Power Steering quest... help!
Discussion in '2nd Gen Tundras (2007-2013)' started by neuberas, Oct 12, 2020.
  1. Oct 12, 2020 at 9:19 AM
    neuberas
    neuberas [OP] New Member
    Hello fellow members,
    Thank you all for looking at my post and if you can help, I would appreciate.
    I recently purchased a 2011 with 97k km which used to be a snow plow truck. I embarked on a big journey. Even though the kms are low, it suffered a lot from the salty roads and sort of negligence of previous 2 owners.
    Anyway...
    The steering is very very hard. I changed the fluid and it improved a bit, seemed that they had never changed it however still hard to steer and locks sometimes.
    I did notice that the hoses are all corroded and need to be changed but not my real concern right now.
    I noticed a leak coming from the steering rack, return line as shown in the picture I am attaching.
    The catch is that there is a little "pipe" that is connected in the rack in the return line.
    This pipe cannot be purchased separately from what the dealer told me, it comes with a brand new steering rack that costs around 1k here believe it or not.
    The guy at the dealer is a pretty nice guy and even recommended me a shop that refurbishes steering racks and that perhaps they would be able to help me but they also do not have one.
    In looking at used racks on ebay, most of the racks for sale also do not come with that little piece.
    Any advice? anyone went through a similar experience?
    Thank you
  2. Oct 12, 2020 at 11:00 AM
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    I would bet that metal hose connector comes with the hose and tube assy. Maybe.... Now that I look at the image a little bit better, not so sure
    neuberas[OP] likes this.
  3. Oct 12, 2020 at 3:53 PM
    neuberas
    Thank you Eric.
    I did check with the dealer and also went through a lot of diagrams and believe it or not, it does not come with it.
  4. Oct 12, 2020 at 4:24 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    @neuberas if its just the metal pipe , you should be able to disconnect the house clamp and unthread the flare fitting from the rack ... get another pipe from the auto parts store of the same diameter and flare it , cut the original pipe in the straight and remove the flare nut an move it to new pipe. then using the mini pipe bender bend the new pipe to match ... cost of pipe and tools you will look at around $30 max , if your not familiar with bending brake/hydraulic lines feel free to take it to a shop and have them do it... best cost effective way ......
    a second way would be to remove the metal pipe , clean it with non chlorinated brake clean and then braze it with a torch and brazing rod. (only recommend
    this as temp fix or trail repair compared to the first one)
  5. Oct 12, 2020 at 5:22 PM
    neuberas
    Appreciate the suggestion.
  6. Oct 15, 2020 at 7:19 AM
    Forcefed
    Forcefed New Member
    2007 Tundra Limited
    6 inch lift, ADS suspension, Alcan custom rear springs, 46 gallon metal gas tank, Full Line-x body, Wheels with 35's, Smittybilt bumpers front and rear, 10k warn winch, custom rack.
    I just did my steering rack on my tundra and it did not come with that metal hose section.
  7. Oct 15, 2020 at 7:44 AM
    neuberas
    I suppose you kept the old one right? or you bought new ones?
  8. Oct 15, 2020 at 8:06 AM
    Forcefed
    Forcefed New Member
    2007 Tundra Limited
    My lines seemed fine, so I just reused them. No leaks.
  9. Oct 15, 2020 at 12:51 PM
    neuberas
    thanks for the contribution!
    I will update when I have time to remove that part and see what can be done. more to come...
