Starting suspension work...
Discussion in '1st Gen Tundras (2000-2006)' started by Voss, Oct 10, 2020.
  1. Oct 10, 2020 at 2:39 PM
    Voss
    Voss [OP] Not a new member
    2003 AC TRD 4x4
    Hi all, started working on changing out UCAs, coilovers and noticed my front sway bar is floating on passenger side/not bolted on.
    Now I have basically no mechanical knowledge but I’m pretty sure this isn’t supposed to be this way. 3A0BC146-EC06-49AA-89F6-09061AD6CD69.jpg
  2. Oct 10, 2020 at 2:47 PM
    Kongap
    Kongap New Member
    2004 SR5 DC
    Did you not notice that when driving? Yikes
    looks like the bolt snapped off. You need a stabilizer/sway bar link.
    G10dra and Voss[OP] like this.
  3. Oct 10, 2020 at 2:49 PM
    Voss
    2003 AC TRD 4x4
    Noticed when I took off the tire. Hopefully can find a replacement over weekend. Thanks
  4. Oct 10, 2020 at 2:53 PM
    Kongap
    Kongap New Member
    2004 SR5 DC
    Didn’t feel any different recently?
    at least they’re a cheap part to replace. Hope you find one locally easily
  5. Oct 10, 2020 at 2:56 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Situation Normal for a truck this age. Both mine snapped off years ago, on different occasions, and I drove without them for a few years.
    Replace both at the same time. Plenty of choices out there and many here recco Suspension Max. I have no idea which links a shop installed on mine. They are stout compared to OEM, though. Truck drives so much better with the sway bar reattached.
    ventorph, jpink and Voss[OP] like this.
  6. Oct 10, 2020 at 2:56 PM
    Voss
    2003 AC TRD 4x4
    Actually thought I wasn’t handling as well about a month ago but didn’t think much of it.
    Appreciate the input
    Kongap[QUOTED] likes this.
  7. Oct 10, 2020 at 2:57 PM
    Voss
    2003 AC TRD 4x4
    Thanks. I’ll look into sus max
  8. Oct 10, 2020 at 4:34 PM
    Voss
    2003 AC TRD 4x4
    5C11AB51-643D-4842-A305-93FAF406E446.jpg Any tips on how to remove an axel nut that won’t budge? Stuck here for 45mins. Wd40 applied 3 times.
  9. Oct 10, 2020 at 4:53 PM
    Casper421
    In the woods
    06 DC
    Impact or a breaker bar.
    Luckydog and Voss[QUOTED][OP] like this.
  10. Oct 10, 2020 at 5:06 PM
    bassman417
    bassman417 "Tundra Time". My favorite time of day...
    Paul
    Las Vegas
    2004 DC 2wd Imperial Jade
    Heat that shit up with a torch also.
    Try to use a pipe on the end of the wrench if you have one as an extension to get boo-koo leverage.
    If you can get a tight grip on the nut, use your foot and put all your weight on it. Be careful.....
    Voss[OP] likes this.
  11. Oct 10, 2020 at 5:43 PM
    Voss
    2003 AC TRD 4x4
    Thanks. Have a friend coming over with an impact gun and have a torch at home which was my next step.
    I can’t get good leverage on the nut since it’s less than half an inch thick. Thinking maybe my CV joint being ruined on this side might have something to do with it being so tight. My car would shake when accelerating fast 1st & 2nd gear. Also when I would slow down quickly exiting freeway right around 2nd gear.
    bassman417 likes this.
  12. Oct 11, 2020 at 12:34 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Make sure there is no indentation on the axle nut, or it will ruin your threads.... I'm not sure if they still indent the axle nuts, or they use a pin, but it doesn't appear to have a pin....
  13. Oct 11, 2020 at 1:53 PM
    Kongap
    Kongap New Member
    2004 SR5 DC
    Iirc, I was able to break free my driver’s axle nut with a cheapo electric Harbor Freight impact gun when I had to punch out a broke ABS sensor... But then again it didn’t look like it had as much corrosion as yours
  14. Oct 11, 2020 at 1:55 PM
    Fred
    Hand Protectors
    Any pics of this job you did? Just curious of the set up.
  15. Oct 11, 2020 at 3:26 PM
    Kongap
    Kongap New Member
    2004 SR5 DC
    Unfortunately I didn’t take any pics. Here’s the new sensor installed after though:
    And here’s the screen grab from 1A Auto with the hub pulled and the hole for the ABS speed sensor:
    While trying to do some rotor & brake work, I tried removing the sensor so the caliper could be more free to move. It had so much corrosion build up that it got stuck in place which resulted in trying to use more force to pull it out. That meant snapping the already brittle 16y/o plastic sensor off partially in the hub. Watching the 1A Auto video gave me the idea to punch it out.
