil brand offers. I know everyone has their own opinion of oil, thats not what I am looking for here. Just looking for information about any of you all running Schaeffers or any other brand with a similar story that has been demonstrated like this.
    **I am currently running Valvoline High Mileage with a factory Toyota filter**
  2. Oct 26, 2020 at 6:26 AM
    Cidertom
    Cidertom Chionophile
    Tom
    2017 longbed
    Used it in the Fire District vehicles. Sent oil samples in to determine when we needed to change the oil. Did filters yearly, and topped off. Even with the cold start, short run time the units typically had oil held up well.
    Rebel Tundra Man[OP] likes this.
  3. Oct 26, 2020 at 6:39 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Your Valvoline is a good oil. If your changing your oil according to the maintenance schedule you will be fine with just about any oil as long as it has the highest API service spec.
  4. Oct 26, 2020 at 6:48 AM
    Fishhead
    Fishhead New Member
    I’ve run Schaeffers before. It’s really good oil and a great record for being quality.
    That being said...Valvoline products are also really good and have a ton of outstanding Used oil analysis’ posted up.
    Honestly, the most important thing is regular maintenance. Yes...some oils are designed more for extended oil change intervals. However when keeping regular OCI’s, pretty much all oils nowadays are really really good as long as you meet specs.
    Use either Schaeffer or Valvoline with confidence.
  5. Oct 26, 2020 at 7:02 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I summon all my mana and cast Amsoil lvl 2 upon this thread.
  6. Oct 26, 2020 at 7:21 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I'm all in for veggie oil.
  7. Oct 26, 2020 at 8:01 AM
    Rebel Tundra Man
    Tyler
    Western Kentucky
    Im all in for my valvoline, been running it for years in all 4 of my vehicles, I do run castrol from time to time as well, but I was just blown away with the information that my friend was telling me about the schaeffers. you do pay quite a bit for this type of oil though. I believe it will be about $70-80 for 8 quarts of it. where as Im only spending $50 now for my valvoline.
  8. Oct 26, 2020 at 9:37 AM
    BIGUGLY
    BIGUGLY I the SheepDog. I have the capacity for Violence.
    Paul
    2018 Limited
    Schaffer makes great stuff. We use it by the barrel for tractors and the combine. You just won't find it in most stores and have to go to a specific dealer or thru a sales representative.
  9. Oct 26, 2020 at 9:52 AM
    Cidertom
    Tom
    2017 longbed
    That is where the testing comes in. But then you have to weigh the costs of the tests vs "just change the oil". I think if you want to do the whole testing thing you will find that 20Kmile change intervals will be the norm with the Schaeffers. My '03 4Runner got 12k interval changes and was still doing fine when I got rid of it at 446,000 miles. The engine was fine, but the running gear was worn out. I figure if a tractor trailer rig can go 25-30K miles between changes with their loads, I didn't need to do 6K changes unless there was a problem. But I never went with less than a "top shelf: oil brand.
  10. Oct 26, 2020 at 9:57 AM
    Charliebrn
    Charliebrn New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
    My ‘17 5.7 has 40k on it. Plan on using Mobile1....it’s avail everywhere around here, unless someone can give me a reason not to. I’ve never seen the Schaffer’s.
  11. Oct 26, 2020 at 10:05 AM
    Rebel Tundra Man
    Tyler
    Western Kentucky
    Yea I have a store and a sales rep close to me, so I got that part covered. I just dont know what the best thought is, right now Im running about 7,500 on oil changes in my tundra. but going to 10k+ would be nice as well.
  12. Oct 26, 2020 at 10:16 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    You really shouldn't base the oil change interval on what kind of oil your using. Engines produce contaminates from the combustion process that oil suspend until the next oil change. Change interval should be based upon your driving conditions, severe or normal.
    JLS in WA likes this.
  13. Oct 27, 2020 at 6:26 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    I'll assume your truck is not under warrantee.
    Before you swap, send the oil out for analysis (Blackstone) and note the report you get back. If you switch, change at the same mileage, and send it out. Any wear indicators change?
    If yes, go back. If no, go with your preference. If better, stay with Schaeffer's
  14. Oct 27, 2020 at 11:33 AM
    Rebel Tundra Man
    Tyler
    Western Kentucky
    Yea Im way out of warranty.
  15. Oct 27, 2020 at 11:59 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    The wrong spell component is used. You and your truck are now covered in baby oil.
    hagrid[QUOTED] likes this.
  16. Oct 27, 2020 at 12:07 PM
    TTund16
    TTund16 New Member
    If I want to spend $9-10 a quart, i would buy Amsoil.
  17. Oct 27, 2020 at 1:41 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    :annoyed:
    Saltyhero13[QUOTED] likes this.
  18. Oct 27, 2020 at 6:14 PM
    Blue Thunder
    Washington
    I've used Schaeffer's in previous vehicles. It is much more common in the heavy truck/equipment industry. It worked great in my Ford V10 and the Explorer V6 I ran it in, but it never performed better or worse than Mobil 1. I did Blackstone tests on them both. I did run it in my Ford with the Ecoboost and it didn't hold up as well as Castrol in that motor (neither did Mobil 1). Wear metals were higher and it sheared (thinned) out of spec. It wasn't in the "bad" range, but noticeable.
