2016 tundra won’t start unless gas applied
Discussion in '2.5 Gen Tundras (2014-2021)' started by FLYERS444, Oct 12, 2020.
  1. Oct 12, 2020 at 4:41 PM
    FLYERS444
    FLYERS444 [OP] New Member
    Hello. I have a 2016 crew max 5.7 liter flex fuel. Recently while up in the mountains the engine would not turn over unless I applied the gas pedal. The ignition turns but will not start unless the gas is applied. Do you know what it can be? Thanks for your help!
    YardBird likes this.
  2. Oct 12, 2020 at 5:56 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from SoCal.
    I've never heard of such a thing . . . :eek:
  3. Oct 12, 2020 at 5:59 PM
    :monocle: Never heard of that before.
    Welcome from NY.
  4. Oct 13, 2020 at 7:23 AM
    FLYERS444
    Let me clarify, the engine turns over but won’t stay running unless I apply the gas. I have heard flex fuel may cause an issue. I am also at about 10000 feet
  5. Oct 13, 2020 at 7:26 AM
    18" TRD Off Road Wheels
    Welcome from Wyoming.
    I've not seen or heard of anything like this. Tagging one of our Toyota Gurus - @Ruggybuggy TAG! You're it!
  6. Oct 13, 2020 at 7:33 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Sounds like an idle air control (IAC) valve issue. I had the same thing happen on my old 4runner.
  7. Oct 13, 2020 at 7:52 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I'm out. There just isnt enough info here to help. There are so many thing that can cause a no start and diagnosing would start by using techstream.
