Bully Dog email, Trail vs Performance, Interesting, Trail="step above stock"
Discussion in 'Performance and Tuning' started by Rhubarb, Oct 9, 2020.
  1. Oct 9, 2020 at 1:51 PM
    Rhubarb
    Rhubarb [OP] New Member
    I was curious about how the "Trail" tune (for Tundras w/long-tubes) compared with the "Performance tune. So, I sent the following inquiry to Bully Dog:
    "Hello there. I have a BDX on my 2015 Tundra. I also have long tube, Doug Thorley headers, with the factory catalytic converters intact. I am running the “trail” tune. I always run 91 octane gas. So, my question; Is the “trail” tune as similar as it can be to the “ performance tune, “ but just makes sure the air/fuel ratios are safe under all circumstances when running long tube headers?
    Bully Dog's Answer is below:
    "Trail tune is a step above stock. The tunes are all tested on stock vehicles so we can’t assure that the tunes will work fine for your vehicle. Premium tune is a lot more aggressive than trail tune."
    The reason I sent this was I had first loaded the "performance" tune. Then went to the "trail" tune. It felt different, so I wanted to see. My truck won't be pushing air out like a Tundra w/JBA's and a killer 3" dual DirtyDeeds set-up. I might go back & try the "Performance" tune and do a data-log to check AFR's.
  2. Oct 9, 2020 at 4:00 PM
    TX210Tundra
    TX210Tundra New Member
    2008 RCSB 5.7 2WD "Sport" / 2022 Limited Hybrid
    2008 - SOS 2/4 Lowering Kit : Firestone Bags : Bilstein Sports at 4 corners : TRD Pro Grill : TRD Pro 18in BBS Forged : Grip Pro LSD : Mike's "ByeNanny" : ARH LT 1 3/4 : ARH Cats : 3" X-Pipe: 3" Dual Borla XR1's / 3" Vibrant Resonators: 3" Tail pipes: DIY SABM: TRD Intake : AFE T/B Spacer : TRD Accelerator : LED Interior/Exterior : Atoto Pro HU : Cerwin Vega 10in Slim : AVS Visors : Sequoia Leather Seats : TRD shift Knob - OVTuned "Spicy 91 Torque Tune" 2022 Limited Crewmax Sonic Red Hybrid - TRD Filters : EGR Window Visors : Cheer Dring Android Adapter : RC Bed Cover : RC 1.75 Level Kit : Undercover Swing Case
    I'd probably follow-up with specifics around what the difference between the 2 tunes are as far as timing/afr target and anything else they can provide. I'm definitely curious now...
  3. Oct 10, 2020 at 1:03 PM
    Rhubarb
    I put my truck back on "performance." Plan on doing a "data-log". Will share results.
    Your exhaust is the top of the line, ARH's & dual 3" exhaust. My goofy, set up is probably somewhere between stock w/a cat-back and your set up.
    Thanks TX210!
    TX210Tundra likes this.
  4. Oct 11, 2020 at 11:30 AM
    Rhubarb
    Hey TX210. So I went out to do it this morning. I can't get AFR's as an option. Do you know if the Bully Dog does record AFR's?
    Thank you.
  5. Oct 11, 2020 at 2:12 PM
    TX210Tundra
    I have the Platinum BD, no AFR option. I don't run the BD in my truck either, just download the tune and back in the box it goes. I use a separate AFR gauge for monitoring.
  6. Oct 11, 2020 at 3:06 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
