  1. Oct 22, 2020 at 2:24 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Toying around with some Flaring Tools found on the side of the road. These might be the Unions used on the new Power Steering Cooler.
    ktundra, oscardog86 and bmf4069 like this.
  2. Oct 22, 2020 at 2:36 PM
    Seeing this pic made me realize I used to have that exact same multi-file kit with the blue and white clamshell. Where the hell did mine go?! It's not in my box anymore. I think my dad bought it back in the 70s or something at Sears. He gave it to me back in the late 80s when I was hitting my teens.
  3. Oct 22, 2020 at 2:40 PM
    Actually just asked dad, he said they were Glardon Vallorbe files. He doesn't remember where he got them. But damn I miss that set!
    oscardog86 likes this.
  4. Oct 22, 2020 at 2:45 PM
    Fred
    Hand Protectors
    Ye. Scored those files from a neighbor friend concierge garage sale. Got to pick through some choice old skool tools from the 60’s-70’s that are super high quality. Since acquiring these files, I often wonder how I did with out them. I use the round files all the time.
    bmf4069 and shifty`[QUOTED] like this.
  5. Oct 22, 2020 at 5:57 PM
    Absolutely crucial for fixing bolt threads. Was perfect for fixing threads on axle ends of skateboard trucks, which was my primary reason to pull them out.
    oscardog86, bmf4069 and FrenchToasty like this.
  6. Oct 22, 2020 at 6:25 PM
    Hasteen
    Hasteen To be continued...
    Justin
    Providence, RI
    2004 DC SR5 Texas edition 2016 CM 1794 edition
    1ST GEN Toytec 3/1 lift kenda 33s on 17x9 RockTrix RT107 BruteForceFab front bumper ----------------------------------- 3RD GEN rough country 6" Toyo 35's on 22x10 Fuel Assault TRDPro Grille
    any rubbing on the frame? my fix for the front rubbing was a BFF front bumper.
    Cane Skretteburg likes this.
  7. Oct 22, 2020 at 6:35 PM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    No, my offset is -10 on a 8" wheel so I am fine there. I just hit the bumper alot.
    Hasteen[QUOTED] likes this.
  8. Oct 23, 2020 at 3:05 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I don't know what makes me happier...the new hub bearing, or the new splash shield!
    Hasteen, Darkness, peanut and 5 others like this.
  9. Oct 23, 2020 at 3:49 AM
    Fred
    Hand Protectors
    I know a great nail file when I see one.
  10. Oct 23, 2020 at 7:51 AM
    Arringtonpalmer
    Arringtonpalmer New Member
    Sam
    New Hampshire
    2004 Limited Double Cab
    ARB Bumper, Warn Evo, UTE H66 tray, OME 2884 and Nitrochargers.
    One of my climate control knob lights went out, so I did the whole interior (except the cluster) up with LEDs.
    HOLY CRAP IT'S AWESOME! You can see stuff in there at night!
    NUDRAT, Hasteen, bmf4069 and 3 others like this.
  11. Oct 23, 2020 at 7:52 AM
    carpenter356
    carpenter356 New Member
    Madison
    2006 DC Limited
    I have been lurking for a while on this forum and wanted to show my 2006 DC Limited getting a bath. I bought this truck in February of '19 (151k mi), but it needs a lot of TLC. I previously owned a 2002 SR5 4WD new from the dealer, but I wanted a DC to fit a car seat comfortably. The 2002 was a fantastic truck with 283k miles on the OD, but life moves on.
  12. Oct 23, 2020 at 8:13 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Darkness and ktundra like this.
  13. Oct 23, 2020 at 8:35 AM
    theblurry1
    theblurry1 ~
    Castle Rock, CO
    2001 Thunder Grey Tundra AC Limited 4x4 V8
    (Camper conversion underway.) Rebuilt engine w/265K miles, A.R.E. camper shell (w/cab pass-through, rooftop fan, and side windows delete), bedlinered steel ladder rack (w/wooden rooftop deck and hammock mount), all LED lights (red dash, 4" side floods, 32" rear bar), Android head unit, 1.5" lift from Bilstein 5100 struts, 32" DuraTrac tires on factory rims, 1.5" wheel spacers, Moog suspension parts, SuperSprings leaf kit, diff drop, Reese trailer brake control, GoRhino Hitch Step, debadged, F-150 rear bumper, Sequoia center console unit upgrade, partial rear bench seat delete, dashcam, aftermarket speakers, 50% sound deadening coverage, custom tools unit.
    Hey guys, it's been awhile. I'm blowing out white exhaust upon startup. I also smell a light fuel odor when driving (likely unrelated). Am I looking at a potential blown head gasket if this is abnormal for winter starts, and has anyone done this job?
