Ask the Detailer
Discussion in 'Detailing' started by T-Rex266, Nov 13, 2017.
  1. Oct 12, 2020 at 4:24 AM
    #3031
    War Machine
    War Machine SSEM # 5 3MW
    x2. Great product for removing scuffs. Cheap, readily available, and very effective. Next best thing to machine polishing in my opinion.
    Fotnot and ToyoMafia like this.
  2. Oct 12, 2020 at 4:25 AM
    #3032
    War Machine
    If you ever feel like trying something different, Jescar Powerlock makes MGM look great!
    Pudge, Azblue[QUOTED] and ToyoMafia like this.
  3. Oct 12, 2020 at 8:46 AM
    #3033
    Heath423
    Heath423 New Member
    Heath
    Chattanooga, TN
    2020 Magnetic Gray CM SR5 4WD
    Console tray/dividers, Interior LED's
    I'm new at this so here is a dumb question: I just clayed my wifes new to her 2018 Pilot. Should I wax with carnauba and then treat with the Griots 3n1 or just do the 3n1 only? The car will be sitting in the garage for at least 4 more days.
    The 2018 was bought used and it does not look/feel/bead water like it has had either in some time.
  4. Oct 12, 2020 at 10:54 AM
    #3034
    Azblue
    The Dirty T ( ^_^)_且
    That's what I always use.
  5. Oct 12, 2020 at 12:02 PM
    #3035
    briarpatch
    briarpatch New Member
    I have some that I could send you a 4oz bottle to try. It is a very good sealant....I've used it a fair amount. Personally, I think their SIO2 version of this sealant is better....but if you want something free to try...PM me your address.
    MotoTundra[QUOTED] likes this.
  6. Oct 12, 2020 at 12:03 PM
    #3036
    briarpatch
    Go right to the 3 in 1....it has a wax component in it.
    Heath423[QUOTED] likes this.
  7. Oct 12, 2020 at 12:04 PM
    #3037
    briarpatch
    When it comes to vehicles....black is not a color...it's a lifestyle
  8. Oct 13, 2020 at 4:25 AM
    #3038
    War Machine
    Well then. Carry on.
  9. Oct 13, 2020 at 7:40 AM
    #3039
    MotoTundra
    MotoTundra The Ocho
    Don
    Very nice of you to offer Sir! I will pick up a bottle and give it a try. I'm sure I will like it, keep yours for you, it isn't cheap! Thanks!
  10. Oct 13, 2020 at 5:46 PM
    #3040
    Damie Street
    Damie Street New Member
    Edsel
    2016 MGM CrewMax SR5 TRD OffRoad
    What would you gurus recommend for wax and an application pad? I just ordered chemical guys clay bar & luber. Going to wash, clay bar, and wax for winter time.
    Thanks in advance
    Edsel
  11. Oct 13, 2020 at 5:48 PM
    #3041
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    9 posts up for your mgm
    Damie Street[QUOTED] likes this.
  12. Oct 13, 2020 at 6:02 PM
    #3042
    18" TRD Off Road Wheels
    I just ordered some of this to see if I can get rid of some minor scratches. Thank you for the pics and endorsement. Makin' me :spending::facepalm:
  13. Oct 14, 2020 at 5:22 PM
    #3043
    Azblue
    Have any of you guys ever tried Jescar Bead-it? As I've mentioned before, I'm a big fan of Power Lock but would love to have a quicker, easy maintenance product (spray) to use in between coats similar to Griot's 3-1 but that would work with the Power Lock. Power Lock is long lasting, but the sun here is so intense it will degrade anything quicker than most places.
    So, while looking around for something that would bond with my beloved Power Lock I found this:
    https://jescarfinishing.com/blogs/n...se-combo-power-lock-bead-it-application-guide
  14. Oct 14, 2020 at 6:12 PM
    #3044
    soobahru
    soobahru New Member
    2015 tundra 5.7L double cab 6.5ft 2019 tundra 5.7L limited crewmax
    Can or should I use iron x product for paint after doing a rinse less wash (optimum no rinse) then doing the another rinse less wash?
    ToyoMafia likes this.
  15. Oct 15, 2020 at 4:21 AM
    #3045
    War Machine
    I wouldn’t use it with a rinseless wash. Very important that you get it all off with a pressure washer.
