Where did you guys mount your front camera?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra234, Oct 14, 2020.
  1. Oct 14, 2020 at 2:19 PM
    Tundra234 [OP] New Member
    Looking for mounting ideas for the front camera in the Anytime camera kit. Thanks.
    Saab95v6 likes this.
  2. Oct 14, 2020 at 6:43 PM
    Cidertom
    Cidertom Chionophile
    Tom
    2017 longbed
    First slot centered under the toyota emblem. I wanted a good view of the front hitch and it works real well there. you have to look close to see it.
  3. Oct 14, 2020 at 7:39 PM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    You have the same honeycomb grille as mine.
    Here is how I did mine. This method used the same two OEM bolt down points of the sensor for attaching the camera bracket. I did not have to drill into the grille.
    D45B5E6E-748C-42BC-B5E5-9ED7D005E50C.jpg FF65BE5A-A622-40AC-989D-9549639EA52F.jpg B776DCF0-5D96-4251-AEC9-6C1CD1EF2F52.jpg 69A6C44A-18A8-4F94-8F6A-294E3310D378.jpg 03B2833F-404C-4056-B637-734B1D225FB8.jpg A133148A-589F-473D-A557-A83C36973BD3.jpg
  4. Oct 14, 2020 at 9:14 PM
    French Avocado
    Utah / Wyo
    ElNopal likes this.
  5. Oct 14, 2020 at 9:44 PM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
  6. Oct 15, 2020 at 3:25 AM
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    I mounted mine in the same place as guys above.
    Made a small bracket and drilled one small hole.
    Used a glob of black RTV silicone as glue in the hollow space between the bracket and grille for extra bond/support.
    Ziptied the wire so the plug was located under the small access panel with the radar plug for easy un-plugging during grille removal.
    https://youtu.be/UwPnCBQohHo
    dgtulsaguy likes this.
  7. Oct 15, 2020 at 4:33 AM
    Thanks for the replies....exactly what I was looking for.....ideas for a custom mount. :thumbsup:
    ElNopal likes this.
  8. Oct 15, 2020 at 5:39 AM
    Saab95v6
    Saab95v6 New Member
    Same here , just got the same camera (Natika) and the harness from @TundraTex .
    TundraTex likes this.
