  1. Oct 13, 2020 at 10:32 AM
    Kongap
    Kongap New Member
    2004 SR5 DC
    @Rheywood456 is that a custom build? I’m looking around for designs to bring to a local fabricator
    Rheywood456 likes this.
  2. Oct 13, 2020 at 10:39 AM
    speedtre
    speedtre New Member
    Inland Northwest
    It changes the geometry of the suspension, which, by definition, will change the physics of the suspension movement. Any change you make to any suspension geometry that deviates from stock will change how the truck rides, there is no debate on that, the only debate is on how it will change the ride and by how much.
  3. Oct 13, 2020 at 11:03 AM
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    Not currently. But it’s on my radar to add one. This is for a possible gas / water / storage mounting spot option. Nothing set in stone on what I’m gonna mount there. But down the road I’ll use the spot
  4. Oct 13, 2020 at 11:04 AM
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    Yeah those 3.0s stand out!! Now that the spare is out of the way too, it helps. (TAKE A PICTURE, ITLL LAST LONGER)
    Darkness[QUOTED] and bmf4069 like this.
  5. Oct 13, 2020 at 11:05 AM
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    Yes. 100% custom. Built by my buddy. I gave him several photos of bumpers I liked and the requirements I wanted and he made the magic happen
  6. Oct 13, 2020 at 11:16 AM
    Kongap
    Kongap New Member
    2004 SR5 DC
    Good stuff! Thanks for the pic of it off the truck! It’s something I want as well. With a “holy” bumper, it’s giving me push towards going aftermarket or custom
    Rheywood456[QUOTED] and YardBird like this.
  7. Oct 13, 2020 at 11:20 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I'm no expert, but when I removed them from my truck it was amazing how much better it rode.
  8. Oct 13, 2020 at 11:24 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Ordered the factory hitch. My cost all in all was $208 and I’ll have it tomorrow. Better deal than the draw tite for me.
    also ordered the factory trans cooler lines to use the factory tow package cooler I picked up a while ago. The new radiator noticeably dropped trans temps and it’s just built so well I’m not fearing coolant contamination. So the 30k cooler is going on the ford to help keep its expensive built trans happy.
  9. Oct 13, 2020 at 12:15 PM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    I stuck the CB Radio here. It will work for now.
    ktundra, Voss, bmf4069 and 5 others like this.
  10. Oct 13, 2020 at 12:34 PM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I haven't driven my truck in weeks. The weather has been nice and the p-car is coming along, so it's way too fun to drive while the roads are salt-free.
    But the Tundra has been on my mind a lot. I still need to do the knock sensors and the fuel door...and I can't stand looking at it all stock like a granddad truck, so wheels and suspension are on my mind as well.
    But here's the thing.
    Those awful awful drum brakes. I can hear PHM (among others) extolling the virtues of well-adjusted and maintained drums, but I hate them. I hate that they're even there. What the heck was Toyota thinking? Which leads me to my real question.
    What am I overlooking to swap a Sequoia rear axle into my truck?
    I know it needs the following at minimum. (none of which are what I would consider deal-breakers)
    -cutting off the coil spring perches
    -welding on leaf spring perches
    -sorting the parking brake cable situation
    -possible changes to the master cylinder or prop valve
    -swapping my 3rd member into the Sequoia axle
    TIA, gents and ladies
    Late addition: I would consider swapping the rear axle from a 2nd gen Tundra if it were similar work...but I reckon it's way too wide.
  11. Oct 13, 2020 at 12:43 PM
    270Fan
    270Fan New Member
    2004 Silver Tundra 4x4 DC
    That is a badass rig.
    Rheywood456[QUOTED] likes this.
  12. Oct 13, 2020 at 2:17 PM
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    Thank you :)
  13. Oct 13, 2020 at 2:36 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Nice! Whats the average drop in temps you are experiencing with the new cooler? Please provide an example of the Coolant Temp drop, as well as the Transmission Temp.
    For example, I noticed the new Denso Radiator dropped my temps 10-15°. Seems as if the Transmission is a harder temp to nail down, but they do seem slightly cooler overall. The air temp/weather is lower and also effects the Trans Temps more vs. the Coolant Temps it seems. My Trans Temp Mojo might be slighted due to weather?