    It was funny enough that when my local shop recently replaced the bearing on the other side of the truck that they ran into the same problem and replaced the sensor too. (Noticed while doing brake work)
  16. Oct 13, 2020 at 10:58 AM
  17. Oct 13, 2020 at 3:02 PM
    Fred
    Hand Protectors
    :yes:
    artsr2002 and bmf4069[QUOTED] like this.
  18. Oct 13, 2020 at 4:03 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    WD 40 can't help much on that sort of thing. You need something like Liquid Wrench or Kroil or any other penetraiting oil. It makes a difference.
    N84434 and Voss[OP] like this.
  19. Oct 14, 2020 at 8:48 PM
    Voss
    2003 AC TRD 4x4
    Breaker bar did the trick. Then I got stuck for about 4 HOURS!! trying to get the upper ball joint to release from the UCA. YouTube videos make it seem so simple... Ended up cutting it off after pounding it with a full size sledgehammer with no luck lol.
    After a couple rentals tries from the local auto part store, ending up ordering ball joint remover from Amazon. Had trouble at first but used another car to hold down the large C clamp(ball joint remover) and got it off. Basically impossible to Torque it enough to pop out without someone/something holding things in place.
    After 2 cuts, the axel was ready for high angle CV boot. Also got a new boot from Toyota for the outer CV boot.
    Now I just need to apply the final clear coat(s) on the spindle gusset my friend welded to put it all back together.
    About 12 hrs in so far and I gotta say, one of the more rewarding experiences I’ve felt in a while. Love learning and working on my truck!
    Appreciate you all!
    mtntop, bmf4069, N84434 and 2 others like this.
  20. Oct 14, 2020 at 8:54 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Thats good stuff. The problem i had with upper ball joint removal was limited space. No room for an impact gun and I couldn't get the leverage with a long socket wrench. My buddy cut one end off his snap on box end and we stuck a 4' pipe on it and got the joint off. I made him best man at my wedding for cutting his snap on wrench lol
  21. Oct 14, 2020 at 8:59 PM
    Voss
    2003 AC TRD 4x4
    Lol, man deserved it!
    Darkness[QUOTED] likes this.
  22. Oct 14, 2020 at 9:23 PM
    Voss
    2003 AC TRD 4x4
    Pics of progress cause well, pics or it didn’t happen lolB37CB7C7-5134-48A6-A1A7-A1841343D17F.jpg
    The CV axel cut was by far the scariest part of everything. Cut it once but there was a section going inward which touched the CV (arm I wanna call it) so I called and asked, was told to cut a bit more. Then assembled it all... oh, I even marked the location of notches so I could connect at same spot. Yeah I did my homework.
    Spindle gusset. Here’s to good friends! Mainly welded on back side.
    oh and ProHandmodel, Got the suspension max sway bar links. Order Sat, arrived Monday and they look beefy. I actually think I remember the exact moment my old link broke. Was off-roading with a buddy and heard metal break but couldn’t find anything at the time. Pretty sure it was the link snapping off now.
    bmf4069 and fighthedude like this.
  23. Oct 15, 2020 at 7:17 AM
    What exactly were you cutting on the CV?
  24. Oct 15, 2020 at 7:56 AM
    Fred
    Hand Protectors
    Nice work. Yeah. I heard mine snap going over a speed bump at the mall.
    Voss[QUOTED][OP] likes this.
  25. Oct 15, 2020 at 8:11 AM
    Voss
    2003 AC TRD 4x4
    Cut the extension off. Not all of it, just the outer portion.
  26. Oct 15, 2020 at 9:07 AM
    Gotcha, I was thinking you were lengthening the shaft or something! ala longer travel setup.
  27. Oct 17, 2020 at 6:01 PM
    smokey0810
    smokey0810 New Member
    '03 Tundra SR5 AC 4WD
    Gonna feel real satisfaction knowing you did all the work yourself. Just make sure you got proper torque specs on those front end nuts and bolts.
  28. Oct 17, 2020 at 7:22 PM
    Voss
    2003 AC TRD 4x4
    Finally... 00974645-8770-45FB-9586-5CED9542BD4E.jpg Passenger side complete. I was told the king coildovers were set at a 2” lift out the box, I was expecting about the same lift I had before with the TRD springs and Bilsteins set on 1st notch but I’m over 2” of lift from before. I was around 35 1/2” from ground to fender, now almost 38”. Not complaining lol but guessing it’ll settle lower.
  29. Oct 18, 2020 at 2:22 PM
    smokey0810
    Where’d you buy the setup at?
  30. Oct 18, 2020 at 4:04 PM
    Voss
    2003 AC TRD 4x4
    Different places. Coilovers from Wheelers over Labor Day sale. Got a great deal. Camburg UCAs from KT Performance while on sale. Total chaos spindle gusset, suspension max sway bar links from Summit, high angle CV boots from off-road solutions, threaded brake lines in think we’re from Wheelers as well. Been ordering parts from about 3-4 months ago lol. Finally had enough to get started
    Sunnier likes this.
