Any suggestions how to fix the plug thanks everyone in advance
Discussion in '1st Gen Tundras (2000-2006)' started by trueblue1981, Oct 13, 2020.
  1. Oct 13, 2020 at 4:09 PM
    trueblue1981
    trueblue1981 [OP] New Member
    2006 white tundra sr5 dc
  2. Oct 13, 2020 at 4:13 PM
    trueblue1981
    By the way I tested it....still have current running,but the bracket is tweaked and the rest flew off.
  3. Oct 14, 2020 at 4:23 AM
    trueblue1981
    Thank you...will do that!
  4. Oct 14, 2020 at 4:31 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    There's no salvaging that plug, so you're going to have to replace it. Is it OEM or aftermarket? You're going to have to crawl underneath to see how it's connected to see what your best course of action will be.
    Snap some pics and post them if you need help IDing the parts.
  5. Oct 14, 2020 at 5:22 AM
    trueblue1981
    It’s oem,i will take some pics later today after work..thank you
  6. Oct 14, 2020 at 5:48 AM
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    Looks like a standard towing connector?
    They often just unplug somewhere further up the line so they can be easily replaced but even if not there is for sure no lack of decent quality options to replace that bad boy too.
    I would solder and use thick adhesive heat shrink tubing if it does not just disconnect somewhere as those connections are notoriously subject to hostile conditions and you want a solid connection to a trailer if you can keep one that way!
  7. Oct 14, 2020 at 5:54 AM
    trueblue1981
    Yes your absolutely right there is plug further up the line i will post pictures later today and see what you folks think..either way I know I some how replace the brace the holds the socket,it’s toast! I’d like to Everthing done in one shot and out of the way of hassles
  8. Oct 14, 2020 at 6:15 AM
    I replaced the 7 pin plug like that (male side) on our old popup camper. The housing came apart and the wires were screwed onto the terminals. It may possibly be the same way on your truck. You don't want to have to replace the whole harness. It's about $215. Etrailer.com has the socket, and some of the auto parts stores may carry it.
  9. Oct 14, 2020 at 6:20 AM
    trueblue1981
    Ok thanks so...so they sell a socket? Then I would cut the wires off old one and rewire on to the new one? Thank you Tundra234
  10. Oct 14, 2020 at 6:43 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  11. Oct 14, 2020 at 10:22 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  12. Oct 15, 2020 at 7:33 AM
    trueblue1981
    thank you w666,,i looked up the links you sent me, and I think ill go your route!!!
