Welcome to Tundras.com!
Quick Links:Differential Oil Change, Metal on Plug(s). How Concerning?
Smoke at startup, valve guide seals? Replace without removing heads?
Auxilary Lights Install on First Gens
Vent Control Binding - Solved
Water pump help maybe timing belt
Is this coolant leak from the O-ring behind the thermostat?
Custom rear bumper
Discussion in '1st Gen Tundras (2000-2006)' started by ajmorenoaz, Oct 10, 2020.
