Back up camera Not working
Discussion in '2nd Gen Tundras (2007-2013)' started by HANKtheTANK, Oct 15, 2020.
  1. Oct 15, 2020 at 1:33 PM
    HANKtheTANK
    HANKtheTANK [OP] New Member
    2007 Tundra Limited Black, In-dash Nav JBL edition. I bought this with 205,000 miles on it, near perfect condition. I am having an issue with the backup camera. It was working off and on then stopped altogether.
    I cleaned the connections with electrical cleaner and added Dielectric grease. started working better, then it stopped again. So out of frustration, I Cut the OEM connectors off and Hard wired them together with Heat shrink butt connectors at both factory connector spots(under back bumper and inside tailgate)
    This actually worked, for a while. One day I lower my tailgate and no more camera.
    I redid all connections and soldered the connections together, covered with Heat shrink, and still no picture.
    I'm now thinking my Camera is bad. What's the chances?
  2. Oct 15, 2020 at 1:39 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    Make sure the backup lights are coming on. If they don't get power, neither does the backup camera. The switch on the transmission could either be bad, or out of adjustment.
  3. Oct 15, 2020 at 1:43 PM
    HANKtheTANK
    Yes they work. also, the Screen comes on and shows a black image, but no camera image.
  4. Oct 15, 2020 at 1:58 PM
    Randy Morton
    Randy
    Get one of the license plate mount cameras (they're pretty cheap) and wire it in to the existing wiring. If it works, the camera's bad. If not, it's somewhere in the wiring.
  5. Oct 15, 2020 at 2:01 PM
    HANKtheTANK
    I have a license plate one. Any clue on how to wire to the factory harness? It's a 12v and oem is 6v. So I know my power needs to be on a different power source. Not sure what to do on the video connections.
  6. Oct 15, 2020 at 2:28 PM
    Randy Morton
    Randy
    The video should connect the same way. The power on the OEM unit must be coming in through the radio. You can wire the license plate unit straight to the backup light power.
  7. Oct 15, 2020 at 6:53 PM
    HANKtheTANK
    Solution. I had two issues. I hooked up 2, 4"Led pods and tapped into the reverse lights. This i believe caused interference with the camera.
    I had a license plate style camera, so I hooked up to the reverse lights and then tapped into the negative and positive camera wires. Blue - and Red +. This works perfectly
    tnbndr likes this.
  8. Oct 16, 2020 at 7:03 AM
    tnbndr
    tnbndr New Member
    New Berlin, WI
    2012 White Rock Warrior CrewMax
    Can you supply a link to the license plate camera you used? I have the same issue since hooking up two LED reverse lights in my custom bumper. Camera screen comes on blue in the mirror and then blacks out. Been trying to figure out why.
  9. Oct 16, 2020 at 7:37 AM
    HANKtheTANK
  10. Oct 16, 2020 at 7:41 AM
    HANKtheTANK
    I believe that the LED add-on is the source of the problem.
    I've seen in other threads that this can be a major issue, but I really wanted those lights back there. Mostly because the old camera for 07 didn't have a night vision mode like the one I installed.
    When I get some free time I'm going to make a Wiring Harness to run up to the cab and hook into a toggle switch for the rear lights.
    Maxi13 and tnbndr like this.
  11. Oct 29, 2020 at 9:58 AM
    tnbndr
    tnbndr New Member
    New Berlin, WI
    I purchased the license plate camera. So you tapped the red/black of the camera into the Blue/red of the original tailgate camera harness? What about the yellow cable with the short red wire?
    TIA
