Tongue weight vs. payload
Discussion in '2.5 Gen Tundras (2014-2021)' started by Coolhardy, Oct 21, 2020.
  1. Oct 21, 2020 at 11:27 AM
    Coolhardy
    Coolhardy [OP] New Member
    Harris
    2014 black tundra
    Too many to list
    I m thinking of buying a bike and taking it with me when I m Over-landing. I m considering the setup below.
    My question
    1. Bike weighs approximately 450lbs. Should I subtract 450 from Tundra payload capacity or is it the Tongue weight and doesn’t affect payload?
    2. I have airbags so I won’t have a problem leveling the truck once I have the bike up.
    3. I am a speed daemon with a supercharged truck. I m not made to haul trailers, that’s the reason I went with RTT route on my truck and have the gear to disappear in the mountains. You guys think hauling 450lbs will restrict me to 55 mph hiding somewhere between the tractor trailers.
    I was wondering if any member here has done something similar. Thinking of Sunk costs before making a decision.
    Setup I m thinking
    My Current setup with RTT
    Bike I m considering
  2. Oct 21, 2020 at 12:02 PM
    Wallygator
    I carry a dual sport (almost 300lbs?) with a hitch carrier. See pic. With that setup the leaf springs are about an inch from the bump stops on completely crap Toyota stock suspension (never been a fan of Toyotas suspension settings or durability).
    Truck handles just fine but I'm careful on big hits, like bridge crossings and things. Also I am no speed demon and drive 70 to 75 mph max when fully loaded like this. This will have to do until I get the funds for a suspension upgrade.
    Your potential bike however weighs quite a bit more than mine and that also means you will have to have a pretty beefy hitch carrier. This will also add weight. But I think with your air bags it won't be much of a issue. As far as the speed thing I think you will use common sense once you see how it handles with your new setup. Hope this helps and good luck with your decision.
    Joss1799 and Coolhardy[OP] like this.
  3. Oct 21, 2020 at 12:06 PM
    18" TRD Off Road Wheels
    Anything you put on your truck comes out the payload. Your tongue weight comes out of your payload, too.
  4. Oct 21, 2020 at 10:28 PM
    Rider0120
    Rider0120 New Member
    Bucks County, Pa
    2018 White double cab SR 4x4 long bed
    Ranch Hand full replacement bumper
    You should find out what your curb weight is with the options you added to your truck ( curb weight minus 7,200lbs) It doesn’t take much to be overweight in a tundra.
    Cpl_Punishment likes this.
  5. Oct 22, 2020 at 3:36 AM
    timsp8
    NY
    With you winch, tires, wheels, and tent, along with gear and passengers you are probably close to payload already. Get it weighed like Rider suggested and check your door sticker. My truck weighs about 6700 without me in it.
    Coolhardy[OP] likes this.
  6. Oct 22, 2020 at 3:51 AM
    Also remember the rack will be around 100 lbs, so ad that to the 450 lbs motorcycle.
    Damn Harris, I forgot how bad ass of a truck you have.
  7. Oct 22, 2020 at 5:53 AM
    Coolhardy
    Harris
    2014 black tundra
    Too many to list
    Good point. Guess I just have to get my truck weighed and take it from there.
  8. Oct 22, 2020 at 5:54 AM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    You might want to look at Falcon suspension components. They have a rear shock that quickly adjusts for different loads.
    Personally, I'm not a big fan of hitch carriers. Too much weight, too far back, and all carried on one contact point? no thanks.
    Jhawk87373 likes this.
  9. Oct 22, 2020 at 5:57 AM
    Coolhardy
    Harris
    2014 black tundra
    Too many to list
    Thank you. your setup picture helps. I have a 3 inch lift with a little better suspension. Stock leaf springs but upgraded shocks, airbags and eckstrom shackles.
    Wallygator[QUOTED] likes this.
  10. Oct 22, 2020 at 6:53 AM
    Coolhardy
    Harris
    2014 black tundra
    Too many to list
    Thanks Chris. I know you want me to buy a toy hauler, lol. I don't trust me when it comes to towing trailers on long routes. I will get my truck weighed and see if I can implement my theory otherwise toy hauler it is....
  11. Oct 22, 2020 at 7:39 AM
    I think you will be all right...close to max but all right.
    Coolhardy[QUOTED][OP] likes this.
