Clunk/ click sound question
Discussion in 'General Tundra Discussion' started by 14crewmax, Oct 13, 2020.
  1. Oct 13, 2020 at 4:57 PM
    14crewmax
    14crewmax [OP] New Member
    Oroville Ca
    2014 TRD off road crew max 4x4 silver sky metallic
    Stock
    I get a clunk/ click sound usually when I go from reverse to drive or drive to reverse. And also I hear the same clunk when your coasting and then step on the gas, I notice everything on my truck, everyone who knows me know it will bother me untill I fix it, just wondering if anyone else has this noise? I have 86k miles I bought the truck used so I don’t know when they last changed the fluid I’m going to change it tonight. It is not the u joints I already verified that you can hear it inside the rear diff. The truck runs smooth dosent howl or anything at any speed or accel or deceleration . I feel like I’m going to have to deal with it unless I replace the diff or rebuild it lol. It’s a 2014 4x4
  2. Oct 13, 2020 at 5:07 PM
    Coffee*8)
    Coffee*8) New Member
    Pennsylvania
    2020 Tundra Crew Max
    + Trans cooler
    Drive to reverse, slack in drivetrain? or transmission?
    Clunk stepping on the gas after coasting is a combo of the torque converter unlocking, up shifting and gas being injected back into the engine.
    My clunk happens most noticeably between 25-30 mph. Found if put it in s6 the clunk goes away.
    14crewmax[OP] likes this.
  3. Oct 13, 2020 at 5:11 PM
    14crewmax
    Oroville Ca
    Stock
    I had someone shift the gears while I was underneath and it’s definitely coming from the diff, but its quiet on the highway and street. I was thinking excessive backlash but it’s quiet while running. And it dosent do it all the time