  14. Oct 23, 2020 at 8:48 AM
    S P A R K Y
    S P A R K Y New Member
    Mark
    Yes you can add 1"blocks. It may not make the best ride, and it may cause them to leak over time, but they will stretch for that 1" your adding.
    I don't believe just adding shocks make a height difference. 5100's will accommodate a 1" is what i see.
  15. Oct 23, 2020 at 9:05 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    is it cold out? condensation in the muffler will blow white smoke too.
    shifty` likes this.
  16. Oct 23, 2020 at 9:10 AM
    oscardog86
    oscardog86 New Member
    Southern California
    I agree, the shocks wont give much height if any. For lift I believe youd need either an AAL or a whole new leaf pack. The shocks are just able to handle a 1" lift. Maybe because they are new youll get a little lift, but once they wear in you wont get much lift if any.
  17. Oct 23, 2020 at 9:10 AM
    peanut
    peanut making uneconomical choices about my truck
    2001 Tundra 4x4 V8 Access cab 222k miles
    What did you order for that to get the full set of LEDs?
  18. Oct 23, 2020 at 9:20 AM
    theblurry1
    theblurry1 ~
    Castle Rock, CO
    Yes, it's a little snowy.
  19. Oct 23, 2020 at 9:26 AM
    empty_lord
    05 rollover special
    keep an eye on coolant level. thats all you really can do for now unless you want to dig into it more. but 90% chance is just condensation in the muffler.
    now if the smoke smells sweet, then its coolant.
  20. Oct 23, 2020 at 9:39 AM
    I've never noticed the fuel smell while driving but I did have it happen occasionally if I sat in the truck 30-40 seconds after starting it. Since I replaced my steering shaft seal I don't notice it. Have you checked that seal?
    https://www.tundras.com/threads/diy-steering-shaft-seal.48664/
    theblurry1[QUOTED] and bmf4069 like this.
  21. Oct 23, 2020 at 10:26 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I replaced my wiper blade transmission arm or whatever it's called (the one that goes between the motor and the wipers) and I'm not sure I put the wiper arms back correctly. On side has a little more bend than the other. Which ones goes where?
    Top is driver's side bottom is passenger's side
  22. Oct 23, 2020 at 10:43 AM
    You centered the steering wheel! What do I win?
    NUDRAT and oscardog86 like this.
  23. Oct 23, 2020 at 10:44 AM
    I keep reading your name as Arnold Palmer and it makes me want a half and half. With vodka.
    Darkness likes this.
  24. Oct 23, 2020 at 10:49 AM
    Arringtonpalmer
    Sam
    New Hampshire
    See the 'info dump' sticky thread. There is a spreadsheet with a full listing. I did find that the "led" column in that sheet was unnecessary. I simply found the bulb # originally called for on the rack at autozone in an LED version. Also, the book at Autozone was good to go in terms of bulb numbers as well. I replaced the door, Maps, Dome, 4x4, and the Climate Control knob lights.
    So awesome.
  25. Oct 23, 2020 at 10:52 AM
    Arringtonpalmer
    Sam
    New Hampshire
    You may continue misreading.
    Darkness and FirstGenVol like this.
  26. Oct 23, 2020 at 11:51 AM
    theblurry1
    theblurry1 ~
    Castle Rock, CO
    I bet you that seal is bad, it's loud in the cab too despite my sound deadening.
  27. Oct 23, 2020 at 11:55 AM
    Kenai4x4
    Kenai4x4 New Member
    Varies
    04 Tundra DC
    Toytec 3" Coilovers Alcan custom 4" lift via 8-leaf 1,000lb rear springs Light Racing UCAs FN Five Star wheels Falken Wildpeak AT3W 285/75r16 Stubbs Welding rock sliders Leer 180 shell JBA LT headers Custom dual-2.5-into-single-3 with Pacesetter Cats, Borla Pro-XS, and bedside fender exit Volant CAI
    Long tubes all day. The low-end torque feels great.
    chrisb and empty_lord[QUOTED] like this.
  28. Oct 23, 2020 at 12:37 PM
    Oh yeah. It's a $13 part and takes 60-90 minutes. If you have any rust you'll want to start soaking with Kroil or similar. The only tool I didn't have was something long enough to push the new seal in place. I had to improvise with a long pry bar.
    ktundra and NUDRAT like this.
  29. Oct 23, 2020 at 2:02 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Retrofit!
  30. Oct 23, 2020 at 2:03 PM
    artsr2002
    'Yonder
    Haven't checked mine but I bet mine is bad too. It gets noisy in the cab driving down the road. A lot of road noise.
    theblurry1[QUOTED] likes this.
