Battery Corrosion
Discussion in 'General Tundra Discussion' started by parker44, Oct 10, 2020.
  1. Oct 10, 2020 at 8:58 AM
    parker44
    parker44 [OP] New Member
    2008 Tundra - Desert Sand Mica
    Well, I was looking under the hood yesterday checking some things and noticed a ton of corrosion on my positive battery terminal. I got some battery cleaner and decided this morning I would remove the battery and clean the connectors good. The negative side was fine, came right out. As i started trying to clean the terminal on the positive side to remove it, I noticed it was worse than I thought.
    My positive terminal evidently has been leaking enough where the post was starting to loosen out of the battery Itself. It corroded enough to where it started eating away at the terminal attachment from the truck, so part of it is gone, and the bolt going through keeping it tight has withered away as well, where i can’t hold it to loosen it up very easily.
    this battery was purchased from Firestone in May 2018.
    Wallygator, omgboost and TheBeast like this.
  2. Oct 10, 2020 at 9:56 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Add some of these pads to the replacement battery.
  3. Oct 10, 2020 at 11:09 AM
    Interstate has a 5 year prorated warranty on their batteries. You will need to replace the terminal end as well. Once it has gotten corrosion etching on it, it will not stop no matter what you clean it with. The terminal is about $25 through the dealer or you can get a universal one at AutoZone for about $6.00. I went through this a couple of years ago. Mine was so bad you couldn't even see the terminal.
  4. Oct 10, 2020 at 11:29 AM
    TheBeast
    TheBeast The Beach
    oh whoa..that usually does not happen overnight though ;) always keep an eye on the battery terminals when opening the hood.
    you can replace the + cable.
  5. Oct 10, 2020 at 11:39 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I lather some dielectric grease on the terminals time to time.
    Wallygator, Wrongside and YardBird like this.
  6. Oct 10, 2020 at 3:28 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    As part of the battery/terminal repair, you should check out your charging system in the process. One of those pics (last one in your post) shows the vent cover wet with acid, which happens when the acid boils during overcharging. Acid may be leaking from the terminal post as well, but acid traveling from the post/battery surface to the top of the vent cover seems unlikely imo.
  7. Oct 10, 2020 at 5:28 PM
    parker44
    i think some of that was overspray with my cleaning stuff, it wasn’t wet before. My needle inside for the charging has been staying in the middle?
  8. Oct 10, 2020 at 5:29 PM
    parker44
    should I look at replacing the entire positive cable as well? I’m worried about the corrosion on the top as well, which has my amp connected along with the positive cable.
  9. Oct 10, 2020 at 5:45 PM
    You could if you wanted to. I don't know what the cable cost is or what Is involved with changing the cable on our trucks. I wonder how far the corrosion worked down the cable. Its hard to tell unless you pull the insulation back.
    parker44[QUOTED][OP] likes this.
  10. Oct 10, 2020 at 5:49 PM
    Piney
    Piney New Member
    South Jersey Pine Barrens
    2020 MGM TRD Pro
    Keep it simple before you dive into the complex.
    Clean the terminal and put some dielectric grease on it.
    Check it periodically.
    No need now to completely re-wire the truck.
    Wrongside and parker44[OP] like this.
  11. Oct 11, 2020 at 7:53 AM
    Wrongside
    Wrongside New Member
    AB
    2016 Tundra
    x2
    YardBird likes this.
  12. Oct 11, 2020 at 8:13 AM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Yes, cable needs replaced . These are sealed cables, and will corrode inside.
  13. Oct 11, 2020 at 8:27 AM
    Wallygator
    Coke is great at removing that crap. I use Amsoil metal protector on the terminals because it dries to the touch. Works great and never have an issue.
  14. Oct 11, 2020 at 8:37 AM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    A little baking soda and water will clean it pretty good too , the baking soda neutralizes the acid .
    RitcheyRch and YardBird like this.
  15. Oct 11, 2020 at 8:43 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    YardBird and RitcheyRch like this.
