air bags
Discussion in 'General Tundra Discussion' started by mrwarm20, Oct 13, 2020.
  1. Oct 13, 2020 at 7:47 AM
    mrwarm20
    mrwarm20 [OP] New Member
    2020 tundra
    installing auto compresser so it fills or deflate at a certain height. where is a good place to tap in the power wire? 2020 trd pro.white of course.
  2. Oct 13, 2020 at 7:50 AM
    timsp8
    NY
    Where are you mounting the compressor? I’m asking because I have an airlift one and it recommends mounting on the frame. I mounted it in the bed, but then moved it to inside the truck.
    If outside the cab, I’d run the wires straight to the battery. If inside, you could get a fuse tap and run it to the fuse box.
  3. Oct 13, 2020 at 7:57 AM
    mrwarm20
    2020 tundra
    ya i got the same one. think im gonna mount it in the bed and keep it out of the weather.how bout tapping it into the feed for the trailer plug
  4. Oct 13, 2020 at 8:00 AM
    timsp8
    NY
    That should work if it’s always hot. I think it was 12 gauge wire, but I’m not sure how many amps it was. I just ran it through the hole in the side of the bed by the fuel cap and along the frame to the battery.
  5. Oct 13, 2020 at 8:16 AM
    DXO
    DXO New Member
    South Shore, MA
    2014 Crewmax Limited
    Mine was in a toolbox in the bed when I bought it, made a mount and moved it under the hood. Also added a switch and valve to let the air out when I'm not using them.IMAG1105.jpg IMAG1107.jpg