  16. Oct 15, 2020 at 4:00 PM
    #3046
    briarpatch
    Bought a bottle based on a review by Apex Detail, and the fact that Detailed Image had a sale + a free t-shirt. It is very easy to use, and similar to Bead Maker. It is slick, not Bead Maker slick. I applied it as a topper to WGDGPS on a friend's car, with very good results. It is worth trying, especially if there's anything to brand synergy.
    ToyoMafia and Azblue[QUOTED] like this.
  17. Oct 15, 2020 at 4:02 PM
    #3047
    Azblue
    Nice, thanks for the info. It's cheap enough too, I'll grab some.
  18. Oct 16, 2020 at 12:52 PM
    #3048
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Cerakote and bead maker contributing to the bead action. Truck is dirty. But had to push it out to program a garage door app I got on prime day, so it got drizzled on.
    This one, you can see the brown dirt/dust within the water beads ha
    jpod, YotaFan05, War Machine and 7 others like this.
  19. Oct 19, 2020 at 6:02 AM
    #3049
    YotaFan05
    YotaFan05 New Member
    NE OH
    2011 Tundra Crewmax
    I did 2 coats of Griot's 3-1 on my wheels last week. Do you think this is good winter protection, or is it worth doing Dlux as well?
  20. Oct 19, 2020 at 7:46 PM
    #3050
    robz
    robz New Member
    Rob
    2015 Platinum 2WD
    Full interior LED lights. Bed cover. OEM LED Headlights and Fog lights
    That is definitely from the clay mitt. You either had very little lubrication or were applying too much pressure. You can only remove that with polishing.
  21. Oct 22, 2020 at 1:29 PM
    #3051
    Azblue
    This showed up today. I'm about 1.5 months since my last coat of Power Lock, so perfect timing. I'll probably wash the truck this weekend and give it a try. Hopefully it'll work well to maintain between my usual rounds of the Power Lock.
  22. Oct 22, 2020 at 3:37 PM
    #3052
    briarpatch
    Seeing as you are in NE Ohio, I'm guessing your winters are pretty bad. I like 3 in 1, but I think you may be asking too much of it to get through all the snow and road salt you must run into. I'd give the Griots a month or two, and then remove whatever is left and go with DLux. Then you might be okay
    YotaFan05[QUOTED] likes this.
  23. Oct 23, 2020 at 3:15 AM
    #3053
    War Machine
    Im not sure it’s suited for wheels, but I guess you’ll be able to tell us soon enough.
  24. Oct 23, 2020 at 3:16 AM
    #3054
    War Machine
    Haven’t come across this before, but love Powerlock. I know a ton of guys use Collinite over Powerlock, wonder if this is a better option since it’s the same brand. Looking forward to your results.
  25. Oct 23, 2020 at 8:41 AM
    #3055
    Azblue
    That's what I'm hoping. I just stumbled upon it on Jescar's site promoted as just that, something to use over Power Lock
  26. Oct 23, 2020 at 8:45 AM
    #3056
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I wonder how it will work seeing that its sio2 over polymer, most combos of layering seem to work best with sio2 as the base layer as it generally bonds best to very clean paint. Im hoping this works out though, powelock is a great sealant!
    Azblue[QUOTED] likes this.
  27. Oct 23, 2020 at 9:37 AM
    #3057
    Azblue
    I was thinking the same, it wouldn't bond and be a waste. But, since the company itself made a point of bringing it up and it's cheap enough, and as a spray-on it should be relatively quick and easy, I figured I'd give it a shot. All this plus the fact that @briarpatch (who is much above my detailing abilities) mentioned he had tried it with decent results made it a worthwhile experiment for me.
    Pudge[QUOTED] likes this.
  28. Oct 23, 2020 at 9:57 AM
    #3058
    Tortuga83
    Tortuga83 New Member
    Tortuga
    Griot’s Best of show spray wax has worked for me. I use it in between wax coats of collinite 915.
  29. Oct 24, 2020 at 7:14 AM
    #3059
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
  30. Oct 24, 2020 at 9:35 AM
    #3060
    itsmerh85
    itsmerh85 New Member
    Gilbert, AZ
    2020 Black TRDPro
    Washed my truck last night and used the griot’s pfm drying towel. I thought it would soak up the whole truck but I had to wring it out 3-4 times - is that typical? Should I grab a couple other cheaper options as backups - maybe from the rag company?
