Transmission cooler or not Thread
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mad Max, Oct 12, 2020.
  1. Oct 20, 2020 at 12:34 PM
    #151
    Tracy Perry
    Tracy Perry New Member
    Tracy
    East Texas
    2019 MGM TRD Off-Road 4x4
    One reason I can think to use Toyota is that they will typically warranty the work if they do it. They will surely NOT warranty work if it's done elsewhere. Not much different that the dealers that put lift kits on the trucks they sell. Even though it's not OEM equipment it's covered under the dealer warranty.
    Rica25, Kung and Doxiedad like this.
  2. Oct 20, 2020 at 1:10 PM
    #152
    Mad Max
    Mad Max [OP] New Member
    Max
    2021 Tundra Limited
    I would welcome Toyota denying a claim as a result of a proper cooler installation. Toyota parts were used including their thermostat, their flexible hoses, their hard lines, and an exchanger more robust their their original design. I would love to get in front of a 6 person jury/arbitrator with the plethora of transmission life vs temperature tables. I would love to show my temperature screen shots before and after cooler installation. I said it before the smart ones pay me quick, the dumb ones pay allot more!!!! Problem is I probably won't ever have a transmission issue....
    ColoradoTJ and Rica25 like this.
  3. Oct 20, 2020 at 1:25 PM
    #153
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Mind sharing these tables as they are specific to our platform?
    Last I recall, we have 1 Blackstone analysis.
    Rica25 and glowblue like this.
  4. Oct 20, 2020 at 1:35 PM
    #154
    Mad Max
    Max
    2021 Tundra Limited
    Again Toyota says no problem and nobody proven otherwise. I hope it stays that way and my cooler was for nothing. On flip side I am not towing in S4 and babying it. It will tow at maximum posted speed limits. I began to have failures on my 20 year old Lexus. Not mechanical but electrical. Just replaced transmission solenoid. Gave to engineers at wk asked to find out why. Response soldered joints failed. Reason thermal fatigue from cycling over 20 years. Same finding with accelerator pedal position sensor. 80f to 260f plus vs 80f to 195fappears to be less taxing on equipment. Again I don’t design truck so what do I know. I know driving my $52k tundra with reasonable and generally acceptable trans temperatures make me fill good. That feeling cost me $800. We will know answer in 3-5 years for sure. I probably be on to 2021 redesign by then IF included trans cooler
    if you have debt, house payment then put money towards that, let Toyota cover transmission. I have disposable income. Could retired 5 years ago, still go to work I spend what I want. Earned by living 75% BELOW my means for 30 years never hired a contractor to wk on my house outside roof. Never had mechanic fix car outside warranty bla blah blah. Hey if I bought Toyota you have little to fear when it comes to reliability!
    Saltyhero13 likes this.
  5. Oct 20, 2020 at 1:52 PM
    #155
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    So you guys think the Toyota engineers found a way to enable the fluid to run hotter and then went "d'oh, we completely forgot about the rest of the transmission"?
    Rica25, Jtundra81, Kung and 4 others like this.
  6. Oct 20, 2020 at 2:05 PM
    #156
    timsp8
    NY
    I think there is more the just the engineers saying we can make it run hotter and it’ll last til it’s out of warranty. With the new freon and condenser, they would have had to redesign a new cooler for a model truck that was being replaced soon. They don’t sell that many tundras and most will never tow or even check their trans temps. The engineers have a boss who is looking out for the bottom line and profits.
    Alex38, jetfishn, jtwags and 2 others like this.
  7. Oct 20, 2020 at 2:16 PM
    #157
    Mad Max
    Max
    2021 Tundra Limited
    Extremely well said!!!!
    jetfishn likes this.
  8. Oct 20, 2020 at 4:07 PM
    #158
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    Picked up my truck today from dealer , fuel pump job completed .
    They refused to install the cooler As they don't want to be liable for warranty denial should any issue arises
  9. Oct 20, 2020 at 5:59 PM
    #159
    Mad Max
    Max
    2021 Tundra Limited
    If that’s a concern for DIY’s then they can remove before getting transmission diagnosed. Another reason to install yourself.
  10. Oct 20, 2020 at 7:16 PM
    #160
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    I'm late to the discussion.... What year did Toyota stop with the transmission fluid cooler? Even with the trailer towing package?
  11. Oct 20, 2020 at 8:33 PM
    #161
    TTund16
    TTund16 New Member
    you are good.
    I think 2019 and 20 don't have it.
    Not sure about 2021 ... maybe they bring it back.
  12. Oct 21, 2020 at 3:24 AM
    #162
    Bammer
    Monroe, CT
    What am I missing? Redesign? Did a site member come up with an acceptable cooler for the 2019/2020's? Or am I way off?
  13. Oct 21, 2020 at 4:23 AM
    #163
    timsp8
    NY
    From mid 10-18 the cooler was integrated with the ac condenser. From what I’ve read, 19+ they changed to different freon which isn’t as effective and required a larger surface area ac condenser so the trans cooler had to go. Seems they tested it without the cooler and said everything was good. 19+ owners here are seeing temps 50+ degrees more than 18 and previous years on the same drivetrain.
    https://www.tundras.com/threads/2019-transmission-cooler-kit.60550/
    Bammer[QUOTED] likes this.
  14. Oct 21, 2020 at 5:54 AM
    #164
    blanchard7684
    blanchard7684 New Member
    Very much this.
    Thanks.
