Headlight Snow Accumulation
Discussion in 'Lighting' started by Tumungaloo, Oct 12, 2020.
  1. Oct 12, 2020 at 9:41 AM
    Tumungaloo
    Tumungaloo [OP] New Member
    2018 Blazing Blue Tundra trd sport
    I'm sure this has been talked about a million times.. i drove my 2018 all-stock Tundra over a snowy pass last night (first snow I've driven it in) and had to stop every 4 or 5 minutes to wipe the snow off the headlights. It was a slow, sketchy trip, and I could only see clearly for a minute then the light started to fade.
    Otherwise the Leds are great, but I might need to do something else in the winter.. The snow here is often wet and sticky. Any ideas?
    I'm new to the forum.. Thanks!
  2. Oct 12, 2020 at 9:49 AM
    18" TRD Off Road Wheels
    Welcome from Wyoming.
    We get snow here as well, and I've had this issue on all vehicles I've had. LED or not, I have always had snow stick to them in a heavy storm. I've just always kind of expected it, but maybe something hydrophobic would help? I would ask our detailing guru @War Machine , but I don't know if he's ever seen snow.
  3. Oct 12, 2020 at 10:06 AM
    Tumungaloo
    Thanks Wyoming.. Perhaps it was just the type of snow then, ill give em' a wax maybe and see if that helps, and give it a little time to see its a thing thats gonna happen every time I drive at night in the snow..
    I live in the mountains in BC, it can snow..
  4. Oct 12, 2020 at 10:21 AM
    Tumungaloo
    Is there anything WD cant do.. thanks :)
  5. Oct 12, 2020 at 10:53 AM
    Djone27
    Djone27 New Member
    2017 MGM Crewmax TSS 4x4
    HID Headlights, full LEDs, TRD front and rear sway bars, CB +2s, Eibach Stage 2s, SABM w/ pro intake tube
    I'll have to try this on my next trip to CO. Being from the south, snow is the equivalent of a Bigfoot. My first winter trip to CO (4 years ago) I had to stop and chip off about a 1/4 inch of ice off the lights due to the rain/sleet/snow mixture. This year I'll try giving them a light coat of WD40 before making the drive.
    NewImprovedRon likes this.
  6. Oct 13, 2020 at 4:27 AM
    War Machine
    War Machine SSEM # 5 3MW
    Id say try Cerakote headlight coating, but @NewImprovedRon ’s suggestion of WD40 makes sense, and is slightly cheaper.
    NewImprovedRon and GODZILLA like this.
  7. Oct 13, 2020 at 4:30 AM
    War Machine
    I’ll have you know I survived the great blizzard of 2017.
  8. Oct 13, 2020 at 4:36 AM
    I...I had no idea. You poor man.
  9. Oct 13, 2020 at 5:06 AM
    oldscout1001
    oldscout1001 New Member
    2008 Radiant Red Toyota Double Cab SR5 TRD Off Road
    For whatever WD can't do, you have duct tape.
  10. Oct 13, 2020 at 5:22 AM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    Does it move? No. Should it? Yes - WD40.
    Does it move? Yes. Should it? No - Duct tape.
  11. Oct 13, 2020 at 5:28 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
  12. Oct 13, 2020 at 6:47 AM
    Medicineman
    Medicineman Not so new member
    Western MD
    2011 MGM Rock Warrior Crewmax
    Heated Leather Seats, Morimoto XB LED and 4-Banger fogs, TRD Pro “style” grille, Bushwhacker Flares, Line-X, Leer Cap, Yak Rack
    ☝️LOL, when I have "tight nuts", its usually due to the undies shrinking in the dryer. Never knew WD40 could fix that. Not even gonna go down the "rusty tool" road.
    Black Wolf and PomDad like this.
  13. Oct 15, 2020 at 6:06 PM
    Charliebrn
    Charliebrn New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
  14. Dec 2, 2020 at 4:28 PM
    JDS616
    JDS616 New Member
    2018 Tundra Limited CrewMax
    Did a search for this scenario and saw this post. I also have a 2018 Tundra and have drove in the snow but never to the extent I drove last night for 5 solid hours. Experienced this last night on snowy trip east of Columbus OH eastbound 70 on through to PA turnpike and ending in Harrisburg. Snow was really bad and progressively getting worse, roads still wet so travel was possible. As time went on I found myself trying to figure out why I couldn’t see as well and began using the semis ahead to gauge the road. It was when I lost the semi in front of me to the off ramp that everything went dark - I realized then the headlights have to be covered with snow...emergency stop on side of highway and semis flying by, there I stood wiping off the headlights...it’s a scenario I will know to think of in the future but for never thinking about the LEDs lack of heat to help melt the snow, over time it can build up to the point of complete darkness...
  15. Dec 2, 2020 at 4:40 PM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Katzkin Leather seats, JRI shocks, Rival aluminum skids, 285/70/17 outpost nat, Berger catch can, icon rear +.5 springs, gator trifold bed cover, Perry parts bump stops, switchback turn signals,
    Ceramic coating? Will last longer than WD40 probably 1-2 seasons.
  16. Dec 2, 2020 at 5:20 PM
    Charliebrn
    NW Ohio
    Have you seen these:Morimoto 2-stroke 3.0 LED bulbs?
    Has me thinking... might solve this problem. They actually are designed to heat up the lens...
  17. Dec 3, 2020 at 5:03 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    I would add a set of dd ss3 yellow fog to this. It will help.
  18. Dec 3, 2020 at 5:46 AM
    Forkhunter
    Forkhunter New Member
    2018 DC Limited
    Thanks for the info on this. I had it happen last year too when on a hunting trip to Wyoming. I couldnt figure out for quite a while why I was struggling to see. It was snowing hard so I just attributed it to poor visibility. Stopped at the gas station and looked at my truck. Duh....no heat from those LED's... My buddy traveling behind me has no issues in his chevy.
    Lesson learned. Looking back at it, I drove pretty dangerously for a lot of miles. I will know better next time.
