  1. Oct 17, 2020 at 9:12 PM
    #8491
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    We have the special tools at work..
  2. Oct 17, 2020 at 9:19 PM
    #8492
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Hmmm... I didn’t see an SST note in the FSM. I guess I’ll take my replacement shopping with me tomorrow.
    On another note, fuck every single bit of these upper ball joints. I finally coaxed the drive side into place but you can bet the passenger one is taking a freezer nap tonight.
    bmf4069 and Darkness like this.
  3. Oct 17, 2020 at 9:21 PM
    #8493
    empty_lord
    05 rollover special
    Lol. Yes we have inner tie rod tools supplied by OTC. No clue the sizes, they’re not SST tools in the normal idea of them. But they’re tools that the shop supplies.
    But we do all of like 1 inner a year totally for the shop. Typically if the inner is shot the racks leaking a way
  4. Oct 17, 2020 at 10:08 PM
    #8494
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
  5. Oct 18, 2020 at 6:52 AM
    #8495
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  6. Oct 18, 2020 at 7:39 AM
    #8496
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    You guys are rock stars. I was likely gonna bail on them but it looks like a local part store has a loaner!
  7. Oct 18, 2020 at 2:25 PM
    #8497
    JessiJane06Tundra
    JessiJane06Tundra New Member
    Jessica
    San Antonio
    06 Tundra crew cab
    Small lift
    I broke the connector on my fuel line putting it back on (black one... The yellows all good) can I just throw a new connector like this one on there or do I need to replace the entire line? I really cant find the answer online. Screenshot_20201018-161116.jpg 20201018_154813_HDR.jpg
  8. Oct 18, 2020 at 2:31 PM
    #8498
    JessiJane06Tundra
    Jessica
    San Antonio
    06 Tundra crew cab
    Small lift
    I got fucked when I did mine because the aftermarket part I bought had to big of a ball. The rental tool took the old ones off but wouldn't put the new ones on so check before you remove the old ones.
    artsr2002 and NUDRAT[OP] like this.
  9. Oct 18, 2020 at 4:14 PM
    #8499
    empty_lord
    05 rollover special
    You can try. It’s not easy. Might have to cut a little back and splice and extra but of line then the new connector
  10. Oct 18, 2020 at 5:29 PM
    #8500
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Hahaha, too little too late. Had the exact same problem. Thankfully I have a massive pair of channel locks that made easy work of it. Couldn’t exactly check torque specs but eh, that’s what the claw washer is for. Used red loctite for a little extra insurance.
  11. Oct 18, 2020 at 6:08 PM
    #8501
    ktundra
    ktundra rust be damned
    Lex
    NJ
    06 Tundra DC Limited 4WD
    Bilstein 5100
    It had been raining on Friday, and I made a U-turn, which then launched a nice fish tail. Only way to combat that is to keep it in 4WD-HI, what do you guys recommend? I have to remember to take it out of 4WD when making tight turns/parking.
  12. Oct 18, 2020 at 6:16 PM
    #8502
    Cummins3500
    Logan
    Any of y’all heard of cm Motorsport off-road? Stumbled across their instagram page.
    bmf4069, FirstGenVol and Kongap like this.
  13. Oct 18, 2020 at 7:59 PM
    #8503
    artsr2002
    'Yonder
    I had a similar problem. I ended up going to the local harbor freight and bought the biggest pliers I could get my hands on. Took care of it no problem. :D Capture.jpg
  14. Oct 19, 2020 at 4:08 AM
    #8504
    Professional Hand Model
    Fred
    Hand Protectors
    Sand bags in the rear?
    ktundra[QUOTED] likes this.
  15. Oct 19, 2020 at 4:14 AM
    #8505
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Dont accelerate too hard when turning and get nicer tires and some weight in the back? Lol might help
    Darkness and NUDRAT[OP] like this.
  16. Oct 19, 2020 at 5:09 AM
    #8506
    You should get a newish SHO. Totally problem free cars. And that transverse AWD is really great.
    Rear sway bar.
  17. Oct 19, 2020 at 6:08 AM
    #8507
    ktundra
    Lex
    NJ
    Bilstein 5100
    Nicer tires would probably help. I was actually taking it easy on the accelerator, knowing I'd have to deal with a 180 if I wasn't paying attention.