  15. Oct 21, 2020 at 6:02 AM
    #165
    Mad Max
    Max
    2021 Tundra Limited
    I think they looked at cost vs return and said it’s cheaper to warrant ones that fail under warranty vs maintain their quality commitment on 100% of vehicles sold. GM /Ford do same thing. They realize 98% don’t tow and 2% that do will warranty. F150 tow 13klbs. Sure maybe 40 miles couple times a year not day in and day out.
  16. Oct 21, 2020 at 6:23 AM
    #166
    Bammer
    Monroe, CT
    Thanks, major brain fart this morning..
  17. Oct 21, 2020 at 6:46 AM
    #167
    Fearthisbeard
    Fearthisbeard New Member
    Gilbert AZ
    2019 - 1794 TRD Offroad
    So the TFL Trucks YouTube channel is going to be doing a video with a 2021 Tundra going up their Ike Gauntlet test this week. They said they are aware of Toyota removing the trans cooler and will be monitoring the trans temp during this test with a scan guage. I have a feeling its not going to be a good look for Toyota
  18. Oct 21, 2020 at 6:48 AM
    #168
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    Cool i will check that out. I really enjoy their channel especially the Ike Gauntlet stuff
    Fearthisbeard[QUOTED] likes this.
  19. Oct 21, 2020 at 6:56 AM
    #169
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Whew...Glad to hear that. Having followed both your posts on this topic, I thought you and @timsp8 were doing a disingenuous Click and Clack infomercial. :D
  20. Oct 21, 2020 at 7:15 AM
    #170
    Mad Max
    Max
    2021 Tundra Limited
    Toyota don’t care and TFL routinely bashes dianasor Toyota even though it best the new Chevy trailboss. Appears Toyota 12 years ahead of its time in 2008. Vs gm
    AZBoatHauler likes this.
  21. Oct 21, 2020 at 8:08 AM
    #171
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    We really need to know how Toyota engineers completed this same test. Were they in Drive with T/H or were they in S4 with T/H. Could be the difference between passing and failing based on other members experiences towing
  22. Oct 21, 2020 at 8:18 AM
    #172
    Bammer
    Monroe, CT
    Well if you think we got a shot, perhaps we can resurrect CarTalk ? :rofl:
    JohnLakeman[QUOTED] likes this.
  23. Oct 21, 2020 at 8:21 AM
    #173
    14burrito
    2014 SR5 CM 4x4 5.7
    Do they run Ike internally?
    J2807 is Davis Dam
  24. Oct 21, 2020 at 8:27 AM
    #174
    Mad Max
    Max
    2021 Tundra Limited
    A buddy of mine at work used his new 2019 Explorer and followed me to Florida pulling his 5klb boat. I told him it was a bad idea. He did it anyway at 55 mph, lmao, I left him behind after 20 miles doing 78mph pulling my 5Klb boat in my super duty. 32K miles on his explorer. When he got back 5 hours after me his transmission was slipping and went in for warranty. Required overhaul. But explorer towing capacity is 5Klb, what happened? confused? Ford said towing capacity 5Klbs. Once a transmission is overhauled they rarely shift the same.
  25. Oct 21, 2020 at 9:06 AM
    #175
    Clemsonman14
    My bad. Mixed the two up
  26. Oct 21, 2020 at 9:33 AM
    #176
    14burrito
    2014 SR5 CM 4x4 5.7
    Does bring up the question,
    Will TFL (or rather do they) follow the same profile called out in J2807 regarding accessories, load, modes, etc - or do they just get after it and run it?
    Seems like they have run a lot of previous tests, just based off quick look at the page, have not dug into the specifics on how they run it / conduct their test.
    Looks like TFL previously ran the Ike test on a 2015 Tundra - will amb conditions (time of year) be comparable? I know, you don't have these answers lol - just thinking out loud here...
    Clemsonman14[QUOTED] likes this.
  27. Oct 21, 2020 at 11:39 AM
    #177
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    And with that said... they sure as hell are not going to redesign the transmission to run hotter temps either. (as someone suggested earlier)
    It's my understanding that they tweaked the ECU for more aggressive TCC lockup. The fluid temps will benefit from this... but from what everyone is saying here and from what I've experienced... the temps are still 225+ during normal unloaded conditions.
    Bammer and timsp8[QUOTED] like this.
  28. Oct 22, 2020 at 5:16 PM
    #178
    14burrito
    2014 SR5 CM 4x4 5.7
    Final odo - 55071mi
    Degradation level will be pulled tomorrow
  29. Oct 22, 2020 at 5:19 PM
    #179
    Midmo_tundra
    Midmo_tundra New Member
    Missouri
    Was looking at the new F150’s with a friend and it appears they have a similar heat exchanger that Toyota did on the 2018+ trucks. Every truck with the 10 speed regardless if it had the max tow package, trailer package, or no tow package had this heat exchanger.
    Only F-150’s that had a front mounted auxiliary transmission cooler was the NA V6 trucks that still use a 6 speed transmission.
    Took a quick look at the Ford forums and it appears the 2018+ trucks are seeing higher temps while towing than the pre-2018 with the auxiliary transmission cooler.
    Went to build and price a 2020 F150 and I noticed this on the trailer tow package:
    • Auxiliary transmission oil cooler (Included on 3.3L V6 PFDI engine (99B) and Raptor only)
    Also no mention of a auxiliary transmission cooler on the Max tow package, only an engine oil cooler (not available for 3.3L V6 PFDI).
    Allrsdup, mdrabicki, TTund16 and 3 others like this.
  30. Oct 22, 2020 at 5:29 PM
    #180
    Jtundra81
    Joe
    Went through the ford forum last day and saw the same thing , they are reporting high trans temp due to the change you mentioned
