Where did you install your bass knob?
Discussion in 'Audio & Video' started by dkahs05, Sep 22, 2020.
  1. Oct 13, 2020 at 1:01 PM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    I keep forgetting to post my picture in here.
    dkahs05[OP] likes this.
  2. Oct 14, 2020 at 12:42 PM
    Kung
    KG, VA
    Do you mind sharing how hard it was to mount the knob there, any bracing questions for the bass knob box, etc.? That's what I plan on doing.
  3. Oct 14, 2020 at 12:46 PM
    The Californian
    Eric
    I'd love to share, unfortunately my only contribution was handing the man my money.
  4. Oct 21, 2020 at 10:27 PM
    JJ_TNDRA20
    JJ_TNDRA20 JJ
    SOCAL
    2020 TUNDRA TRD PRO SW
    *Wheels/Suspension -ReadyLIFT Plus 2 -ReadyLIFT skid plate adapter -Method MR701 18 x 8 + 25 -BFG KO2 305/70/18 *Exterior -BakFlip MX4 hard cover -Rigid Industries foglight caps *Audio -2 AudioMobile 10 in subs -Sealed dual 10 enclosure -Helix Class D 1 channel amp -Helix 4 channel amp -5 channel Line Out Converter -BLAM audio 6.5s/6x9s/tweeters
  5. Oct 25, 2020 at 5:21 AM
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
    6 inch Pro Comp lift. OME rear springs with Coach Builder +3 shackles. Coach Builder tie rod ends. ICON 2.5 front and rear shocks with remote res. ICON Hyd bump stops. 35" Nitto Trail Grapplers on 18" fuel rims. Kenwood DNX 892 head unit with JL audio and RF amp pushing 2 Image Dynamics idq10 subs. SABM, S POD switches for 42" in bumper and 32" behind grille LED light bars. Full interior and exterior LED conversion. LED flush mount back up lights in rear bumper. Valentine one radar detector. V Leds under dash and seats foot well lighting. TRD pro head lights and grille. Full AJT dash kit
  6. Dec 26, 2020 at 4:22 PM
    BrianH4x4
    BrianH4x4 New Member
    Shelby, North Carolina
    2015 silver sky metallic
    USB plug added for backseat 6 circuit fuse holder added Amp power steps Bed lights Bumper led ( anytime) lights Amp reasearch bed step Focal three way components up front Focal 165 in rear Jl xd200 amp for front stage Jl xd 300 amp for 10 W3 -D4 sub Maestro rr for steering wheel control
    put mine right here.
  7. Jan 18, 2021 at 8:35 AM
    james33440
    james33440 New Member
    James
    2010 Tundra Double Cab
    Magnaflow Exhaust
    Here’s my bass knob location
  8. Jan 22, 2021 at 1:16 PM
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    I completely cut out the access spot in my organizer for the 12V DC outlet. Mounted the bass control knob above the outlet. Provides easy access to the bass control and easier access to the 12V outlet as well as the cavernous console-without having to remove the entire organizer tray.
    AZBoatHauler likes this.
  9. Oct 5, 2021 at 6:29 AM
    pjsssss
    pjsssss New Member
    P.J.
    Massachusetts
    2021 Toyota Tundra Platinum CrewMax
    I put mine on back of console. This way anyone in the back seat can adjust plus it’s still an easy reach around for me. Plus I didn’t have to pull apart center console at all.
  10. Dec 2, 2021 at 1:21 PM
    Black
    2014 Tundra Limited CrewMax
    I haven’t pulled my center console yet so I am not sure what space looks like under there.
    Has anyone with AJT cup holder bezel tried mounting the knob so it replaces one of the 3 bolts on the left hand side?
    I have the AJT cup holder bezel but am waiting to install it for when my system comes hopefully by the end of the month.
  11. Dec 3, 2021 at 4:14 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    22540E55-42D4-4C6D-9D30-254C85416240.jpg Had my installer put it here.
  12. Dec 21, 2021 at 5:27 PM
    Stainlesst
    Stainlesst everybody loves an Inky. Inky Inky. go Inky go!
    going to the big D and don't mean Denver...
    09 trd crewmax, 13 TWReX stage III
    In the "Zone"...
    Kinda just put it there quickly...
