Tips before POR15!
Discussion in '1st Gen Tundras (2000-2006)' started by Pucks18, Oct 22, 2020.
  1. Oct 22, 2020 at 5:43 AM
    Pucks18
    Pucks18 [OP] Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Im sure there's already threads about this but I dont care! So tomorrow im going to por15 my rear axle cover to prevent leakage as its rusted bad but hasn't leaked yet. Any tips on using por 15? I bought 1 pint, and my rear axle housing has residual grease on it from grease applications from me a few months ago. Should I use engine degreaser on it or brake parts cleaner? Thanks
  2. Oct 22, 2020 at 6:14 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    I used brake cleaner, painted the cover, put a coat of Gasket sealer over the area, then painted the area again.
  3. Oct 22, 2020 at 6:45 AM
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    As already stated, definitely remove the grease. Also scrape flaky rust but leave the "non flaky" rust. The POR won't adhere to clean metal.
  4. Oct 22, 2020 at 8:03 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    brake cleaner, wire brush to remove all the crud you can, then brake cleaner again and use the por15. After the por15 is fully dry I suggest you top coat it with a good "rust" paint of your choice. por 15 can react with light and discolor and it is always a good idea to top coat it with paint to help cover and protect everything.
  5. Oct 22, 2020 at 8:34 AM
    Pucks18
    What's an example of one of these rust paints? Also how many coats of por15 should I do ?
  6. Oct 22, 2020 at 8:41 AM
    frichco228
    Frank
    Virginia
    follow the por15 instructions, probably couple coats will do. Any paint like rustoleum or other spray can paint that is decent quality.
  7. Oct 22, 2020 at 9:36 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Make sure you do a light sanding and clean-up again after the por-15 is cured and before you finish spray it. Por-15 comes out quite an impenetrable layer that won’t let anything stick to it including more paint ;)
  8. Nov 1, 2020 at 9:58 AM
    Pucks18
    Does anyone think spraying fluid film over the por15 is a good idea?
  9. Nov 1, 2020 at 10:03 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    I didn't use POR15, but I did coat the frame with FF after all my work was done. I used Chassis Saver, which does not require a top coat.
  10. Nov 1, 2020 at 10:57 AM
    Pucks18
    Cool, that is a similar product.. so you sprayed fluid film over the chassis saver? I just want to make sure that it wouldn't be trapping moisture in doing the opposite of what I want to happen
  11. Nov 1, 2020 at 11:41 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    No, you won't have to worry about trapping moisture. I sprayed right on top of the Chassis Saver. If I'm feeling up to it later in the week, I think I'll hit the box section of my frame again. I have a half a can left, so I might as well use it up.
    If you don't have a spray hose adapter, look on Amazon and purchase one. It's basically a 20 inch hose with a brass nozzle on the end that replaces the nozzle that comes on the can. Great for getting inside frame areas.
  12. Nov 1, 2020 at 1:42 PM
    Pucks18
    Im just going to spray the ff over the por15 from the can, they work plenty good., thanks!
    N84434[QUOTED] likes this.
  13. Nov 3, 2020 at 2:34 PM
    I don’t know what size can you purchased but I’ve done my whole chassis in 2 coats of POR-15. Trick is to only take out 1/2 pint at a time and seal back up the larger can with Saran Wrap under the lid to get an airtight seal.
    N84434 likes this.
  14. Nov 4, 2020 at 5:28 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    The directions say a minimum of 2 coats. In my experience, that's absolutely correct. 1 coat does not fully seal. I would do at least 3, probably 4. The directions also say for best results appy additional coats when the surface is slightly tacky. Additional coats can be applied after letting it fully cure, but you have to scuff it before re-coating.
  15. Nov 4, 2020 at 8:40 AM
    Professional Hand Model
    Fred
    Hand Protectors
    You follow directions and I like that.
  16. Nov 4, 2020 at 4:01 PM
    SeaBass8
    SeaBass8 New Member
    2005 RCLB V6 6spd 4x2, 2002 RCLB V8 A/T 4x4
    Plans
    I'm about to have the rear diff on my 2005 RCLB repaired using this:
    Then I'm going to use this stuff on the entire axle assembly and then por15 everything. The Ospho work great, I've used it on spots here and there.
  17. Nov 4, 2020 at 4:17 PM
    16MagSR5
    16MagSR5 New Member
    Buffalo
    2016 Magnetic SR5, leveled and capped
    Boost tow Mirrors, TRD rear sway, Rough Country Duals, Bilstein 5100's, diff breather mod, more that I'm forgetting...
    Also, don't get any Por15 on the lid of the can, you will have a hard time opening it again. Stuffs like glue. Obviously if you are going to use the whole pint, it's a moot point. I used my pint twice, and almost didn't get it open again. Transferred to a new container after that without contaminating the lid.
    torino69 likes this.
  18. Nov 4, 2020 at 4:19 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE TRD OR; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads Husky liners
    I was going to mention chassis saver. From my reading of 15, its truly a multi step product that takes some time. No real experience with it, though. I hand scraped and sanded then blasted with rust reformer and rustoleum, greased a couple weeks later. I should have done differently but too many things to do before winter. Good luck OP, am curious to see what you do.
  19. Nov 4, 2020 at 5:06 PM
    SeaBass8
    SeaBass8 New Member
    Plans
    That Chassis Saver looks interesting, thanks, Never heard of it before.
  20. Nov 4, 2020 at 5:42 PM
    tvpierce
    Maine
    Report back on how that works. I've used Ospho, and I've used POR-15, but I've never used them together. I'd be interested to know how it works.
    SeaBass8[QUOTED] likes this.
  21. Nov 4, 2020 at 5:52 PM
    MEWaters
    MEWaters New Member
    Maine
    you get the ospho into the box frame? IDK if that's exactly what it's called, but the front to back box that sits behind the front grill, radiator, et al
  22. Nov 4, 2020 at 5:54 PM
    MEWaters
    MEWaters New Member
    Maine
