2006 Tundra XSP wheel/tire question- Help
Discussion in '1st Gen Tundras (2000-2006)' started by Jeffrg, Oct 12, 2020.
  1. Oct 12, 2020 at 5:38 PM
    Jeffrg
    Jeffrg [OP] New Member
    Jeff
    Hello all,
    I’m looking to switch my wheel set up on my 2006 XSP. It came from the factory with the 20’ BBS rims. I’m really looking to get tires with beefier tread and get away from the street look.
    My initial thought is to drop down to a stock Toyota rim (17 inch I believe) and possible 31 inch tires, but not sure if anyone on here has done this on this exact truck... if so, did you have any clearance/rub issues? Should I be looking at a different set up? Looking for advice/input. I appreciate the help in advance!
    YardBird likes this.
  2. Oct 12, 2020 at 5:40 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from SoCal.
    Jeffrg[OP] likes this.
  3. Oct 12, 2020 at 6:27 PM
    Cummins3500
    Logan
    You’ll be fine dropping to a 17 inch wheel, and will have no problems fitting a 265/70/17. You could probably squeeze 275/70’s but that will narrow tire choices.
    does your truck have a leveling kit or plans for a leveling kit?
  4. Oct 12, 2020 at 6:36 PM
    Jeffrg
    Jeff
    Thanks Cummins3500. This truck is bone stock, have done nothing after market on it besides an in dash unit. I’m just looking for tires with actual tread, especially for pulling the boat out of the water on those low tides.
    You happen to know the bolt pattern on these first gen tundras?
  5. Oct 13, 2020 at 3:28 AM
    Cummins3500
    Logan
    6 lug w/ 6x5.5 inch or some wheels list it as 6x139.7mm. Same bolt pattern though. You going for aftermarket wheels or oem Toyota?
  6. Oct 13, 2020 at 5:28 AM
    Jeffrg
    Jeff
    I’m going back and forth. I wouldn’t mind running a stock set to be honest with you.
  7. Oct 13, 2020 at 6:04 AM
    Cummins3500
    Logan
    Toyota has some good looking oems out right now. My wife’s sequoia has a set of of the 4Runner trail edition wheels
    bmf4069 and speedtre like this.
  8. Oct 13, 2020 at 6:33 AM
    Jeffrg
    Jeff
    Dang that looks nice! Thanks for sharing. I’m doing some research, I’ll let you know the outcome. Thanks for all the help!