    I'm wondering more about whether most of you engage 4WD-HI in the rain. Are there any adverse effects (ie - additional wear/tear) when in 4WD-Hi when roads are clear / dry?
  18. Oct 19, 2020 at 6:26 AM
    #8508
    JessiJane06Tundra
    Jessica
    San Antonio
    06 Tundra crew cab
    Small lift
    I figured it out. There was a wierd warping layer of plastic wrap on the line that was jamming it. Cleaned it all up and was able to put the connector back together. Stopped the leak so now I wait to see if that dam check engine light comes back on. Thanks for always helping me out here.
  19. Oct 19, 2020 at 9:19 AM
    #8509
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Not quite as old manish as the LS, but I loved my 08 GS350, it was a perfect blend of comfort and sporty it did use oil and the heat shield melted off (AWD problem) but I got it for $10K with 96,000 miles.
    bmf4069 and Darkness[QUOTED] like this.
  20. Oct 19, 2020 at 5:59 PM
    #8510
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    Ive been trying to find that tundra before as it was parked by my house once and I assumed he had an instagram. I posted a photo in here back in july.
    FirstGenVol likes this.
  21. Oct 19, 2020 at 6:24 PM
    #8511
    MS22
    MS22 New Member
    02 Tundra 4x4
    Cool to see you got your hitch hooked up, I was wondering if there is a difference between an accessory hitch and the one you bought? BTW your truck is looking awesome.
    empty_lord[QUOTED] likes this.
  22. Oct 19, 2020 at 8:18 PM
    #8512
    empty_lord
    05 rollover special
    This one is the accessory hitch. The “factory” one replaces the whole bumper support and costs an ungodly amount of money
  23. Oct 20, 2020 at 6:58 AM
    #8513
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    3 ton should be good for most passenger vehicles, 6 ton won't hurt but the saddle may be too large to fit some places. The ratcheted ones are a lot easier to adjust also.
  24. Oct 20, 2020 at 1:51 PM
    #8514
    @empty_lord I need to get 8+ quarts back into the transmission. I'm guessing if I try to add that much I'll overflow the dipstick. Should I start the truck after adding 4-5 quarts?
  25. Oct 20, 2020 at 1:58 PM
    #8515
    Fred
    Hand Protectors
    Anybody here think about installing a Power Steering Fluid Cooler on their early gens?
    Research shows that the same Steering Pump is in the later gens with the OEM PS Cooler (basically a metal pipe in front of the engine fan) so I don’t think I need to worry about pressure issues installing one where there isn’t.
    Derale has a junior coppered finned one for about $35 with the hose. Might need to purchase a little more hose to make it work, but thats low cost.
    ktundra and Cane Skretteburg like this.
  26. Oct 20, 2020 at 2:01 PM
    #8516
    empty_lord
    05 rollover special
    Fill, run through park reverse neutral and drive, park again, top off, repeat a few times, then go on a short drive, check level on flat ground and add accordingly
  27. Oct 20, 2020 at 2:03 PM
    #8517
    empty_lord
    05 rollover special
    When I do my p/s lines I plan on putting the tow package lines (has the outlet for the cooler) and install that same cooler. But this is quite a ways down the line
  28. Oct 20, 2020 at 3:23 PM
    #8518
    Cummins3500
    Logan
    Not the cleanest option or a perfect fit. The search continues. Cali raised’s bracket will fit and would need a little modification to be if I was gonna use it to. Probably gonna be returning it.
    the stock fog lights use a locking tab to hold in place. Rigids kit mentions that it snaps in place. I think I’m gonna order it before I write this project off as a no go
    where as the Cali raised bracket has a long threaded piece on top. The top tab could me trimmed to make it an option for our trucks
    jImmegart[QUOTED] likes this.
  29. Oct 20, 2020 at 6:40 PM
    #8519
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Here's where I'm at with the design stage of the lighted switches.
    I've found a location. I'm going to use my sunglasses compartment to mount them.
    Does toyota make a version of this without the sunglasses hole? It may look cleaner without the crease.
    I can't decide what would look better.
    Something like this.
    Or like this.
    If I went with the single switches in a row I could put more there I think.
    Edit: anyone handy with photoshop?
    Cane Skretteburg and NUDRAT[OP] like this.
  30. Oct 20, 2020 at 9:51 PM
    #8520
    empty_lord
    05 rollover special
