TPS Sensors 2020 Tundra
Discussion in 'Wheels & Tires' started by UtahTundra2020, Oct 8, 2020.
  1. Oct 8, 2020 at 1:52 PM
    UtahTundra2020
    UtahTundra2020 [OP] New Member
    Orlando
    2020 Barcelona Red Tundra
    Remote Starter
    FYI.. I purchase a 2020 Tundra that came with Steel wheels. I replaced them with the alloy Toyota wheels, I had discount tire shop swapped the wheels and the new sensors would not program to the truck, sensors had to be replaced because they did not fit on the alloy wheels.
    after a couple trips to the tire shop and the manager unsusefully not being able to program the new sensors I went to Toyota dealership, this is what they are telling me.. they are claiming that because my tundra came with steel wheels the computer will only program to the original sensors. Has anyone had this issues before? I cant imagine every tundra with aftermarket wheels has the TPS Sensors not working.
  2. Oct 8, 2020 at 2:06 PM
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    I will find out this weekend if aftermarket TPMS works. My winter tires are getting mounted and programmed at my local shop on Saturday. Aftermarket alloy wheels and, as far as I can tell, non-OEM TPMS sensors are being used. Though I do have the OEM alloys stock.
    Wouldn't make sense to me if the wheel is steel vs aluminum and that's what's causing the problem.
  3. Oct 8, 2020 at 2:17 PM
    UtahTundra2020
    Orlando
    Remote Starter
    Good Luck,
    Not sure why they are having such a hard time getting this figure out. My tundra is a the dealership right now has been since yesterday at 5:00 pm still no call from them bing done with the new sensors. Im fearing they will come back with nop we cant program them.
  4. Oct 8, 2020 at 2:21 PM
    Blueknights75
    Ron
    Clayton, NC
    Many members have switched over from OEM steel wheels to OEM alloy successfully. The sensors are different between the two types of wheels but they can be programmed....
  5. Oct 8, 2020 at 3:15 PM
    glowblue
    glowblue From time to time
    VA
    I swapped steel for alloy wheels and my tire shop used Autel aftermarket sensors which have been just fine. Mines a 2019, I don’t know if anything changed in 2020.
  6. Oct 8, 2020 at 3:17 PM
    mcm0455
    mcm0455 New Member
    2020 Tundra Platinum
    I used my Autel TMPS programmer on my new wheels/tires on my 2020 Platinum. Very easy to do, about 5 minutes.
  7. Oct 8, 2020 at 3:20 PM
    fbingha
    fbingha New Member
    Bakersfield, CA
    Your answer for discount tire specifically.. https://www.tundras.com/threads/tpms-sensor-re-calibrating.42293/page-2#post-1916066
  8. Oct 9, 2020 at 7:51 AM
    UtahTundra2020
    Orlando
    Remote Starter
    All,
    Issue has been fixed! I took the truck to Toyota they installed OEM sensors for the alloy wheels and program them to my truck. It did cost me $386.00.
    Discount tire offered to do a 100% Refund since they weren't able to Program the sensors they sold me..