    Our motors are not harsh on oil, so there's no reason to run it IMO. Especially at their price point. I doubt it will last longer than any other oil, but you'd need an used oil analysis on a sample from your motor to really make that decision. Don't believe the salesman.
    JLS in WA, Saltyhero13 and Ruggybuggy like this.
  19. Oct 27, 2020 at 7:51 PM
    Cidertom
    Tom
    2017 longbed
    One other thing that must be taken into consideration is quantity. Our FD water tender used (as I remember) 14 GALLONS of oil. At that quantity, testing becomes very cost effective.
    Where my snowcat uses 3 qts. I use synthetic in it and change every season. It will see excess temp at least once per season and while synthetic holds better than traditional oil, it's much cheaper to change than test.
    the two extremes of quantity
  20. Oct 29, 2020 at 8:25 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I run Schaeffers front to back in my tundra, in everything except the transfer case. I love it. Its in both my trucks, my 7.3 loves it! I have a rep close to me that gives me good deals and free bottles of Citrol when I buy a few cases. I have a UOA thread on it, its worth a look. Had 9k miles on the oil, and I think 196k on the odo when I performed the change. I highly recommend it and if you can get it, do it! Look at some of their million mile engine tear downs. They're also the oldest oil company in America, and have been family owned the entire time. One of the guys there I believe has some certifications that only 3 or 5 people in the world have. They have tons of knowledge and if you ever have any questions just give them a call and they will be more than happy to help you out, if they don't have the answer immediately, they'll give you a call back when someone more knowledgeable is able to answer your question. Top notch company with superior products. Do it do it do it!
    250000yota likes this.
  21. Oct 30, 2020 at 2:59 AM
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    I've been running Schaeffers in my Tundra since day one. I bought my '15 used July 31, 2018, and changed the oil immediately about 2-3 days later. I've put right on 50k miles on it since buying it at 86k, all of that with Schaeffers. It is due for an oil change, so I will be taking a sample for Blackstone. I've been running Schaeffers in my older T100 since late 2013. I did a few Blackstone tests with the T100, but I can't find all of my results. Shown is one of the earlier tests I did with the truck. Just for some history, I bought my T100 in September, 2008, and spoke with the previous owner when he traded it in to the dealer I was working for at the time. He'd been running Mobil1 in it since its first oil change. I bought it from the dealer after his trade in with 102k on it. As of this writing, it's up to 238k, and has been supercharged since 170k, right after this testing shows. I need to do a new test, as I've been running Schaeffers in it for so long, but the reduction in wear metals was enough of a reason to do it for me. As Sumo91 stated, I run it front to back in both trucks. The T100 gets pushed much harder than my Tundra, as it's my fun 4x4 vehicle.
    Sumo91 likes this.
  22. Oct 30, 2020 at 3:30 AM
    glowblue
    glowblue From time to time
    VA
  23. Oct 30, 2020 at 3:48 AM
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    2020 Tundra Platinum
    So long as an oil meets certifications/grade requirements and it's from a reputable company it won't make one bit of difference. Your truck will never know the difference between Schaeffer's and Valvoline. Schaeffer's is good oil but so is Valvoline.
    WILLINH, Ruggybuggy, Hoff and 2 others like this.
  24. Oct 30, 2020 at 3:56 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Shoo! Go away and take your science with you.
    Obviously a sorcerer.
  25. Oct 30, 2020 at 5:01 AM
    Tundra-in-Cement
    Tundra-in-Cement Truck Chump
    2021 Tundra CM-OR
    Scanguage-II, Decked Systems, Leitner Rack, CaliLED lights, Firestone Air Bags, Trans-cooler kit, 2017 Pro grille and bulge, S-Tech 6 way switch, Corse Evo Darks w/ Stock Tires, 17-inch Alpha Equip Delta w/ Wildpeaks, Falcon Suspension, Coachbuilder +1 Shackle, Valhalla Cat Protectors.
    Have used Shaeffer's Moly for years in my Mazda Skyactiv engines. Good stuff. Have to believe their motor oil is on-par with other top brands.
  26. Oct 30, 2020 at 10:22 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Couldn't agree more!
    WILLINH and PWMDMD[QUOTED] like this.
  27. Oct 30, 2020 at 6:01 PM
    250000yota
    Russ
    Berthoud, CO
    Your probably right, but I will say, in addition to the testing I showed on my T, I've done the valve cover gaskets twice in my time of ownership (the curse of the 3.4. They always leak, no matter what you do lol). One thing that I noticed between the first set of gaskets (replaced at approx. 125-130k, not completely sure) and the second set (done while installing the supercharger at 170k) is that the engine was much cleaner internally, and didn't have near the deposits in the valve train area when I popped the covers off the second time.
    PWMDMD[QUOTED] likes this.
