Tow Haul light not working
Discussion in 'Towing & Hauling' started by SundanceKid, May 7, 2020.
  1. Oct 22, 2020 at 11:39 AM
    #61
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I was hoping that you'd be looking for that beige colored wire and measuring the voltage on it. Why are you worried about a blank position? Not all of them are going to be filled, that depends on how your truck is equipped. That could be for something as random as heated seats. :)
    To give you an idea how different our trucks can be, I did happen to find a picture of that area of my truck from when I was doing a modification writeup.
    That's connector AJ4 on my truck, the one that you have out looks like it might be AJ5. They start from AJ1 at the bottom and count upward from there, counting only the white ones. As it happens, I have a few minutes, I'll run out to my truck and see if I can find that beige wire's position and take a picture for you.
    NewImprovedRon likes this.
  2. Oct 22, 2020 at 1:14 PM
    #62
    marckicker46
    marckicker46 New Member
    Marc
    I would appreciate very much.
  3. Oct 22, 2020 at 1:15 PM
    #63
    marckicker46
    Marc
    I appreciate your help..looking forward picture of beige wire
  4. Oct 22, 2020 at 1:26 PM
    #64
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Here are pictures from my truck. As mentioned, it's not the same as yours. Not only are the connectors different and in different locations, but the wires are different colors and in different pin positions. For example, what on your truck would be the beige wire in pin position 19, on my truck is a green wire in pin position 2.
    PXL_20201022_194242158.jpg PXL_20201022_194306997.jpg PXL_20201022_194317438.jpg
  5. Oct 22, 2020 at 1:29 PM
    #65
    marckicker46
    Marc
    Is this green wire for your truck pin#2?
  6. Oct 22, 2020 at 1:44 PM
    #66
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Yup...
  7. Oct 22, 2020 at 2:17 PM
    #67
    marckicker46
    Marc
    I appreciate everyone's help found out I had broken wires from AJ4 beige wire plug female into male plug wire red going to ECM was broken. Now I have tow haul mode switch! Thanks!!!
    NewImprovedRon, 1lowlife and Wynnded like this.
  8. Oct 22, 2020 at 2:20 PM
    #68
    marckicker46
    Marc
    Do you have a picture of your truck? Here is my Toyota Tundra
  9. Oct 22, 2020 at 2:38 PM
    #69
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Glad you got it sorted!
  10. Oct 22, 2020 at 2:44 PM
    #70
    marckicker46
    Marc
    I know I got my tow haul switch working..learning about this 4 wires from switch. Start from right to left..white/black(Ground),Red-?,Green (light when turn headlight) and Beige( to ECM)..is Red wire goes to speedometer cluster to light tow haul indicator when press T/H switch.
  11. Oct 22, 2020 at 4:15 PM
    #71
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The T/H indicator in the dash is turned on by the ECU when the T/H shift pattern is selected with the button press. The red/green wires are the illumination circuit.
  12. Oct 22, 2020 at 4:18 PM
    #72
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Truck.
  13. Oct 22, 2020 at 5:59 PM
    #73
    marckicker46
    Marc
    Nice looking truck. I hardly don't see stand Cab as often in Florida
    Wynnded likes this.