  14. Oct 13, 2020 at 2:41 PM
    empty_lord
    05 rollover special
    Coolant temps just as good as before. 180-183 aka thermostat controlled. Trans temp is about 10-15 degrees cooler though
  15. Oct 13, 2020 at 2:49 PM
    Fred
    Hand Protectors
    Yeah. Seems my coolant is about 183-185° average and the trans is 5° average less (still figuring that one out though).
  16. Oct 13, 2020 at 3:11 PM
    Fred
    Hand Protectors
    Man. Either my hearing is going or my engine is so quiet that I forget to turn the engine off or I turn the key to start it when she is running and she dies on me. What? Someone say something?
    Where was I going?:rofl:
    bmf4069 likes this.
  17. Oct 13, 2020 at 3:15 PM
    Who am I?
  18. Oct 13, 2020 at 3:16 PM
    Fred
    Hand Protectors
    Zoolander!
    bmf4069 and FrenchToasty[QUOTED] like this.
  19. Oct 13, 2020 at 4:38 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    Darkness, bmf4069 and 270Fan like this.
  20. Oct 13, 2020 at 4:47 PM
    empty_lord
    05 rollover special
    Other thing came in because bling
    (And higher blow off pressure)
    ktundra, Voss, Darkness and 3 others like this.
  21. Oct 13, 2020 at 5:02 PM
    Fred
    Hand Protectors
    What is the purpose of higher blow off pressure as compared to standard blow off pressure?
  22. Oct 13, 2020 at 5:15 PM
    empty_lord
    05 rollover special
    Raises the effective boiling point of the coolant
  23. Oct 13, 2020 at 8:05 PM
    magnetom
    magnetom New Member
    Mississippi
    2004 Tundra SR5 TRD Access Cab V6 5VZ-FE
    Installed an LED light bar on the bottom of the tailgate, has running lights, brake lights, and turn signals. Very clean installation and wiring, looks good and provides better visibility in traffic.
    MS22, theblurry1, ktundra and 4 others like this.
  24. Oct 13, 2020 at 8:28 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Headlight restoration waiting on SP to get unbusy.
    Decided to wet sand(controlling the moment), compound and polish my headlights. The pictures don't do it justice but they were pretty yellow and foggy to say the least. They aren't perfect when you get in close you can see the sanding scratches. I used 400 to start with then 1500 then 2000 grit. I probably could have spent more time sanding but as I was taking pictures my phone decided it was going to randomly restarting itself over and over and over for an hour and a half so I had to deal with that and Verizon... Here are the results I'm sure it's temporary I did not coat them but I want to halos. Disclaimer; that black blob by rear tire is not oil of any sort. Lincoln is jet black and was apparently tired. No I did not run him over
    MS22, ktundra, bassman417 and 11 others like this.
  25. Oct 14, 2020 at 4:57 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    Hmm. My coolant runs 199-200 and never a degree more. The needle on the gauge is still dead in the middle. You think I'll be fine? Lol
  26. Oct 14, 2020 at 5:00 PM
    Thrussn
    Gabe
    NM
    I'm absolutely going to have to get the same radiator as you when mine goes kaput. Who did you have make it? And would you happen to have the specs you sent to the company that made it?
  27. Oct 14, 2020 at 5:13 PM
    empty_lord
    05 rollover special
    210 is when you worry.
  28. Oct 14, 2020 at 5:13 PM
    empty_lord
    05 rollover special
    Radiator supply house. They already had the specs. With shipping it was just under $1000... so not cheap
    Thrussn[QUOTED] and Darkness like this.
  29. Oct 14, 2020 at 5:14 PM
    empty_lord
    05 rollover special
    [​IMG] New Toyota hitch is in. Try to mount it tonight
    shifty`, ktundra, hammeron and 6 others like this.
  30. Oct 14, 2020 at 5:57 PM
    Fred
    Hand Protectors
    My old NAPA one was 195-200° and I thought that to be normal. The new radiator is 183-185° steady and have been shocked to now that is true normal. I guess you’ll be alright because our engines haven’t blown up yet. :rofl:
    Try that Mishimoto Radiator ($500). Its supposedly pretty nice quality. I’d have done that one if I had known prior to the job.
